Hackaday Prize Entry: Online Bone Marrow Cytometry Aid
Simple blood tests can lead a doctor toward a diagnosis of blood cancers, like leukemia, lymphoma and myeloma, but to really see what’s going on, he or she needs to go to the source of the problem: the bone marrow. Examining maturing blood cells from the marrow with a microscope is an important step in staging the disease and developing a plan for treatment, but it’s a tedious and error-prone process that requires a doctor to classify and tally a dozen or so different cells based on their size, shape and features. Automated systems like flow cytometry and image analysis software can help, but in an austere environment, a doctor might not have access to these. Luckily, there’s now an on-line app to assist with bone marrow cytometry.
Thanks to [Eduardo Zola], a doctor can concentrate on classifying cells without looking up from the microscope, and without dictating to an assistant. Keys are assigned to the different cell morphologies, and a running total of each cell type is kept. With practice, the doctor should be able to master the keying for the various cells; we suspect the generation of physicians that grew up with the WASD keying common in PC-based gaming might have a significant advantage over the older docs when it comes to learning such an app.
[Eduardo]’s app seems like a simple way to improve on an important medical procedure, and an enabling technology where access to modern instrumentation is limited. To that end, one area for improvement might be a standalone app that can run on a laptop without internet access, or perhaps even a version that runs on a smart phone. But even as it is, it’s a great entry for the 2015 Hackaday Prize.
The 2015 Hackaday Prize is sponsored by:
Puzzle Box
Puzzle Box Is Rigged To Blow
[Sande24] needed a gift for his father’s birthday. He decided that rather than simply give his father the gifts, he would present his father with a unique challenge. The gifts are locked inside of a multi-stage puzzle box. This isn’t your average puzzle box though. This one is rigged to blow.
The puzzle box was designed to test his father’s reflexes, mind, and luck. The finished product looks sort of like a wooden crate made from particle board. The box contains three levels, each with its own gift and its own task to be completed.
With the lid opened, the first compartment and puzzle is revealed. Inside of the compartment were a new pair of gloves, meant to protect the father’s hands when working on the puzzles. The first puzzle is built into a sheet of wood with several custom-made levers. The levers must be moved into position in order to remove the wooden sheet and reveal the next level.
The first lever triggers a home-made detonator that eventually lights a series of fireworks placed around the box. You need to solve the puzzle box fast enough to prevent the fireworks from destroying the gifts that lay inside. [Sande24] was unable to legally purchase fuses where he lived, so he had to make his own.
The second level held a gas mask, also meant to protect the father from the booby traps of this mysterious box. This level, also made from a sheet of wood, has nine squares drawn on it. Each square is labeled with a different number which goes into solving a mathematical function (x^5-25x^4+233x^3-995x^2+1866x-1080 = 0). The solution to the function would reveal the safe path to be used to cut the wooden platform in half. Unfortunately [Sande24’s] father cut the wrong squares and released a huge amount of vinegar into the box. Oops.
The bottom level contained the final puzzle and the locked treasure compartment locked with an ordinary padlock. To find the key, another puzzle had to be solved based on a series of wooden levers labeled with different shapes. The shapes provided clues to the order in which the levers should be pulled. Once the levers were moved into position, two compartments were unlocked. One of them contained the key to the treasure box. The other contained another booby trap which would set off more fireworks, destroying the final gift of four cans of Kuld beer. That’s a lot of work to get a a few cans of frothy beverage!
[Thanks Ellery]
This Little Amiga Still Runs School District’s HVAC
It’s the rare tech worker that manages a decade in any one job these days – employee loyalty is just so 1980s. But when you started your career in that fabled age, some of the cultural values might have rubbed off on you. Apparently that’s the case for an Amiga 2000 that’s been on the job since the late ’80s, keeping the heat and AC running at Grand Rapids Public Schools (YouTube video link.)
The local news story is predictably short on details and pushes the editorial edge into breathless indignation that taxpayer dollars have somehow been misspent. We just don’t see it that way. “If it ain’t broke, don’t fix it,” is somewhat anathema to the hacker ethos. After all, there’s no better time to “fix” something than when it’s working properly and you can tell if you’ve done something wrong. But keeping an important system running with duct tape and wire ties is also part of the hacker way, so we applaud [Tim Hopkins] and his colleagues at the GRPS Facilities and Operations Department for their efforts to protect the public purse. And a round of applause is also due not only to the Amiga design team, who produced a machine that can run for nearly three decades, but also to Johnson Controls, whose equipment – apparently a wide area radio modem linking the HVAC systems in the district’s buildings – is being run by The Little Amiga That Could. Sounds like they built stuff to last way back when.
So when this machine is finally retired, here’s hoping they give it a good sendoff. Perhaps we’ll see it with some other Amigas at some future Vintage Computer Festival. Or maybe it’ll be one of those active retirees and start a career in the music industry.
[Thanks Thinkerer!]
Another IoT Platform In The (Blue)Mix
Many major companies (Intel, Oracle, Atmel, and IBM, for example) are competing to be the standard interconnect fabric for the Internet of Things. As a developer, it is hard to cut through the marketing hype and decide which platform is the best for you and your application. Luckily, there’s a plethora of projects on the web that showcase these frameworks. These project sites are an easy way to evaluate the strengths and weaknesses of IoT frameworks in practical applications without having to develop prototypes yourself.
[diyhacking], for example, posted a demo of using IBM’s Bluemix along with a Raspberry Pi, to do some simple home automation tasks. The project hardware is modest, using a PIR motion sensor and a relay to control an AC load. However, that’s good because it lets you focus on the Bluemix tools. The example client and server software is less than 200 lines of Python.
Bluemix looks like it has good integration with the Raspberry Pi and features a simulator so you can work without real hardware for development. Bluemix does offer a free plan (with limits), but the fee options may be a turn off to some IoT hackers.
Continue reading “Another IoT Platform In The (Blue)Mix”
Caption CERN Contest – What’s In The Box?
Week 24 of the Caption CERN Contest was one for the books. There were so many good captions that we had a hard time picking a winner! Thank you to everyone who wrote up a caption and entered the contest. We still don’t know quite what this device was. Our best guess is a coil from a beam line. Some creative positioning and camera focus sure turned it into a conversation piece though!
The Funnies:
  • “I am the Face of Boe. Has anyone seen the Doctor?.” – [jonsmirl]
  • “CERN’s brief attempt into the consumer “Pro” audio market. They lost out to the competitions because they didn’t use unidirectional oxygen free copper wires that are blessed by the Tibetan monks. They might be the expert with super conductor magnets, but one hard lesson they have learnt is that you can’t spell consumer without the “con” part.” – [K.C. Lee]
  • “Go ahead pick up the operating tool!! For your first task remove the patient’s tooth for 10 points. But beware!!! there’s the 10,000K volt charge if you touch the sides!! Enjoy!!!” – [EngineerAfterLunchTime]
This week’s winner is [surubarescu] with “Prototype of the sextuple face electric razor was a complete technical success, but it never went into full production due to some raised (then lost) eyebrows.” Enjoy your new Teensy 3.1 from The Hackaday Store, [surubarescu]!
Week 25
cern-25-smWe’re not kidding when we say CERN scientists and engineers really get into their work. Check out this CERN scientist looking down at his… uh, experiment. We’re not sure exactly what this device is. There is a sealed chamber, but is it a vacuum, or some sort of specialized atmosphere for the research this scientist is working on? Either way, he seems very interested in whatever is happening inside this box!
So what’s happening here? High energy physics, or some new coffee maker? You tell us!
This week’s prize is once again a Teensy 3.1 from The Hackaday Store. Add your humorous caption as a comment to this project log. Make sure you’re commenting on the contest log, not on the contest itself.
As always, if you actually have information about the image or the people in it, let CERN know on the original image discussion page.
Dropping By The MIT Electronics Research Society
We’re in Boston this week and my first stop was at MITERS last night. This is the MIT Electronics Research Society, which started as a way to provide free access to computers for all students. Since those humble beginnings the organization has grown to include a slew of fabrication and test hardware, as well as a vibrant community that makes the group a great place to hang out.
Walking into the building you’re greeted with double doors strewn with interesting electronics and many examples of fabrication in the form of the word MITERS. The group, which is pushing 60-years of existence, feels immediately like a hackerspace where creativity and anarchy duke it out in a wild dance of experimentation. On this particular Wednesday evening we encountered a room of about 10 people working feverishly to fabricate electric racers for the PRS racing circuit in Detroit this Saturday.
Like a hackerspace, MITERS is completely member (read: student) run. There is a board that helps keep things on the rails. There is no membership fee; funding for the organization is sourced from Swapfest, a weekly flea market during the summer.
There is a strong slant toward machine shop at this hackerspace. In addition to a respectable Bridgeport CNC Mill, the machine tools and hand tools provide for almost all your fabrication needs.
What can be built in this space? How about a unibalancer? This is a single-wheeled, human-ridable vehicle that has a 7-mile cruise radius between charges. For me the most interesting feature is the deadman’s switch. You know those black rubber strips on public buses that you press for the next stop? This unibalancer has one that you need to stand on to make it go.
The hackers at MITERS excel when it comes to electric vehicles and this time of year that means the Power (Wheels) Racing Series. There are restrictions on size, and power output so the teams squeeze every bit that they can. For me, the most interesting build is based off of a pair of Ryobi electric chainsaws. The 40V batteries for these are themselves quite formidable but not used at all in the build. The team has reverse-engineered the driver circuits and written their own firmware for the STM8 microcontrollers on the boards. The chainsaws use chains to drive the two rear wheels. The entire system is monitored with XBEE-based wireless data which is displayed on a tablet.
This isn’t the only PRS build. The MITERS plan to take three different vehicles with them this weekend. The one they can’t bring is the huge electric shopping cart (with mandatory wheelie bar) which hangs from the ceiling of the space.
In addition to the formidable fabrication projects, there are a multitude of electronic projects to be seen. There is a musical tesla coil which is the best I’ve ever heard. It could easily be mistaken as a proper speaker. If you need more bass there’s a massive ceiling-mounted sub-woofer for that. And if you want a more formidable tesla coil, the parts are there.
Look hard enough and you’ll even find battle robots. This one had diamond plate that spins with a variety of nasty accoutrements intended for maximum damage of its foe. On the underside you’ll see a brushless motor used the opposite of how you might think. The shaft is attached to the locomotion frame of the bot. The underside of the spinning diamond plate has a ring of antistatic mat against which this brushless motor body spins.
Thanks to the MITERS for welcoming us in. It was a blast seeing all of the projects they’re working on!
Meetup at Artisan’s Asylum Tonight
If you’re in the Boston area, head on over to Artisan’s Asylum tonight starting at 6. They were gracious enough to open their doors for a Hackaday Meetup. Bring some hardware to show off if you can, if you can’t that’s fine as well. We’ll have a few lightning talks, some social time, and maybe an afterbar!
To wrap things up, we have covered a few projects from MITERS already, like this Power Wheels Racing build, and an electric go kart done the right way. Now that we’ve met them in person we’ll be on the lookout for a lot more awesome hacks from them.
[Thanks John for suggesting we stop by!]
[Federico Musto] Of Arduino SRL Discusses Arduino Legal Situation
Recently we had the opportunity to sit down and interview Arduino SRL’s CEO, [Federico Musto], over a nice dinner. His company is one half of the Arduino vs Arduino debacle which has pitted Arduino.cc against Arduino.org in a battle over the trademark on “Arduino”.
Given the tremendous amount of press coverage of [Massimo Banzi] and the Arduino LLC side of the story (Arduino.cc), we were very interested in hearing how the whole situation looks where [Frederico Musto] sit (Arduino.org). In the end, we came away with what we feel is a more balanced and complete picture of the situation, as well as interesting news about future products from the Arduino SRL camp. [Musto’s] take on the legal proceedings, both past and present, is nothing short of fascinating.
Continue reading “[Federico Musto] Of Arduino SRL Discusses Arduino Legal Situation”
