The latest version of the Linux kernel was just released on Sunday, and there’s a little bonus which we think is worth considering. It seems that many changes from Android made their way into version 3.3 of the Linux kernel.
This may not sound like much, but it’s a great example of the power of open source. Since device specific changes based on the Linux kernel must be released under the same license, hardware manufactures are compelled to release their sources. But normally this would only help you if you have the expertise to slog through their code and find the parts that you need for whatever purpose you have in mind. But with these changes being rolled into the main kernel you should be able to run your own distributions on Android devices relatively easy; hardware support is already in there. Of course there’s still a lot of expertise that goes into cross-compiling an OS.
This may have the potential to open up old Android hardware as a development platform. Think of how Chumby hardware has been used in robotics projects. Now what if your old Bluetooth and WiFi enable cellphone had a stock kernel that was as easy and open to use in your own projects?
[Thanks Adam]
![6845665720_8da6d83443[1]](http://hackaday.com/wp-content/uploads/2012/03/6845665720_8da6d834431.jpg)
