Magnetic Hockey Game Uses A 555
We love a good project here at Hackaday, particularly one that makes us want to pick it up and have a go at whatever it does for ourselves. And when we see such a project and find that it contains the One Chip To Rule Them All (otherwise known as the NE555 timer), our collective cup runneth over with joy. So [Andrew Fentem]’s magnetic hockey project certainly pushes all our buttons, as it’s a game superficially similar to an air hockey table in which a magnetic puck is accelerated by a handheld electronic bat.
The bats look extremely high-tech but are in fact surprisingly simple. Each one contains a Hall effect sensor which triggers the 555 which we’d expect is wired as a monostable, this in turn fires a MOSFET which energises an electromagnet for a set period of time. The puck is a magnet, and thus when it is detected by the Hall sensor it is shot away at high speed by the electromagnet. the result is a fast-paced game which has an extra edge over conventional air hockey, and which being honest, we’d love to have a go at. You can see it in the video below the break.
Of course, if your budget doesn’t stretch to not one but two chips in this era of semiconductor shortages, you can always try a conventional table.
Continue reading “Magnetic Hockey Game Uses A 555” →
Bath County Pumped Storage Station (Credit: CHA)
Grid-Level Energy Storage And The Challenge Of Storing Energy Efficiently
Although every electrical grid begins with the production of electricity, there are times when storing this power in some form instead of using it immediately is highly convenient. Today’s battery-powered gadgets are an obvious example of such time-shifting, but energy storage plays a major role on the grid itself, too, whether in electrochemical, mechanical or in some other form.
Utility-level energy storage is essential for not only stabilizing the grid, but also to time-shift excess energy and provide a way to deal with sudden spikes in demand (peak-shaving) plus demand drops by absorbing the excess energy. The health of the grid can essentially be regarded as a function of its alternating current (AC) frequency, with strong deviations potentially leading to a collapse of the grid.
Naturally, such energy storage is not free, and the benefits of adding it to the grid have to be considered against the expense, as well as potential alternatives. With the rapid increase of highly volatile electrical generators on the grid in the form of non-dispatchable variable renewable energy, e.g. wind turbines and PV solar, there has been a push to store more excess power rather than curtailing it, in addition to using energy storage for general grid health.
Continue reading “Grid-Level Energy Storage And The Challenge Of Storing Energy Efficiently” →
Helping The War Effort With 3D Printed Tourniquets
It’s a sad statement on the modern world that even civilians are at risk for severe traumatic injuries in the course of going about their lives. And if something unthinkable happens to you or someone you love, here’s hoping both that the injury can be treated, and that someone is nearby who both knows what to do and is properly equipped to do it.
That’s the thinking behind these 3D printed tourniquets, an unfortunate but necessary response to the ongoing war in Ukraine. To get tourniquets into the hands of those trained to use them, [3DPrintingforUkraine] is working on plans for a printable version of the C-A-T, or combat application tourniquet, a lightweight but strong tourniquet that can be rapidly applied, even by victims themselves. The commercial device consists of molded nylon buckles and hook-and-loop fastener bands, along with a very sturdy plastic handle that serves as a windlass that provides the necessary occlusive force when twisted. The 3D printed version’s parts aren’t as streamlined as the commercial unit’s, but they appear to be strong enough to withstand the considerable forces involved. From the look of their site, STL files and instructions for assembly will be available soon.
To be clear, tourniquets should only be applied by someone properly trained to do so. But having ample tourniquets available where traumatic injuries to the extremities are likely to occur can only improve the odds that one will be available when it’s needed. So hats off to [3DPrintingforUkraine] for making the effort to push this forward.
[Austin Everman] sent us this tip. Thanks!
Build A TPM Module For Your Server
One of the big stories surrounding the announcement of Windows 11 was that it would require support for TPM 2.0, or Trusted Platform Module, to run. This takes the form of an on-board cryptographic processor, which Microsoft claims will help against malware, but which perhaps more importantly for Redmond, can be used to enforce DRM.  Part of the standard involves a hardware module, and [Zane] has built a couple of them for ASrock server motherboards.
The chip in question is the Infineon SLB9965, which with a bit of research was found to map more or less directly to the pins of the TPM socket on the motherboard. The interesting thing here lies in the background research it gives into TPMs, and furthermore the links to other resources dealing with the topic. The chances are that most readers needing a TPM will simply buy one, but all knowledge is useful when it comes to these things.
Our weekly security roundup has been keeping an eye on the use of TPMs for a while, and has even shown us some ways that people have used to bypass the modules.
Fix Every Broken Via To Return This Game To Life
We all know the havoc that water in the wrong place can do to a piece of electronics, and thus we’ve probably all had devices damaged beyond repair. Should [Solderking] have thrown away the water-damaged PCB from a Nintendo Pokemon Ruby cartridge? Of course he should, but when faced with a board on which all vias had succumbed to corrosion he took the less obvious path and repaired them.
Aside from some very fine soldering in the video below the break there’s little unexpected. He removes the parts and tries a spot of reworking, but the reassembled board doesn’t boot. So he removes them again and this time sands it back to copper. There follows a repair of every single vial on the board, sticking fine wires through the holes into a sponge and soldering the top, before turning it over and fixing the forest of wires on the other side. Fixing the ROM results in a rather challenging fitment involving the chip being mounted at an angle and extra wires going to its pads, which demonstrates the value in this story. It’s not one of monetary value but of persevering with some epic rework to achieve a PCB which eventually boots. Of course a replacement board would make more sense. But that’s not the point, is it?
Continue reading “Fix Every Broken Via To Return This Game To Life” →
RC Car Test Tether Takes Car Testing To New Lengths
It’s fascinating to see what happens when a creative hacker is given a set of constraints to work within. [rctestflight] found themselves in a very specific set of circumstances: Free RC cars from sponsors, and no real purpose for them. Instead of just taking them apart to see what made them tick (itself the past time of many a beginning hacker), [rctestflight] decided to let the RC cars disassemble themselves, destructively, on their way to 100,000 (scale) RC Car Miles, tallying up the distance (and the carnage) in the end as you see in the video below the break.
Can you spot the RC car under the mud?
Re-using a jig and test track (his backyard) from another test, [rctestflight] set up solar powered tether that could power any of the vehicles under test. The vehicles were modified as needed to drive along the circular track on a tether, and once stability was achieved, the cars were set on their own to either drive 100,000 scale miles or die trying.
Seeing as how [rctestflight] hales from the Pacific NorthWet of the United States near Seattle, the endurance test turned out to be not just a test of distance. Among the factors evaluated were how well each vehicle could withstand the mud, grime, and yes, even earthworms, that awaited them.
After each vehicle failed beyond the point of a quick fix, they were all torn down. Where each manufacturer cut corners could clearly be seen, and the weaknesses and strengths of each vehicle were pretty interesting. Plus, there’s a pretty great (awful) uh… rendition… of an iconic 80’s song. Twice. And of course the final conclusion: Exactly how many miles did each vehicle go before catastrophic failure? Check the video for results.
Regular readers will know that [rctestflight] is somewhat of a Hackaday regular, with plentiful great hacks such as this drone boat that sails the high seas of Lake Washington.
Continue reading “RC Car Test Tether Takes Car Testing To New Lengths” →
A 3D Printed 35mm Movie Camera
Making a camera can be as easy as taking a cardboard box with a bit of film and a pin hole, but making a more accomplished camera requires some more work. A movie camera has all the engineering challenges as a regular camera with the added complication of a continuous film transport mechanism and shutter. Too much work? Not if you are [Yuta Ikeya], whose 3D printed movie camera uses commonly-available 35 mm film stock rather than the 8 mm or 16 mm film you might expect.
3D printing might not seem to lend itself to the complex mechanism of a movie camera, however with the tech of the 2020s in hand he’s eschewed a complex mechanism in favour of an Arduino and a pair of motors. The camera is hardly petite, but is still within the size to comfortably carry on a shoulder. The film must be loaded into a pair of cassettes, which are pleasingly designed to be reversible, with either able to function as both take-up and dispensing spool.
The resulting images have an extreme wide-screen format and a pleasing artistic feel. Looking at them we’re guessing there may be a light leak or two, but it’s fair to say that they enhance the quality rather than detract from it. Those of us who dabble in movie cameras can be forgiven for feeling rather envious.
We’ve reached out to him asking whether the files might one day be made available, meanwhile you can see it in action in the video below the break.
Continue reading “A 3D Printed 35mm Movie Camera” →
