Neo-Geo Case Mod
Neodrive%20with%20pads
What do you get when you cross a Neo-Geo and a Sega Genesis? A pretty vintage case mod. [Brett] used a variation of the 16-bit console (known as the Mega Drive II) as the base of his project. With an original Neo-Geo motherboard and a few other components (such as a power indicating LED), the ‘Geosis’ was born. [Brett] removed a few of the unnecessary parts from the mobo, like the power-amp, and set it up to work with a regular 5V DC wall adapter. The PCB also had to be clipped so it would fit into the Mega Drive chassis.
Though it may not be the case, some Neo-Geo motherboards in circulation have been salvaged from arcade machines. An enclosure would be essential for protecting them during standalone use – something [Brett] plans to do a lot.
Build An Analog TV Station
F4Y5YOTFX8OUGNN
With the transition to digital TV, the FCC has abandoned the old analog format. Luckily, you can take advantage of this and set up your own analog TV station. The FCC has a tool on their site to see what channels are open in your area to broadcast in. To broadcast, you need a TV transmitter, but cheap short-range models can be found on eBay or made at home [pdf]. Once you have a transmitter, you can pump in a video source, either your own content or videos from youtube. One group, OMGimontv is showcasing popular youtube clips on channel 14 in New York. On their site, users can vote for what clips they want to see. Although this isn’t as simple as making a radio station, it still has a lot of potential.
[via BoingBoing]
Direct-to-PCB Inkjet Printing
inkjet-pcb
Full Spectrum Engineering has offered up a tutorial for their inkjet direct PCB kits that repurpose direct-to-CD capable inkjet printers (such as the Epson R280) to print etch-resistant ink straight onto copper clad board. This is easier and less error prone than some iron-on methods, especially for two-sided boards. Just print (no need to reverse the design), dry on a hot plate or in a toaster oven for a couple minutes, and your board’s ready for etching!
Homebrew methods exist for all of this, but for those who would rather move ahead with their design than spend time scrounging for the required bits, the kits offer a pretty good value. They can also meet you halfway…say if you’re only lacking access to a laser cutter and just want the CD stencil…all of the parts are available individually or as a complete set: the resist ink cartridge, the stainless steel board-holding stencil, and a supply of double-sided copper clad boards precisely sized for the stencil (3.5 by 2.5 inches). The small board size is well within the limits of the freeware Eagle Light Edition software.
Concerned about gunking up your nice inkjet with non-OEM ink? You can dedicate hardware to the job without breaking the bank. Many of the compatible printers are of the “free printer after rebate” bundle variety that can now be found inexpensively on Craigslist or eBay.
Repurpose An Unused Portable CD Player
diy_wall_mounted_cd_player
[Ariel] liked the look of the Muji wall mounted CD player. He set out to build his own, posting a how-to that documents his project. The custom paperboard case contains a portable CD player, two portable speakers with amplifier, and a pull-string switch to turn it on and off. With mp3 players sending portable CD players the way of the dodo, and with the proliferation of powered mini-speakers this is a thrift-store build waiting to happen.
[via Boing Boing Gadgets]
Gmail Without The Cloud: Tips For Next Time
gmail_outage_tips
Yesterday’s Gmail service outage is a hot topic on just about every news site right now. For so many of us that have always taken the reliability of Gmail for granted it was a real shock to lose all of the functionality of the web based system. Now that we’ve learned our lesson, here’s a couple of tips to help you out the next time there’s an outage.
Continue reading “Gmail Without The Cloud: Tips For Next Time”
Simple Automatic LED Lamps
simple_led_lamps
[woody1189] put together some automatic lighting for his closet. Nine LEDs are grouped into three lamps and controlled by a hall effect sensor. He prototyped this on an Arduino and then migrated over to an ATtiny85. Although the current implementation could be accomplished without a microcontroller, we’d love to see some firmware improvements such as an auto shutoff for when you forget to close the closet door. The hall effect sensor seems to pop up in a lot of projects so make sure you get a few of them with your next parts order. Video of this in action after the break.
Continue reading “Simple Automatic LED Lamps”
Fire Horn
firehorn
Artist [Ariel Schlesinger] has managed to replace an air horn‘s compressed air tank with butane fuel. This hack manages to change the pitch of the horn slightly, as well as making one very noisy flamethrower. While not as impressive as other flamethrowers, this would probably take the cake for most achievable. Currently the site containing the how-to is down, but we would have to recommend not doing this at home anyway. Video after the jump.
Continue reading “Fire Horn”
