Arduino-based LED Wedding Lights
Light (1 of 3)Light (2 of 3)
[Rob] created these amazing Bluetooth controlled LED lights for his daughter’s wedding adding a colorful ambient glow to the ceremony. Each item held a Neopixel ring and an Arduino microprocessor with a wireless module that could be individually addressed over a ‘mini-network.’ The main master station would receive commands from a Windows Phone. Usually we see Arduino-based projects being run with Android apps, so it’s nice to see that Microsoft is still present in the maker community.
The enclosures and translucent vases that sit atop the devices were 3D printed. All eight of the matrimonial units synchronized with each other, and the colors could be changed by sliding the settings bar on the app.  [Rob] says that it was a lot of fun to build, and jokingly stated that it kept him “out of all the less important aspects of the ceremony. (food choice, decor, venue, who to marry etc etc).” The outcome was a beautiful arrangement of tabletop lighting for the wedding. A demo of [Rob]’s setup can be seen in the video below.
Continue reading “Arduino-based LED Wedding Lights”
Baby’s Room Gets A Palace With This CNC Castle Decoration
castle decoration
[Vegard] and his wife were expecting a baby girl, and decided to build a castle for their new daughter. As a prototyping geek with his own CNC machine in his apartment, he decided to take to Google Sketchup to design this well-crafted castle decoration for his daughter’s room.
The first challenge was figuring out what the castle would look like. [Vegard] had never been to Disney Land or World, and so had never actually seen any of the fairy-tale castles in real life. After experimenting with some paper versions, he settled on a design which incorporates multiple layers and can house lights within them.
The next step was to cut the final version on the CNC machine, then sand and paint the parts. After figuring out a way to mount the castle to the wall, some LEDs were added for effect, driven by an Arduino. The final version looks pretty good!
Hacking your kids’ room is great fun, and you get to keep making new stuff to remain age appropriate. We bet [Vegard] can’t wait until she’s old enough to enjoy a marble-run that wraps the entire room. In the mean time he can work on a classic robot stroller.
Hackaday Links: August 30, 2014
hackaday-links-chain
Adafruit did another Circuit Playground, this time concerning frequency. If you’re reading this, no, it’s probably not for you, which is great because it’s not meant to be. If you have some kids, though, it’s great. Not-muppet robots and oscilloscopes. Just great.
The Hack42 space in Arnhem, Neterhlands recently got an offer: clean out a basement filled with old computer equipment, and it’s yours. Everything in the haul had to fit through an 80cm square door, and there are some very heavy, very rare pieces of equipment here. It’ll be a great (and massive) addition to their museum. There’s a few pics from the cleanout here and here.
[Mike] has been working on a project to convert gerber files into SVGs and it’s great.
[Carl] did a roundup of all the currently available software defined radios available. It’s more than just the RTL-SDR, HackRF, and BladeRF, and there’s also a list of modifications and ones targeted explicitly to the ham crowd.
This is a Facebook video, but it is pretty cool. It’s a DIY well pump made in Mexico. A few rubber disks made out of an old inner tube, a bit of PVC pipe, and a string is all you need to bring water to ground level.
What can you do with a cellphone equipped with a thermal imaging camera? Steal PIN codes, of course. Cue the rest of the blogosphere sensationalizing this to kingdom come. Oh, what’s that? Only Gizmodo took the bait?
About a year ago, we saw a pretty cool board made by [Derek] to listen in on the CAN bus in his Mazda 3. Now it’s a Kickstarter, and a pretty good one at that.
Your connectors will never be this cool. This is a teardown of a mind bogglingly expensive cable assembly, and this thing is amazing. Modular connectors, machined copper shields, machined plastic stress relief, and entire PCBs dedicated to two caps. Does anyone know what this mated to and what the list price was?
Flying A Drone With An Oculus Rift
Controlling autonomous vehicles remotely with the use of virtual reality headsets seems like an obvious next step. Already, a few UAV companies have begun experimenting with these types of ideas by integrating Oculus Rift developer kits into their hovering quadcopters and drones. Parrot released a video on their blog showing that they developed a head-tracking system for their Bebop Drone in an effort to bring FPV flights to fruition. It looks like a lot of fun and we want to try one of these out asap!
As for technical specifications, they can be found in the YouTube description of the video embedded below. A quick glance showed that the operating system is based on Android and uses WiFi to connect the handheld tablet to the autonomous vehicle floating above. The range is a whopping 2km, giving plenty of freedom to explore. Moving one’s head swivels the attached camera giving a more immersive flying experience.
This isn’t the first example of FPV drones that we have seen. Previously, we covered an Oculus Rift + Head Tracking setup and another similar integration with a Black Armor Drone. We are bound to see virtual reality equipment used to control drones more and more as developers get their hands on cutting edge hardware like the Oculus developer kit 2 hardware which is currently shipping.
Continue reading “Flying A Drone With An Oculus Rift “
A Remote Controlled, Fully Functional, Steam Powered Tank
Steam Powered Tank for the 21st Century
Steam power anything these days is pretty cool, but rarely have we ever seen such a complex build as this steam powered, remote controlled 1/16th scale tank.
[Ian] is an electronics design engineer whose hobbies include messing around with steam power. The Steam Turret Tank is based on a 1/16th scale Tamiya King Tiger die-cast model tank. It features a 3.5″ diameter marine boiler from MaccSteam, which is a fully equipped miniature version of a real boiler, complete with pressure gauges, safety valves, and a ceramic burner. It can produce pressures of up to 70PSI (max 120PSI), but for this project, [Ian] is limiting it to around 30PSI.
A small 2″ diameter fuel tank contains a propane mixture to fuel the boiler. Two Regner 40451 Piccolo steam engines make up the drive train, with mechanical linkages controlled by servos to engage the various features. The tank can go forward, backward, spin in place, and the turret can both rotate and adjust trajectory. It also has controllable headlights, and can even “fire” the turret.
Continue reading “A Remote Controlled, Fully Functional, Steam Powered Tank”
Green Lights Forever
Green Light Your Commute With America’s Unsecured Traffic Lights
Remember that episode of Leverage (season 5, episode 3), where Alec uses Marvin to wirelessly change all the street lights green so they can catch up to an SUV? And you scoffed and said “that’s so not real!”… well actually they got it right. A new study out of the University of Michigan (PDF warning), shows just how easy it is to make your morning commute green lights all the way.
The study points out that a large portion of traffic lights in the United States communicate with each other wirelessly over the 900Mhz and 5.8Ghz ISM band with absolutely no encryption. In order to connect to the 5.8Ghz traffic signals, you simply need the SSID (which is set to broadcast) and the proper protocol. In the study the researchers used a wireless card that is not available to the public, but they do point out that with a bit of social engineering you could probably get one. Another route is the HackRF SDR, which could be used to both sniff and transmit the required protocol. Once connected to the network you will need the default username and password, which can be found on the traffic light manufacturer’s website. To gain access to the 900Mhz networks you need all of the above and a 16-bit slave ID. This can be brute forced, and as the study shows, no ID was greater than 100. Now you have full access, not to just one traffic signal, but EVERY signal connected to the network.
Once on the network you have two options. The completely open debug port in the VxWorks OS which allows you to read-modify-write any memory register. Or by sending a(n) UDP packet where the last byte encodes the button pressed on the controller’s keypad. Using the remote keypad you can freeze the current intersection state, modify the signal timing, or change the state of any light. However the hardware Malfunction Management Unit (MMU) will still detect any illegal states (conflicting green or yellow lights), and take over with the familiar 4-way red flashing. Since a technician will have to come out and manually reset the traffic signal to recover from an illegal state, you could turn every intersection on the network into a 4-way stop.
So the next time you stop at a red light, and it seems to take forever to change, keep an eye out for the hacker who just green lit their commute.
Thanks for the tip [Matt]
THP Semifinalist: FNIR Brain Imager
565281406845688681 The current research tool du jour in the field of neuroscience and psychology is the fMRI, or functional magnetic resonance imaging. It’s basically the same as the MRI machine found in any well equipped hospital, but with a key difference: it can detect very small variances in the blood oxygen levels, and thus areas of activity in the brain. Why is this important? For researchers, finding out what area of the brain is active in response to certain stimuli is a ticket to Tenure Town with stops at Publicationton and Grantville.
fMRI labs are expensive, and [Jeremy]’s submission to The Hackaday Prize is aiming to do the same thing much more cheaply, and in a way that will vastly increase the amount of research being done with this technique. How is he doing this? Using the same technology used in high-tech vein finders: infrared light.
[Jeremy]’s idea is much the same as a photoplethysmograph, better known as a pulse oximeter. Instead of relatively common LEDs, [Jeremy] is using near infrared LEDs, guided by a few papers from Cornell and Drexel that demonstrate this technique can be used to see blood oxygen concentrations in the brain.
Being based on light, this device does not penetrate deeply into the brain. For many use cases, this is fine: the motor cortex is right next to your skull, stretching from ear to ear, vision is taken care of at the back of your head, and memories are right up against your forehead. Being able to scan these areas noninvasively with a device you can wear has incredible applications from having amputees control prosthetics to controlling video game characters by just thinking about it.
[Jeremy]’s device is small, about the size of a cellphone, and uses an array of LEDs and photodiodes to assemble an image of what’s going on inside someone’s head. The image will be somewhat crude, have low resolution, and will not cover the entire brain like an fMRI can. It also doesn’t cost millions of dollars, making this one of the most scientifically disruptive entries we have for The Hackaday Prize.
You can check out [Jeremy]’s intro video below.
SpaceWrencherThe project featured in this post is a semifinalist in The Hackaday Prize.
Continue reading “THP Semifinalist: FNIR Brain Imager”
