Prove Your Geek Cred With A Binary Watch
Binary Wrist Watch
After just one prototype, [Elia] has finished his super awesome Binary Wrist Watch.
He designed the PCB in KiCad, using a template for the PIC he found in a standard library — unfortunately it turns out the SSOP-20 PIC footprint in this library was actually a TSSOP-20. Confusingly enough, there was also a TSSOP-20 footprint in the library. Luckily it’s just a few millimeters off so [Elia] was able to just bend the pins in a bit before reflow soldering it in place.
The trickiest part of the project was actually making the wristband. He tried several different styles before settling on a paracord braid design he found on Instructables.
We especially like his quote at the end of the project:
Although not having worn the watch in the presence of normal humans, I can already guarantee that now everyone will be able to easily identify me as a nerd.
Acceptance is the first step in realizing you have an addiction, right?
[via Dangerous Prototypes]
PiAware, Automated Airliner Tracking On The Raspberry Pi
FlightAware
For the sufficiently geeky aviation nerd there’s FlightAware, a website that tracks just about every airliner and most private planes currently in flight. The folks at FlightAware compile all the information with the help of a few thousand volunteers around the world that have a bit of hardware to listen to ADS-B transmissions and relay them to the FlightAware servers. Now you can do this with a Raspberry Pi, and as a nice little bonus FlightAware is giving away free enterprise accounts to anyone who does.
Listening in on ADS-B transponders is something Raspberry Pis have been doing for a while, but doing anything useful with the altitude, speed, heading, and registry numbers of various planes flying overhead is pretty much FlightAware’s only reason for existing, and the reason they’ve developed an easy to use software package for the Pi.
Setting everything up requires getting dump1090 running on the Pi, the only hardware required being an RTL-SDR USB TV tuner, a GPS module, and an antenna for 1090 MHz. From there, just send all the data to FlightAware and you get a free enterprise account with them. Not a bad deal for the aviation nerds out there.
Home Made Segway Makes use of Balanduino
Impressive Homemade Segway Is The Real Deal
[Kristian] just put the finishing touches on his full size Segway built from scratch.
Back in 2012, he made a small balancing robot using a gyroscopic sensor and a PID controller — you can see the original post here. The cool thing is, he’s basically just scaled up his original project to create this full-size Segway!
It uses two 500W 24V DC motors (MY1929Z2) on an aluminum check plate frame, with the rest of the structure made from steel plumbing and fittings. What we really like is the steering linkage; similar to a real Segway, you pull the handle in the direction you want to turn. He’s accomplished this by putting another length of pipe parallel to the wheels which is connected by an elbow fitting to the handle bar. It’s supported by two pillow block bearings, and in the back is a fixed potentiometer — when you lean the handle bars one way, the pipe rotates, spinning the potentiometer. To make it return to neutral, he’s added springs on either side.
There’s an impressive build log to go along with it, and a great demonstration video after the break.
Continue reading “Impressive Homemade Segway Is The Real Deal” →
50 Semifinalists Selected For Next Stage Of The Hackaday Prize
thp-semifinalists
Who cares about Open Design and building the next generation of Connected Devices? It turns out a lot of people do!
The Hackaday Prize put out the call for Open, Connected design ideas and around 800 projects were posted over the last few months to answer that call. The cutoff for documenting your concept and making entry to the contest was just before midnight last Wednesday. Since then our crew has been going through the entries to select 50 to move on as Semifinalists. Here’s who made the cut:
Continue reading “50 Semifinalists Selected For Next Stage Of The Hackaday Prize” →
Homemade Hot Water Shower Might Shock You
DIY Hot Water Shower
[Stephen] doesn’t have the luxury of readily available hot water in his apartment, and since he’s just renting he didn’t want to buy one of those instant powered units, so he decided to go ahead and build his own!
He’s using a submersible 1000W immersion heater in a 2.5 gallon water container which has been mounted high up in his bathroom to let gravity do the work for actual shower. It’s not quite an instant shower unit as the water needs to heat up like a kettle before being used — this takes about 4 minutes to hit the optimum temperature.
The current shower head installed drains the tank in about 2.5 minutes, which might not seem like much time for a shower, but let’s be honest — we could all probably cut back our shower time and save some water for the environment! Something one of our Hack a Day Prize entries is hoping to solve through music!
Continue reading “Homemade Hot Water Shower Might Shock You” →
Chromecast Is Root
Image from [psouza4] on the xda-developers forum
Chromecast is as close as you’re going to get to a perfect device – plug it in the back of your TV, and instantly you have Netflix, Hulu, Pandora, and a web browser on the largest display in your house. It’s a much simpler device than a Raspi running XBMC, and we’ve already seen a few Chromecast hacks that stream videos from a phone and rickroll everyone around you.
Now the Chromecast has been rooted, allowing anyone to change the DNS settings (Netflix and Hulu users that want to watch content not available in their country rejoice), and loading custom apps for the Chromecast.
The process of rooting the Chromecast should be fairly simple for the regular readers of Hackaday. It requires a Teensy 2 or 2++ dev board, a USB OTG cable, and a USB flash drive. Plug the Teensy into the Chromecast and wait a minute. Remove the Teensy, plug in the USB flash drive, and wait several more minutes. Success is you, and your Chromecast is now rooted.
Member of Team-Eureka [riptidewave93] has put up a demo video of rooting a new in box Chromecast in just a few minutes. You can check that out below.
Continue reading “Chromecast Is Root” →
Ask Hackaday: Can Paper USB Business Cards Exist?
swivel business card
The swivelCard Kickstarter campaign recently received a lot of press coverage and makes some impressive claims as their goal is the development of USB and NFC business cards at a $3 unit price. While most USB-enabled business cards we featured on Hackaday were made of standard FR4, this particular card is made of paper as the project description states the team patented
a system for turning regular paper into a USB drive.
As you can guess this piqued our interest, as all paper based technologies we had seen until now mostly consisted of either printed PCBs or paper batteries. ‘Printing a USB drive on regular paper’ (as the video says) would therefore involve printing functional USB and NFC controllers.
Luckily enough a quick Google search for the patents shown in one of the pictures (patent1, patent2) taught us that a storage circuitry is embedded under the printed USB pads, which may imply that the team had an Application-Specific Integrated Circuit (ASIC) designed or that they simply found one they could use for their own purposes. From the video we learn that ‘each card has a unique ID and can individually be programmed’ (the card, not the UID) and that it can be setup to open any webpage URL. The latter can even be modified after the card has been handed out, hinting that the final recipient would go to a ‘www.swivelcard.com/XXXX” type of address. We therefore got confused by
Imagine giving your business card with pictures, videos, presentations, and websites for the recipient to interact with!
paragraph that the project description contains.
This leads us to one key question we have: what kind of USB drive can make a given user visit a particular website, given that he may have Linux, Windows, Mac or any other OS? They all have similar USB enumeration processes and different key strokes to launch a browser… our wild guess is that it may be detected as storage with a single html file in it. Unfortunately for us the USB detection process is not included in the video.
Our final question: Is it possible to embed both USB and NFC controllers in a thin piece of paper without worrying about broken ICs (see picture above)? NFC enabled passports have obviously been around for a long time but we couldn’t find the same for USB drives.
Possible or not, we would definitely love having one in our hands!
Edit: One of our kind readers pointed out that this campaign actually is a re-launch of a failed indiegogo one which provides more details about the technology and confirms our assumptions.
