Containing Conficker
conficker
With all the noise about Conficker turning your computer into liquid hot magma on April 1st, there’s actually some positive news. Researchers from the HoneyNet Project have been following the worm since infections started in late 2008. They recently discovered an easy way to identify infected systems remotely. Conficker attempts to patch the MS08-067 vulnerability during infection. A flaw in the patch causes the machine to respond differently than both an unpatched system and an officially patched system. Using this knowledge, the team developed a proof of concept network scanner in python to find infected machines. You can find it in [Rich Mogull]’s initial post. [Dan Kaminisky] has packaged it as an EXE and has instructions for how to build the SVN version of Nmap, which includes the new signature. Other network scanner vendors are adding the code as well.
In conjunction with this detection code, the team has also released the whitepaper Know Your Enemy: Containing Conficker. It discusses ways to detect, contain, and remove Conficker. They’ve combined this with a tool release that covers Conficker’s dynamic domain generation among other things.
PSP As A Status Monitor
[Avi] sent in his PSP as a status monitor hack(zip). He’s using Lua on the PSP, so you have to install LuaPlayer. The computer side is written in python, so it should be cross platform. Last time we saw a psp as an extra monitor, it had more capabilities, but it was limited to Windows. You’ll find the Lua script as well as the python in the zip file. It’s a nice use for an extra psp.
Parts: Programmable Gain Amplifier (MCP6S26)
mcp6s26
Microchip’s MCP6S21/2/6/8 are programmable gain amplifiers that multiply an input voltage by a factor of 1, 2, 4, 5, 8, 10, 16, and 32. The MCP6S22/6/8 also have selectable input channels for working with different signal sources. The multiplication factor and input channel are configured through an SPI interface. This chip is useful for multiplying a small input signal, and selecting among several analog input sources. We demonstrate the six channel MCP6S26 below.
Continue reading “Parts: Programmable Gain Amplifier (MCP6S26)”
Arduino + Wii Nunchuck + Servos
[youtube=http://www.youtube.com/watch?v=phcsDNOglLI]
[Yezzer] has posted a video of a cool little project he’s working on. He has interfaced the Arduino and the Wii Nunchuck to control some servos. He mounted a standard USB webcam on it for good measure. There isn’t a whole lot of information, but he does include a few links to code he modified for the project. The movement is quite natural looking and seems like it would be a cheap way to get some good animatronic controls started. This might actually be a great way to control a robot for the Crabfu challenge, if they ever have another one.
Update: As [dokument] points out in the comments below, it looks like we’ve seen a set up that could be almost identical in the past.
[via the Hack a Day Flickr pool]
