Making PCB Strip Filter Design Easy To Understand
We’ve always been fascinated by things that perform complex electronic functions merely by virtue of their shapes. Waveguides come to mind, but so do active elements like filters made from nothing but PCB traces, which is the subject of this interesting video by [FesZ].
Of course, it’s not quite that simple. A PCB is more than just copper, of course, and the properties of the substrate have to be taken into account when designing these elements. To demonstrate this, [FesZ] used an online tool to design a bandpass filter for ADS-B signals. He designed two filters, one using standard FR4 substrate and the other using the more exotic PTFE.
He put both filters to the test, first on the spectrum analyzer. The center frequencies were a bit off, but he took care of that by shortening the traces slightly with a knife. The thing that really stood out to us was the difference in insertion loss between the two substrates, with the PTFE being much less lossy. The PTFE filter was also much more selective, with a tighter pass band than the FR4. PTFE was also much more thermostable than FR4, which had a larger shift in center frequency and increased loss after heating than the PTFE. [FesZ] also did a more real-world test and found that both filters did a good job damping down RF signals across the spectrum, even the tricky and pervasive FM broadcast signals that bedevil ADS-B experimenters.
Although we would have liked a better explanation of design details such as via stitching and trace finish selection, we always enjoy these lessons by [FesZ]. He has a knack for explaining abstract concepts through concrete examples; anyone who can make coax stubs and cavity filters understandable has our seal of approval.
Continue reading “Making PCB Strip Filter Design Easy To Understand”
Raspberry Pi OS’s Wayland Transition Completed With Switch To Labwc
With the latest release of Raspberry Pi OS (formerly Raspbian) the end of the X Window System has become reality, completing a years-long transition period. Although this change between display servers is not something which should be readily apparent to the casual user, the change from the client-server-based X11 protocol to the monolithic Wayland protocol has a number of implications. A major change is that with the display server and window manager no longer being separate units, features such as network transparency (e.g. remote X-sessions) are no longer a native feature, but have to be implemented separately by e.g. the Wayland compositor. Continue reading “Raspberry Pi OS’s Wayland Transition Completed With Switch To Labwc”
Interfacing Old Burglar Alarm Sensors Into HomeAssistant
The annoying thing about commercial smart home gear is its lack of interoperability. HomeAssistant is very flexible though, and it’s easy to use all kinds of gear—even stuff you bodge together yourself. [Jeff Sandberg] demonstrates that ably with his project to use ancient 1990s burglar alarm sensors in his modern smarthome setup.
The sensors in question are from an old GM Interlogix security system. The sensors themselves sit on doors or windows. They use magnets and a reed switch to sense if the door or window is opened. If so, they send out a radio message saying as much. All [Jeff] had to do was catch those messages and translate them for HomeAssistant.
To listen in on the sensors, [Jeff] employed a Nooelec NESDR—a software defined radio that could pick up the 319.5 MHz signals. The NESDR runs a tool called RTL_433, which can decode the sensor signals, and spit out MQTT messages to interface with HomeAssistant.
Much of the hard work was done already for [Jeff]—he just had to lace together the components. This is just a testament to the hard work by people in the HomeAssistant and SDR communities for figuring all this out and putting the tools online.
We’ve seen some neat HomeAssistant builds before, like this neat home control terminal. If you’re cooking up your own smarthome hacks, don’t hesitate to let us know!
Turning A Quansheng Handheld Into A Neat Desktop Transceiver
The Quansheng UV-K5 is a popular handheld radio. It’s useful out of the box, but also cherished for its modification potential. [OM0ET] purchased one of these capable VHF/UHF radios, but got to hacking—as he wanted to use it as a desktop radio instead!
This might just sound like a simple reshell, but there was actually a bit of extra work involved. Most notably, the Quansheng is designed to be tuned solely by using the keypad. For desktop use, though, that’s actually kind of a pain. Thus, to make life easier, [OM0ET] decided to whip up a little encoder control to handle tuning and other control tasks using an ESP32. This was achieved with help from one [OM0WT] and files for that are on Github. Other tasks involved finding a way to make the keypad work in a new housing, and how to adapt things like the audio and data module and the speaker to their new homes.
Despite the original handheld being much smaller than the case used here, you’d be surprised how tight everything fits in the case. Still, the finished result looks great. We’ve seen some other adaptable and upgradable ham radio gear before, too. Sometimes custom is the way to go! Video after the break.
Continue reading “Turning A Quansheng Handheld Into A Neat Desktop Transceiver”
The Woodworker’s Cyberdeck
Computers were supposed to be personal, customizable, and cool. At times, in this cold modern world, we forget that. However, the cyberdeck scene is chock full of people building creative, original computers that suit their own tastes, aesthetics, and needs. [DIY Tinkerer] is one such individual, and he made the most of his woodworking skills when it came time to build his own cyberdeck!
The technological basics are along the lines of what we’re used to in this field. The build is based around a Raspberry Pi 4, with [DIY Tinkerer] selecting an 8 GB model for his needs. It’s paired with a 9000 mAh onboard battery, and there’s a power jack on the front to let the thing run on anything from 5 to 20 volts DC. For ease of use, there’s a multi-memory card reader and several USB 3 ports available.
The rest of the video focuses on the woodworking side of things. [DIY Tinkerer] shows us how he managed to build a new housing out of a rugged plastic case that would also be practical to use. The final product is both functional and attractive, and comes with an oscilloscope built in to boot! It came a long way from his earlier build, too.
We’ve seen a great load of cyberdeck builds over the years.
Continue reading “The Woodworker’s Cyberdeck”
Word Of The Day Calendar Is Great Use Of E-Paper
If you’re trying to learn a new language, there are always a lot of words to learn. A word-of-the-day calendar can help, and they’re often readily available off the shelf. Or, you can grab some hardware and build your own, as [daedal-tech] did!
The project was built as a gift to help [daedal-tech]’s partner with their efforts to pick up French. Thus, a Raspberry Pi Zero 2W was employed and paired with a small Waveshare e-Paper display. These were stuffed inside a fancy light switch plate from Hobby Lobby and a small stand, the pair of which act as a pretty nice little frame for the build. The Pi runs a small Python script which employs the BeautifulSoup4 library and the Python Image library. Basically, the script grabs French words and spits them out on the display with a small description such that one might understand their meaning.
It’s a simple build, but one that has some real utility and is fun to boot. We might see more word clocks than calendars around these parts, but we love both all the same!
FreeBSD At 30: The History And Future Of The Most Popular BSD-Based OS
Probably not too many people around the world celebrated November 1st, 2023, but on this momentous date FreeBSD celebrated its 30th birthday. As the first original fork of the first complete and open source Unix operating system (386BSD) it continues the legacy that the Berkeley Software Distribution (BSD) began in 1978 until its final release in 1995. The related NetBSD project saw its beginnings somewhat later after this as well, also forking from 386BSD. NetBSD saw its first release a few months before FreeBSD’s initial release, but has always followed a different path towards maximum portability unlike the more generic nature of FreeBSD which – per the FAQ – seeks to specialize on a limited number of platforms, while providing the widest range of features on these platforms.
This means that FreeBSD is equally suitable for servers and workstations as for desktops and embedded applications, but each platform gets its own support tier level, with the upcoming version 15.x release only providing first tier support for x86_64 and AArch64 (ARMv8). That said, if you happen to be a billion-dollar company like Sony, you are more than welcome to provide your own FreeBSD support. Sony’s Playstation 3, Playstation 4 and Playstation 5 game consoles namely all run FreeBSD, along with a range of popular networking and NAS platforms from other big names. Clearly, it’s hard to argue with FreeBSD’s popularity.
Despite this, you rarely hear people mention that they are running FreeBSD, unlike Linux, so one might wonder whether there is anything keeping FreeBSD from stretching its digital legs on people’s daily driver desktop systems?
Continue reading “FreeBSD At 30: The History And Future Of The Most Popular BSD-Based OS”
