New Chip Alert: The ESP8266 WiFi Module (It’s $5)
Every so often we run across something in the Hackaday tip line that sends us scurrying to Google, trying to source a component, part, or assembly. The ESP8266 WiFi module is the latest, made interesting because it pretty much doesn’t exist outside China.
Why is it cool? It’s a WiFi module with an SOC, making it somewhat similar to TI’s CC300 in conception (A.K.A. the thing that makes the Spark Core so appealing), in that a microcontroller on the module takes care of all the WiFi, TCP/IP stack, and the overhead found in an 802.11 network. It’s addressable over SPI and UART, making this an exceptionally easy choice for anyone wanting to build an Internet of Things thing; you can simply connect any microcontroller to this module and start pushing data up to the Internet. Oh, it’s also being sold for $5 in quantity one. Yes, for five dollars you can blink a LED from the Internet. That’s about half the price as the CC3000 itself, and a quarter of the price if you were to build a CC3000 breakout board.
There’s a catch, right, there’s always a catch. Yep. About two hours after this post is published it will be the number one English language Google result for “ESP8266.” As far as the English-speaking world is concerned, there is absolutely nothing to be found anywhere on the Internet on this module.
Seeed Studio recently sold a few of these modules for $7 and has some documentation, including a full datasheet and an AT command set. All the documentation is in Chinese. There’s also an “ESP8266 IoT SDK”, but from a quick glance at the code, this appears to be an SDK for the SOC on the module, not a simple way to connect the module to a microcontroller.
Anyone wanting to grab one of these modules can do so on Ali Express. Anyone wanting to do something with one of these modules will have a much more difficult time, most likely poking and prodding bits randomly with the help of Google translate. Should someone, or even a group of people, want to take up the task of creating a translation of the datasheet and possibly a library, we have a pretty collaborative project hosting site where you can do that. You may organize in the comments below; we’ll also be taking bets as to when a product using the ESP8266 will be found on Kickstarter. My guess is under a month.
EDIT: Here’s a translation of the datasheet and AT command set.
Edit two: [bafeigum] is writing a library go help him out.
Thanks [Liam] for the tip.
ARM-BMW, The Open Hardware Cortex-M0 Development Board
[Vsergeev] tipped us about a neat Cortex-M0 based development board with a total BoM cost under $15. It’s called the ARM Bare Metal Widget (ARM-BMW), focuses on battery power, non-volatile storage and debuggability.
The chosen micro-controller is the 50MHz NXP LPC1114DH28 which provides the user with 32kB of Flash, 8kB of SRAM, a 6 channel ADC and I2C/SPI/UART interfaces among others. The ARM-BMW contains a 2Mbyte SPI flash, an I2C I/O expander, several headers for expansion/debug purposes, 4 LEDs, 2 buttons, 2 DIP switches and finally a JTAG/SWD header for flashing and debugging. As you can see in the picture above you may either populate your own HC49UP crystal or use the internal 12MHz RC oscillator.
The platform can be powered using either a USB cable or a LiPo battery. As you can guess it also includes a much-needed battery charger (the MCP73831T) and a switched capacitor DC/DC converter to supply 3.3V. You may find all the files on the hardware or software repositories.
Retrotechtacular: Turn On The Magic Of Colored Light
title cardChances are, you take color for granted. Whether or not you give it much thought, color is key to distinguishing your surroundings. It helps you identify fire, brown recluse spiders, and the right resistor for the job.
In the spotlight this week is a 1950s educational film called “This is Color“. It also happens to be a delightful time capsule of consumer packaging from the atomic age. This film was made by the Interchemical Corporation, an industrial research lab and manufacturer of printing inks. As the narrator explains, consistent replication of pigments is an essential part of mass production. In order to conjure a particular pigment in the first place, one must first understand the nature of color and the physical properties of visible light.
electromagnetic spectrumEach color that makes up the spectrum of visible rays has a particular wavelength. The five principal colors—red, yellow, green, blue, and violet—make possible thousands of shades and hues, but are only a small slice of the electromagnetic spectrum.
When light encounters a transparent material more dense than air, such as water or glass, it has to change direction and is bent by the surface. This is known as refraction. A straw placed in a glass of water will appear bent below the surface because the air and the water have different refractive indices. That is, the air and water will bend or refract different percentages of the light that permeates them. Continue reading “Retrotechtacular: Turn On The Magic Of Colored Light”
An IPod Dock Converted Into Chromecast Speakers
CoQIKNJ
[easybakejake] figured out a way to fuse together an iPod speaker dock and a wireless Chromecast receiver. His method utilized a modified HDMI-to-VGA adapter. From the looks of it, apps like music for Google Play, Pandora, and Music All Access seem to able to be streamed through this device.
A few problems did come up with this project though when researching the functionality of this music hack. For one, there is little to no documentation since the tip came to us through a Reddit post. Another inconvenience had to do with supporting different monitor sizes. [easybakejake] confirmed in the comments of that post that he ran into an error where the input was not working; probably due to a resolution issue. Eventually, he got it working and dubbed the device the MusicBox. Now stick it on a roomba and get it to DJ a party (like this Parks and Recreation skit that follows after the break):
Continue reading “An IPod Dock Converted Into Chromecast Speakers”
Laser Engraved Business Cards With LEDs
Plexiglass-LED-Lit-Business-Card-1
Regular paper business cards are boring. They are flimsy and easily forgettable for the most part, and when stacked together or thrown in a pile, it’s hard to locate a specific one; like trying to find a needle in a haystack. Plastic cards aren’t much better either because they still fall into that ‘who cares’ category. But plexiglas business cards with laser cut etchings beautifully lit up by an LED?! Yes please.
The design was developed by Romanian engraving company called Gravez Dotro who fixed the problem of simply glancing at a business card, putting it in a wallet, and causally forgetting about it later, never to contact the person that gave it out. If someone hands away one of these though, the receiver is definitely going to remember it. The solution isn’t that high-tech and just about anyone with access to a laser cutter can make their own. It will be interesting to see what people come up with. If you feel like creating one, be sure to send us pictures. We would love to see them. Video of the design comes up after the break.
Continue reading “Laser Engraved Business Cards With LEDs”
Prove Your Geek Cred With A Binary Watch
Binary Wrist Watch
After just one prototype, [Elia] has finished his super awesome Binary Wrist Watch.
He designed the PCB in KiCad, using a template for the PIC he found in a standard library — unfortunately it turns out the SSOP-20 PIC footprint in this library was actually a TSSOP-20. Confusingly enough, there was also a TSSOP-20 footprint in the library. Luckily it’s just a few millimeters off so [Elia] was able to just bend the pins in a bit before reflow soldering it in place.
The trickiest part of the project was actually making the wristband. He tried several different styles before settling on a paracord braid design he found on Instructables.
We especially like his quote at the end of the project:
Although not having worn the watch in the presence of normal humans, I can already guarantee that now everyone will be able to easily identify me as a nerd.
Acceptance is the first step in realizing you have an addiction, right?
[via Dangerous Prototypes]
