The Mechanical Diode
A diode allows current to travel in only one direction. With that in mind, [Alex] built a mechanical diode that will only allow gear rotation in one direction to be transmitted through the system. But wait, by connecting two of these devices together he’s built something of a mechanical rectifier. An electrical rectifier converts alternating current to direct current and this mechanical version outputs clockwise rotation no matter what direction of rotation is coming into the device.
There’s video which we’ve embedded after the break as well as many pictures on his site but not much explanation. Here’s what we’ve deduced. The two large gears are inputs. Mounted on top of them is a smaller ratcheting gear that will only turn in one direction. This ratcheting gear selects whether the smallest gear on the left or right will rotate, which then feeds the output gear at the top of this image. Continue reading “The Mechanical Diode” →
Leapfrog Didj: Followup
Yesterday we mentioned the Woot! sale of the Didj, and we had some comments and emails from readers who had purchased one. We couldn’t resist either, and ordered a couple to take apart and modify. We will probably be following the work laid out by [Claude Schwarz], who seems to be one of the leading hackers on the scene. [Claude] has done some work in porting the GP2x libraries to the Didj, which gives a tremendous head start to anyone looking to have a working game system any time soon. There will also be a build log for everyone to follow along at home, and contribute what you want and have, as well as a follow up How-To when a working system is attained. Happy Hacking, everyone.
Print Your Own Pizza
[youtube=http://www.youtube.com/watch?v=XJ7gD0nH-xA]
If you think there’s never enough computerized numerical control in your life perhaps the pizza plotter should be your next project. This is a large 2-axis machine that shoots pressurized sauce onto a pizza crust. It’s a food-grade RepStrap and appears to use a garden sprayer as a reservoir. They learned their lesson when a loose hose clamp sprayed sauce around the room. We’re thinking this is a bit of reinventing the wheel as pizza-making factories but it’s fun nonetheless.
Lego Spider-bot
[MkMan’s] LEGO spider robot combines pieces from a Mindstorm kit with a few milled plastic parts. The legs are a locomotive concept called a Klann Linkage. They operate in pairs and convert the rotational force from one motor into movement for two legs. Here, a total of four rotating gears moves eight legs, besting the hexapods we saw a couple of weeks ago in both leg count and motor economy.
Each limb is made up of five pieces plus one base for each pair. That makes eleven pieces per pair and a total of 44 for the entire robot. [MkMan] milled these parts out of 3/8″ HDPE stock. He’s made videos of forward motion and turning which we’ve embedded after the break. Even on a polished surface the bot looks fairly efficient at getting around.
Continue reading “Lego Spider-bot” →
Amplifier Built Inside A 9v Battery
It’s pretty creative to use a 9v battery as an enclosure. That’s what [Osgeld] did when building this amplifier. There are several advantages; they’re easy to find, it keeps a bit of the dead battery out of the landfill, and this method provides a built-in connector for a 9v power source. In this case the circuit is built around a LM386 audio amplifier. It’s glued to the back of a potentiometer and wired up with the other components for a package smaller than a quarter. A stereo jack reside in the side of the battery case with a cable and alligator clips for connection with a speaker. Now the amp can be quickly connect to any 4-8 ohm speaker.
Ask A Winner Updates Day 4: Answers
Not too long ago we asked our readers what they would like to hear about from the PUSH N900 winners and their hacks. We got some silly questions, and some serious, we asked both and now the PUSH teams have answered.
Solderin Skaters are really making progress. They’ve gotten their printed circuit boards and mounting equipment all set to go, and the code and algorithms are really shaping up. All that and more updates are seen in their latest video, and blog entry.
Continue reading “Ask A Winner Updates Day 4: Answers” →
PHP Runtime Rewritten, By Facebook?
Yes, its true. Facebook has completely rewritten the PHP runtime to make it faster and more efficient, and its completely open source. Named HipHop, its described as a source code transformer, changing PHP into optimized C++ which is then compiled using g++. Thus keeping the best aspects of PHP while taking advantage of the performance of C++. Using HipHop, the Facebook web server CPU usage has been decreased by about fifty percent! And who would have thought that this and many other cool advances in programming, started at a Hackathon.
