Web Development In… Pascal?
If you were asked to make an e-commerce website in 2025, what language would you reach for? Show of hands: JavaScript? Go? Pascal? Well, there was at least one taker for that last one: [jns], and he has an hour-long tutorial video showing you how he made it happen.
The site in question is the web store for his personal business, Photronic Arts, so you cannot say [jns] does not have skin in the game. From the front end, this is HTML and could be anything upto and including Shopify under the hood. It’s not, though: it’s a wholly custom backend [jns] put together in FreePascal, using the Lazarus IDE.
There’s a case to be made for Pascal in the modern day, but when we wrote that we weren’t expecting to get tips about web development.  Ironically enough [jns] spends so much time giving the technical details in this video he doesn’t delve that deeply into why he chose FreePascal, especially when it’s clear he’s very familiar with C and C++. In his associated writeup on his Gopher page (link though Floodgap) [jns] simply declares it’s a language he’s quite fond of, which is reason enough of us. The source code is available, though on request, to avoid AI scraping. It’s a sad but understandable response to these modern times.
If you’re not into web development and want to see a deep-dive into how the backend works, this video is worth watching even if you don’t particularly care for Pascal. It’s also worth watching if you do know backend development, and are Pascal-curious. If neither of those things interest you, what about this Pascal Library for Arduino?
Thanks to [jns] for the tip! If you’re doing modern work with questionably-modern tools, we call that a hack and would love to hear from you.
Screenshot of Lazarus IDE on MacOS Ventura
The Case For Pascal, 55 Years On
The first version of Pascal was released by the prolific [Niklaus Wirth] back in 1970. That’s 55 years ago, an eternity in the world of computing. Does anyone still use Pascal in 2025? Quite a few people as it turns out, and [Huw Collingbourne] makes the case why you might want to be one of them in a video embedded below.
In all fairness, when [Huw] says “Pascal” he isn’t isn’t talking about the tiny language [Wirth] wrote back when the Apollo Program was a going concern. He’s talking about Object Pascal, as either Free Pascal or Delphi– which he points out are regularly the tenth most popular of all programming languages. (Index.dev claims that it has climbed up to number nine this year, just behind Go.) As a professional move, it might not be the most obvious niche but it might not be career suicide either. That’s not his whole argument, but it’s required to address the criticism that “nobody uses Pascal anymore”.
Pascal, quite simply, can make you a better programmer. That, as [Huw] points out, was an explicit goal of the language. Before Python took over the education world, two generations of high school students learned Pascal. Pascal’s strong typing and strict rules for declaration taught those kids good habits that hopefully carried over to other languages. It might help you, too.
For experienced programmers, Pascal is still a reasonable choice for cross-platform development. Free Pascal (and the Lazarus IDE) brings the graphical, drag-and-drop ease that once made Delphi rule the Windows roost to any modern platform. (And Delphi, a commercial Pascal product, is apparently still around.) Free Pascal lets you code on Linux or Mac, and deploy on Windows, or vice-versa. While you could do that on Python, Pascal gets you a lot closer to the metal than Python ever could.
Sure, it’s a modern object-oriented language now, with objects and classes and hierarchies and all that jazz– but you don’t always have to use them. If you want to go low-level and write your Pascal like it’s 1985, you can. It’s like being able to switch into C and manipulate pointers whenever you want.
On some level, perhaps the answer to the question “Why use Pascal in 2025” is simply– why not? It’s likely that the language can do what you want, if you take the time to learn how. You can even use it on an Arduino if you so wish– or go bare metal on the Raspberry Pi.
Thanks to [Stephen Walters] for the tip.
Continue reading “The Case For Pascal, 55 Years On”
Yet Another Rigol DS1054Z Viewer
Tired of squinting at the small numbers on the oscilloscope display, [Alfred] aka [Gaze@] decided to take matters into his own hands and wrote yet another tool to remotely view images from a Rigol DS1054Z. At least that was the initial idea. But, it grew unexpectedly — as [Alfred] says, “the more the project turned out to be fun, the more it got out of hand”. We know the feeling well.
In addition to being able to simply view and export the screen, the program implements waveform measurements (we’re not sure if it is using the measurement ability of the ‘scope, or actually performing measurements in the program). And as you can see in the animated GIF of the program in operation over on the GitHub repository, the numbers are certainly clear and legible. His problem of squinting at the small screen has indeed been solved.
This is coded in Pascal (FPC Lazarus), but we weren’t able to browse the program because [Alfred] hasn’t posted the source code yet. It is written only for Linux, and he has tested it on Ubuntu, Debian, Fedora, and Manjaro. The project relies on Python, PyVisa, and gtk2, and talks to your DS1054Z over USB or LAN. The installation instructions are well documented, but as [Alfred] himself warns, if you encounter trouble arising from subtle dependency version conflicts, you may need to be a nerd and/or a pensioner with unlimited time on your hands to solve them. There is no users guide nor extensive help according to [Alfred]. However, simple hints might be found in hover text or by pressing F1. Disclaimers aside, this looks like an interesting project to try out.
As [Alfred] notes, there are many other tools available to fetch data and images from your Rigol oscilloscope. [Jenny List] wrote a two-part series on using Python to control your test instruments, and here’s an example of a simple Python script that does a screen grab. Do you have a favorite way to remotely operate your oscilloscope? Let us know in the comments below.
Raspberry Pi Boots CP/M
Retrocomputing is an enjoyable and educational pursuit and — of course — there are a variety of emulators that can let you use and program a slew of old computers. However, there’s something attractive about avoiding booting a modern operating system and then emulating an older system on top of it. Part of it is just aesthetics, and of course the real retrocomputing happens on retro hardware. However, as a practical matter, retrocomptuters break, and with emulation, you’d assume that CPU cycles spent on the host operating system (and other programs running in the background) will take away from the target retrocomputer.
If you want to try booting a “bare metal” Z80 emulator with CP/M on a Raspberry Pi, you can try EMUZ80 RPI. The files reside on an SD card and the Pi directly boots it, avoiding any Linux OS (like Raspian). It’s available for the Raspberry Pi Model B, A+, and the Raspberry Pi 2 Model B. Unlike the significant boot times of the standard Linux distros on the earliest models of Pi, you can boot into CP/M in just five seconds. Just like the old days.
The secret to this development is an open source system known as Ultibo, a framework based on Open Pascal which allows you to create bare metal applications for the Raspberry Pi. The choice of Free Pascal will delight some and annoy others, depending on your predilections. Ultibo is still very much in active development, but the most common functions are already there; you can write to the framebuffer, read USB keyboards, and write to a serial port. That’s all you really need to make your own emulator or write your own Doom clone. You can see a video about Ultibo (the first of a series) below.
Continue reading “Raspberry Pi Boots CP/M”
