Pulse Jet Ski Chases The Winter Blues Away
A long winter has a way of making a lot of us northerners a little bit squirrly. In [Build N Pulsejets]’s case, squirly enough to mount a home-made propane-powered pulse-jet to a kids’ kick scooter and take to the frozen lake for a rip.
Okay, well, it started as a kid’s scooter, but after trying it on the ice sans pulsejet, [Build N] decided that his cabin fever wasn’t quite bad enough to risk using it in stock configuration. Before mounting the 180 lb thrust (800 N) pulse jet he’d built in a previous video, a few modifications would be needed. Namely, a trio of scrap metal skis and a goodly amount of metalwork to mount them, and the pulse jet. Even on ice, with relatively little friction, the mass of maker and a full propane tank meant the acceleration wasn’t great, but he did get it over 44 mph (77 km/h) on the snowmobile drag strip. (Yeah, snowmobile drag racing’s a thing in the frozen north. Those of you sipping mai tais in the tropics are probably pretty jealous right now, huh?)
These pages have been no stranger to pulse jets, given that they’re probably the easiest engine to build at home. We’ve seen them mounted on everything from go karts, to Swedish snomobiles, and even tea kettles.  Actually, we’ve seen two of those. No points for guessing what nation the tea kettle builds hail from.
Continue reading “Pulse Jet Ski Chases The Winter Blues Away”
Jet Engine Powers Tea Kettle
While there are plenty of places around the world to get a great cup of tea, no one has quite burned it into their culture like those in the United Kingdom. While they don’t have the climate to grow the plants themselves, they at least have figured out the art of heating water extremely rapidly in purpose-built electric kettles while the rest of us wait to heat water on our stoves and microwaves. But that’s still not fast enough for some, like [Finlay Shellard], who just completed this jet-powered tea kettle.
[Finlay] took some inspiration cues and parts from another jet engine he had on hand that was powering his toaster. This is a pulse jet design, which is welded together from laser-cut pieces of sheet metal with guides welded in place to allow water to flow around the combustion chamber and exhaust. Pressurized water sits in a reservoir at the top of the engine, and when it is up to temperature, a valve allows it to flow to the engine to heat up. When it has passed the jet engine section, it passes a tea bag holder and then out of a spout at the end of the engine.
A few tests at 100 PSI had the hot tea exiting the engine in a non-linear fashion, so the pressure was reduced. The device now makes tea at incredibly fast speeds, with the only downsides being access to some sort of jet fuel, and also the need for a protective hearing device of some sort. For anyone attempting to do this themselves, take a look at this build which includes a turbocharger design for improved efficiency of the pulse jet itself.
Continue reading “Jet Engine Powers Tea Kettle”
3D Printed Turbocharger Boosts Pulsejet Performance
Pulsejets are a popular DIY build for the keen experimenter, much loved for their mechanical simplicity and powerful roar. However, it can be difficult to get them running smoothly and producing high amounts of thrust. In an ongoing quest to do just that, [Integza] has been iterating hard on his designs, recently adding an electric turbocharger to add some boost.
Like any combustion engine, adding more air means that more fuel can be burned for more power. The electric turbocharger is a perfect way to do this, using a powerful brushless motor to turn a radial compressor wheel to force high-pressure air into the pulse jet’s combustion chamber. [Integza] used a resin printer to produce the turbocharger compressor wheel and housing, which made producing the complex geometry a cinch.
Initial results were positive, with the pulsejet maintaining better combustion with the turbocharger activated. It does come with the drawback of requiring battery power to run, but it may be worth the tradeoff for added thrust. However, the fragile setup requires more refinement before a thrust test can be carried out. Up until now, [Integza] has made do with a set of bathroom scales; we imagine a spring force gauge or strain gauge might be in order. If you’re keen to build your own pulsejet without welding, consider the carbon fiber method used in this project. Video after the break.
Continue reading “3D Printed Turbocharger Boosts Pulsejet Performance”
A 136 Euro Pulse Jet For Some No-Firework Lockdown Fun
With the aim of reducing virus transmission due to gatherings during the pandemic, the Dutch government have banned fireworks. The people of the Netherlands like their noisy things so we’re told that the ban has been widely flouted, but [Build Comics] are a law-abiding group of workshop tool heroes. For their lockdown noise, they created an entirely-legal pulsejet. The interesting part is that it was made entirely using fairly basic tools on a minimalist budget, with TIG and MIG eschewed in favour of a mundane stick welder.
The form of the pulse jet will probably be familiar as it has been taken from other published designs. A long tube is bent back upon itself with a combustion chamber placed in one of its arms such that the jet forms a resonant chamber that produces continuous pulses of exhaust gas. This one is made from stainless steel tube, and the exhaustive documentation should be worth a look for anyone tempted to make their own. Welding thin sheet with a stick welder requires quite a bit of skill, and in a few places they manage to burn a hole or two. One requires a patch, but the time-honoured technique of running a bead around the edge manages to successfully close another.
Their first attempt to fire it up using a leaf blower with a 3D-printed adapter fails, but following the construction of a more resilient part and a more efficient gas injector the engine starts. It’s then taken out on a farm for some serious noise without too many angry neighbours, as you can see in the video below the break.
The hero tools of Build Comics have appeared here before, most recently with an analogue meter clock.
Continue reading “A 136 Euro Pulse Jet For Some No-Firework Lockdown Fun”
Homebrew Pulsejet Uses Carbon Fiber To Great Effect
Jet engines are undeniably awesome, but their inherent complexity prevents many from experimenting with the technology at home. Perhaps the most accessible design is the pulsejet; in valveless form, it can be built relatively easily without needing a lot of precision spinning parts. [Integza] decided to try building his own, facing many hurdles along the way. (Video, embedded below.)
Despite eschewing turbines and compressors, and consisting of just an intake, exhaust and a combustion chamber, the pulsejet still presents many challenges to the home gamer. Primary concerns are sustaining combustion without the jet flaming out, and building the jet out of suitable materials that won’t simply melt into a gooey puddle on the floor.
[Integza]’s design process began with many 3D-printed attempts. While the geometry was on point, none of these designs could run for more than a few seconds without melting and falling apart. Determined to avoid the typical welded-steel approach, [Integza] instead resolved to go left-of-field with carbon fibre mat combined with high-temperature sealant. With the help of a 3D-printed mold, he was able to produce a working engine that could stand up to the high temperatures and produce that glorious pulsejet sound.
It’s come a long way from [Integza]’s earlier experiments, and we look forward to seeing where it goes next – whether that be on a plane or perhaps even a go-kart. Video after the break.
Continue reading “Homebrew Pulsejet Uses Carbon Fiber To Great Effect”
A Jet Powered Go Kart
Do Not Try This At Home: A Jet Powered Go Kart
[Colin Furze] is at it again. This time he’s built a freaking jet-engine powered go kart.
In case you’re not familiar with [Mr. Furze], he’s no stranger to building high-speed vehicles, like the fastest baby stroller in the world. And he’s also got a bit of an obsession with pulse jet engines. He’s even made one out of a toilet roll holder. He was a plumber — but now he’s one of the best mad scientist YouTube creators around. We just hope he doesn’t kick the bucket too soon with one of his extreme projects, because his safety tie probably won’t save him!
This month’s project is no exception — he’s strapping his giant pulse jet engine he used to fart on France onto the frame of a tiny go kart. “As you can see the jet to kart ratio is pretty good”. No kidding — the engine has gotta be 2.5 times as long as the go kart’s frame!
Stick around after the break to see him risk his neck for our own amusement.
Continue reading “Do Not Try This At Home: A Jet Powered Go Kart”
Pulse Jet Snowmobile, Or, What Swedes Do During Hibernation
Sweden is coming out of the depths of a cold, dark winter. What better time, then, to enjoy the last few weeks of frigid temperatures, short days, and frozen lakes and rivers? That’s what Orsa Speed Weekend is all about; tearing across a frozen lake by any means necessary, including jet powered snowmobiles.
This pulse jet comes from the fruitful minds at Svarthalet Racing (Google Translation) who have put an amazing amount of work into their fuel-injected pulse jet snowmobile during these last cold winter months. They’ve even gone so far as to do some analysis regarding how much horsepower their snowmobile has. Surprisingly, it’s not much more horsepower than a small car, but that’s due to the hilarious inefficiency of pulse jets compared to more conventional engines.
This isn’t the first time we’ve seen jet powered snowmobiles build for Orsa Speed Weekend. We’ll just hope this year a few more videos will show up in our tip line.
