A diagram with one Tag and two Base Stations.
Using Ultra-Wideband For 3D Location And Tracking
Interested in playing with ultra-wideband (UWB)? [Jaryd] recently put together a fairly comprehensive getting started guide featuring the AI Thinker BU03 that looks like a great place to start. These modules can be used to determine distance between two of them to an accuracy in the order of 10 centimeters, and they can do so in any orientation and with obstacles in the line of sight. It is possible to create a network of these UWB modules to get multiple distance measurements at once and enable real-time 3D tracking for your project.
[Jaryd] gathers up nine UWB modules and uses a Raspberry Pi Pico for command and control purposes. He explains how to nominate the “tag” (the device being tracked) and the “base stations” (which help in locating the tag). He reports having success at distances of up to about 10 meters and in favorable circumstances all the way up to as much as 30 meters.
If you don’t know anything about UWB and would like a primer on the technology be sure to check out What Is Ultra Wideband?
Lisp In 99 Lines Of C With TinyLisp
As one of the oldest programming languages still in common use today, and essential for the first wave of Artificial Intelligence research during the 1950s and 60s, Lisp is often the focus of interpreters that can run on very low-powered systems. Such is the case with [Robert van Engelen]’s TinyLisp, which only takes 99 lines of C code and happily runs on the Z80-based Sharp PC-G850V(S) pocket computer with its 2.3 kB of internal RAM and native C support.
The full details on how TinyLisp was implemented and how to write it yourself can be found in the detailed article that’s part of the GitHub project. It supports static scoping, double-precision floating point and features 21 Lisp primitives along with a garbage collector. Two versions for the Sharp PC-G850 (using BCD (i.e. NaN) boxing) are provided, along with a number of generic implementations, using either double or single precision floating point types. A heavily commented version is probably the version to keep alongside the article while reading.
TinyLisp is – as the name implies – very tiny, and thus more full-featured Lisp implementations are widely available. This includes two versions – linked at the bottom of the Readme – also by [Robert] that use a gargantuan 1,000 lines of C, providing a more advanced garbage collector and dozens more Lisp primitives to handle things like exceptions, file loading, strings and debug features.
A brown plastic circuit board is visible in the middle of the picture, containing an integrated circuit, a resistor, a diode, two capacitors, and some jumper wires going away to the sides.
A Solderless, Soluble Circuit Board
Anyone who’s spent significant amounts of time salvaging old electronics has probably wished there were a way to take apart a circuit board without desoldering it. [Zeyu Yan] et al seem to have had the same thought, and designed circuit boards that can be dissolved and recycled when they become obsolete. Read the details in the research paper. (PDF)
The researchers printed the circuit boards out of water-soluble PVA, with hollow channels in place of interconnects. After printing the boards, they injected a eutectic gallium-indium liquid metal alloy into these channels, populated the boards with components, making sure that their leads were in contact with the liquid alloy, and finally closed off the channels with PVA glue, which also held the components in place. When the board is ready to recycle, they simply dissolve the board and glue in water. The electric components tend to separate easily from the liquid alloy, and both can be recovered and reused. Even the PVA can be reused: the researchers evaporated the solution left after dissolving a board, broke up the remaining PVA, and extruded it as new filament.
Continue reading “A Solderless, Soluble Circuit Board”
Roll Your Own SSB Receiver
[Paul Maine] was experimenting with GNU Radio and an RTL-SDR dongle. He created an SSB receiver and, lucky for us, he documented it all in a video you can see below. He walks through how to generate SSB, too. If videos aren’t your thing, you can go back to the blog post from [Gary Schafer] that inspired him to make the video, which is also a wealth of information.
There is a little math — you almost can’t avoid it when talking about this topic. But [Paul] does a good job of explaining it all as painlessly as possible. The intuitive part is simple: An AM signal has most of its power in the carrier and half of what’s left in a redundant sideband. So if you can strip all those parts out and amplify just one sideband, you get better performance.
Continue reading “Roll Your Own SSB Receiver”
2025 One Hertz Challenge: Atomic Decay Clock Is Accurate But Not Precise
At this point, atomic clocks are old news. They’ve been quietly keeping our world on schedule for decades now, and have been through several iterations with each generation gaining more accuracy. They generally all work under the same physical principle though — a radio signal stimulates a gas at a specific frequency, and the response of the gas is used to tune the frequency. This yields high accuracy and high precision — the spacing between each “tick” of an atomic clock doesn’t vary by much, and the ticks cumulatively track the time with very little drift.
All of this had [alnwlsn] thinking about whether he could make an “atomic” clock that measures actual radioactive decay, rather than relying on the hyperfine transition states of atoms. Frustratingly, most of the radioactive materials that are readily available have pretty long half-lives — on the order of decades or centuries. Trying to quantify small changes in the energy output of such a sample over the course of seconds or minutes would be impossible, so he decided to focus on the byproduct of decay — the particles being emitted.
He used a microcontroller to count clicks from a Geiger-Müller tube, and used the count to calculate elapsed time by multiplying by a calibration factor (the expected number of clicks per second). While this is wildly inaccurate in the short term (he’s actually used the same system to generate random numbers), over time it smooths out and can provide a meaningful reading. After one year of continuous operation, the counter was only off by about 26 minutes, or 4.4 seconds per day. That’s better than most mechanical wristwatches (though a traditional Rubidium atomic clock would be less than six milliseconds off, and NIST’s Strontium clock would be within 6.67×10-11 seconds).
The end result is a probabilistic radiometric timepiece that has style (he even built a clock face with hands, rather than just displaying the time on an LCD). Better yet, it’s got a status page where you can check on on how it’s running. We’ve seen quite a few atomic clocks over the years, but this one is unique and a great entry into the 2025 One Hertz Challenge.
Food Irradiation Is Not As Bad As It Sounds
Radiation is a bad thing that we don’t want to be exposed to, or so the conventional wisdom goes. We’re most familiar with it in the context of industrial risks and the stories of nuclear disasters that threaten entire cities and contaminate local food chains. It’s certainly not something you’d want anywhere near your dinner, right?
You might then be surprised to find that a great deal of research has been conducted into the process of food irradiation. It’s actually intended to ensure food is safer for human consumption, and has become widely used around the world.
Continue reading “Food Irradiation Is Not As Bad As It Sounds”
The VLF Transformation
People have long been interested in very low frequency (VLF) radio signals. But it used to be you pretty much had to build your own receiver which, luckily, wasn’t as hard as building your own VHF or UHF gear. But there is a problem. These low frequencies have a very long wavelength and, thus, need very large antennas to get any reception. [Electronics Unmessed] says he has an answer.
These days, if you want to explore any part of the radio spectrum, you can probably do it easily with a software-defined radio (SDR). But the antenna is the key part that you are probably lacking. A small antenna will not work well at all. While the video covers a fairly common idea: using a loop antenna, his approach to loops is a bit different using a matching transformer, and he backs his thoughts up with modeling and practical results.
Of course, transformers also introduce loss, but — as always — everything is a trade-off. Running hundreds of feet of wire in your yard or even in a loop is not always a possibility. This antenna looks like it provides good performance and it would be simple to duplicate.
Early radio was VLF. Turns out, VLF may provide an unexpected public service in space.
Continue reading “The VLF Transformation”
