Announcing The Five Finalists For The Hackaday Prize
Six months ago we challenged you to realize the future of open, connected devices. Today we see the five finalists vying for The Hackaday Prize.
These five were chosen by our panel of Launch Judges from a pool of fifty semifinalists. All of them are tools which leverage Open Design in order to break down the barriers of entry for a wide range of interests. They will have a few more weeks to polish and refine their devices before [Chris Anderson] joins the judging panel to name the winner.
Starting on the top left and moving clockwise:
ChipWhisperer, an embedded hardware security research device goes deep into the world of hardware penetration testing. The versatile tool occupies an area in which all-in-one, wide-ranging test gear had been previously non-existant or was prohibitively expensive to small-shop hardware development which is so common today.
SatNOGS, a global network of satellite ground stations. The design demonstrates an affordable node which can be built and linked into a public network to leverage the benefits of satellites (even amateur ones) to a greater extent and for a wider portion of humanity.
PortableSDR, is a compact Software Defined Radio module that was originally designed for Ham Radio operators. The very nature of SDR makes this project a universal solution for long-range communications and data transfer especially where more ubiquitous forms of connectivity (Cell or WiFi) are not available.
ramanPi, a 3D printed Raman Spectrometer built around a RaspberryPi with some 3D printed and some off-the-shelf parts. The design even manages to account for variances in the type of optics used by anyone building their own version.
Open Source Science Tricorder, a realization of science fiction technology made possible by today’s electronics hardware advances. The handheld is a collection of sensor modules paired with a full-featured user interface all in one handheld package.
From Many, Five
The nature of a contest like the Hackaday Prize means narrowing down a set of entries to just a few, and finally to one. But this is a function of the contest and not of the initiative itself.
The Hackaday Prize stands for Open Design, a virtue that runs far and deep in the Hackaday community. The 50 semifinalists, and over 800 quarterfinalists shared their work openly and by doing so provide a learning platform, an idea engine, and are indeed the giants on whose shoulders the next evolution of hackers, designers, and engineers will stand.
Whether you submitted an entry or not, make your designs open source, interact with the growing community of hardware engineers and enthusiasts, and help spread the idea and benefits of Open Design.
The Hackaday Store Lives Again!
Once upon a time there was a store where you could find the most amazing Hackaday shirts and other swag. If you managed to get one of the rare Jolly Wrencher adorned shirts back then, it’s probably about worn out by now. Prepare to rejoice, Hackaday has a completely new store packed with T-shirts, tools, and stuff to help you fill up those waking hours with hardware hacking goodness.
We’ve had a little fun over the last couple of days with posts that hint (maybe a bit too subtly?) that this was coming. We always try to have a little bit of fun for those of you who are really paying attention. Now we’re wondering who will be the first to implement the one-time pad as a dedicated piece of hardware… project ideas need to come from somewhere, right?
Take a look around the general store and you’ll see this time we have more than just stuff you wear. Hackers need tools and we’ve selected a small but inspiring group of must-have’s. The kits and toys we’ve selected are surely a rabbit hole of personal challenges and evolving hacks for you. And the best part is that these choices are one more way for us to promote the virtue of Open Design (it is the way). The only question now is what other open hardware do you want to see added to those ranks?
Open Design. It Is The Way.
It seems like I’m constantly having the same discussions with different people about the Open Design aspect of The Hackaday Prize. I get arguments from both sides; some attest that there should be no “openness” requirement, and others think we didn’t set the bar nearly high enough. Time to climb onto my soap box and throe down some sense on this argument.
Open Design is Important
When you talk about hardware there is almost always some software that goes into making a finished product work. Making the information about how a product works and how it is manufactured available to everyone is called Open Design; it encompasses both Open Hardware and Open Source Software. Open Design matters!
First of all, sharing how something is designed and built goes much further than just allowing others to build their own. It becomes an educational tool and an innovation accelerator (others don’t need to solve the same problems over and over again). When using a new chip, protocol, or mechanical part you can learn a lot by seeing how someone else already did it. This means faster prototyping, and improvements on the design that weren’t apparent to the original creator. And if it breaks, you have a far easier time trying to diagnose and repair the darn thing! We all benefit from this whether we’re creating something or just using an end product because it will work better, last longer, and has the potential to be less buggy or to have the bugs squashed after the fact.
nest-300x293
Nest thermostat rooted by [cj]
There is also peace-of-mind that comes with using Open Design products. The entries in The Hackaday Prize need to be “connected devices”. With open design you can look at the code and see what is being done with your information. Can you say that about Nest? They won’t even allow you to use the thermostat in a country that hasn’t been pre-approved by decree from on high (we saw it hacked to work in Europe a few years back). Now it has been rooted so that you can do with it what you please.
But I contest that it would have been better to have shipped with options like this in the first place. Don’t want to use Nest’s online platform? Fine, let the consumer own the hardware they pay for! My wager since the day they announced Google’s acquisition of Nest is that this will become the “router” for all the connected devices in your home. I don’t want the data from my appliances, entertainment devices, exercise equipment, etc., being harvested, aggregated, and broadcast without having the ability to look at how the data is collected, packaged, and where it is being sent. Open Design would allow for this and still leave plenty of room for the big G’s business model.
I find it ironic that I rant about Google yet it would be pretty hard to deny that I’m a fanboy.
Decentralize the Gatekeeper
I’m going to beat up on Google/Nest a bit more. This is just an easy example since the hardware has the highest profile in the field right now.
If Nest controls the interface and they retain the power to decide whose devices can participate the users lose. Imagine if every WiFi device had to be blessed by a single company before it would be allowed to connect to any access points? I’m not talking about licensing technology or registering a MAC address for a chip. I’m talking about the power, whether abused or not, to shut any item out of the ecosystem based on one entity’s decisions.
If connected devices use a known standard that isn’t property of one corporation it unlocks so many good things. The barrier for new companies to put hardware in the hands of users is very low.
Let’s consider one altruistic part of this; Open Design would make small run and single unit design a possibility. Think about connected devices specialized for the physically challenged; the controller project makes specialized controls for your Xbox, what about the same for your oven, dishwasher, the clock on your wall, or your smart thermostat?
The benefits really show themselves when a “gatekeeper” goes out of business or decides to discontinue the product line. This happened when the Boxee servers were shut down. If the source code and schematics are available, you can alter the code to use a different service, build up your own procotol-compliant home server, or even manufacture new devices that work with the system for years to come. There are already pleas for belly-up manufacturers to open-source as the last death throw. Hacking this stuff back into existence is fun, but isn’t it ridiculous that you have to go to those lengths to make sure equipment you purchased isn’t turned into a doorstop when they shut the company lights off?
home-automation-from-1985To drive the point home, consider this Home Automation System from 1985 [via Reddit]. It’s awesome, outdated, and totally impossible to maintain into the future. I’m not saying we should keep 30-year-old hardware in use indefinitely. But your choices with this are to source equally old components when it breaks, or trash everything for a new system. Open Design could allow you to develop new interfaces to replace the most used parts of the system while still allowing the rest of the hardware to remain.
Why not disqualify entries that aren’t Open Hardware and Open Source Software?
Openness isn’t a digital value
Judging preferences are much better than disqualifying requirements. This is because ‘openness’ isn’t really a digital value. If you publish your schematic but not your board artwork is that open? What if you’re using parts from a manufacturer that requires a Non-Disclosure Agreement to view the datasheet and other pertinent info about the hardware?
In addition to deciding exactly where the threshold of Open or Not-Open lies, we want to encourage hackers and companies to try Open Design if they never have before. I believe that 1% open is better than 0% open, and I believe that there is a “try it, you’ll like it” experience with openness. If this is the case, The Hackaday Prize can help pollinate the virtue of Open Hardware far and wide. But only if we act inclusively and let people work their way toward open at their own pace.
There are more benefits to Open than there are drawbacks.
open-hardware-is-goodThe biggest worry I hear about open sourcing a product is that it’ll get picked up, manufactured, and sold at a cut-throat rate.
If you build something worth using this is going to happen either way. The goal should be to make a connection with your target users and to act ethically. Open Design allows the user to see how your product works, and to add their own features to it. Most of the time these features will appeal to a very small subset of users, but once in a while the community will develop an awesome addition to your original idea. You can always work out a way to include that in the next revision. That right there is community; the true power of open.
So yeah, we’re giving away a trip to space and hundreds of other prizes. But these are really just a carrot to entice hackers, designers, and engineers to feed the hungry world of Open Hardware and Open Source Software.
Barobot Serves Cocktails While Using Open Design The Right Way
barobot-mechanical-bartender
Oh for the day when we can stop repeatedly looking up our favorite drink recipes on Wikipedia. Those may be just around the corner and you’ll have your choice of single-click delivery or toiling away in the workshop for a scratch build. That’s because Barobot is satisfying both the consumer market and our thirst for open hardware goodness. They’re running a Kickstarter but to our delight, the software and mechanical design files are already posted. Before you dig into the design files there’s a really good look at the constituent parts in the assembly manual (PDF) — that’s a lot of pieces! — and a tiny bit on the tech-stuff page.
This remind us of the Drinkmo we saw earlier in the year. That one cames complete with the high-pitched whine of stepper motors. We didn’t get to hear Barobot’s ambient noise in the promo vid after the break. But one place this desing really shines is a swiveling caddy that allows for a double-row of bottles in a similar footprint. One thing we’d be interesting in finding out is the cleaning procedure. If anyone know what goes into cleaning something like this let us know in the comments.
Continue reading “Barobot Serves Cocktails While Using Open Design The Right Way”
Hardware Startup Review: Spark
The Hardware Startup Review - Spark - Hackaday-01
Like it or not, a whole new wave of Hardware Startups is coming our way. Crowd Funding campaigns are making it possible for everyone with an idea to “test the waters”, tech-savvy Angel investors are eager to help successful ones cross over, and Venture Capitalists are sitting on the other side, always on the lookout for potential additions to their “hardware portfolio”. It’s these billion-dollar acquisitions that made everyone jump on the bandwagon, and there’s no going back. At least for now.
That’s all great, and we want to believe that good things will come out of this whole frenzy. But instead of staying on the sidelines, we thought Hackady should get involved and start asking some hard questions. After all, these guys didn’t think they’d be able to get away with some nicely produced videos and a couple of high-res photos, right?
For our first issue, we picked a relatively innocent target – Spark, the team behind the Spark Core development board. By embracing Open Source and Open Hardware as the core part of their strategy, Spark has so far been a positive example in the sea of otherwise dull (and potentially creepy) IoT “platforms”. So we thought we should give [Zach Supalla], CEO of Spark a call.
Continue reading “Hardware Startup Review: Spark”
The Hackaday Prize: You Build Open Hardware, We Send You To Space
[youtube=https://www.youtube.com/watch?v=Dh5yzP4ZINA&w=580]
For weeks we’ve been teasing you that something BIG was coming. This is it. Six months from now one hardware hacker will claim The Hackaday Prize and in doing so, secure the grand prize of a trip into space.
You have the skills, the technology, and the tenacity to win this. Even if you don’t take the top spot there’s loot in it for more than one winner. To further entice you, there are eyebrow-raising prizes for all five of the top finishers, and hundreds of other rewards for those that build something impressive. You can win this… you just need to take the leap and give it your all.
Continue reading “The Hackaday Prize: You Build Open Hardware, We Send You To Space”
