Retro Style VFO Has Single-Digit Parts Count
Not every project has to be complicated– reinventing the wheel has its place, but sometimes you find a module or two that does exactly what you want, and the project is more than halfway done. That the kind of project [mircemk]’s Simple Retro Style VFO is — it’s a variable frequency oscillator for HAM and other use, built with just a couple of modules.
Strictly speaking, this is all you need for the project.
The modules in question are the SI5351 Clock Generator module, which is a handy bit of kit with its own crystal reference and PLL to generate frequencies up to 150 MHz, and the Elecrow CrowPanel 1.28inch-HMI ESP32 Rotary Display. The ESP32 in the CrowPanel controls the SI5351 module via I2C; control is via the rest of the CrowPanel module. This Rotary Display is a circular touchscreen surrounded by a rotary display, so [mircmk] has all the inputs he needs to control the VFO.
To round out the parts count, he adds an appropriate connector, plus a power switch, red LED and a lithium battery. One could include a battery charger module as well, but [mircmk] didn’t have one on hand. Even if he had, that still keeps the parts count well inside the single digits. If you like video, we’ve embedded his about the project below; if not the write up on Hackaday.io is upto [mircmk]’s typical standard.
People have been using the SI5351 to make VFOs for years now, but the addition of the round display makes for a delightfully retro presentation.
Thanks to [mircmk] for the tip.
Continue reading “Retro Style VFO Has Single-Digit Parts Count”
Illustrated Kristina with an IBM Model M keyboard floating between her hands.
Keebin’ With Kristina: The One With The Circuit Sculpture Keyboard
The left half of GEMK-47, a mechanical keyboard with a round screen.
Image by [New-Concentrate6308] via reddit
Don’t worry, [New-Concentrate6308] is working on the GitHub for this final build of 2024, dubbed the GEMK_47. That stands for Grid Ergo Magnetic Keyboard, but I swear there are 48 keys.
What we’ve got here is a split ergo with an ortholinear layout. There’s a round screen and encoder on the left side, and a 35 mm trackpad on the right. There’s also space for some other round thing on this side, should you want another rotary encoder or whatever fits in place of the spacer.
Internally, there’s a Waveshare RP2040 Tiny and a mixture of Gateron Oil Kings and Gateron Yellow V3 switches. That lovely case is printed in silk silver PLA, but [New-Concentrate6308] wants to try metal-filled PLA for the next version. Although the original idea was to go wireless, ZMK didn’t play nicely with that round display, which of course is non-negotiable.
Continue reading “Keebin’ With Kristina: The One With The Circuit Sculpture Keyboard”
Synesthetic Clock Doesn’t Require Synesthesia
We often think of synesthetes as those people who associate say, colors with numbers. But the phenomenon can occur with any of the senses. Simply put, when one sense is activated, synesthesia causes one to experience an unrelated, activated sense. Sounds trippy, no?
Thankfully, [Markus Opitz]’s synesthetic clock doesn’t require one to have synesthesia. It’s actually quite easy to read, we think. Can you tell what time it is in the image above? The only real requirement seems to be knowing the AM color from the PM color. The minute display cycles through blue, green, yellow, and red as the hour progresses.
Behind that pair of GC9a01 round displays lies an ESP32 and a real-time clock module. [Markus] couldn’t find a fillArc function, so instead he is drawing triangles whose ends lie outside the visible area. To calculate the size of the triangle, [Markus] is using the angle function tangent, so each minute has an angle of 6°.
[Markus] created a simple but attractive oak housing for the clock, but suggests anything from cardboard and plastic to a book. What’s the most interesting thing you’ve ever used for an enclosure? Let us know in the comments.
Do you appreciate a good analog clock when you see one? Here’s a clock that uses analog meters for its display.
PCB Design Review: ESP32-S3 Round LCD Board
For our next installment, I have a lovely and daring PCB submitted by one of our readers, [Vas]. This is an ESP32-S3 board that also has an onboard round TFT display, very similar to the one we used on the Vectorscope badge. The badge is self-sufficient – it has an ESP32, it has a display, a programming connector, two different QWIIC ports you could surely use as GPIOs – what’s not to love?
This is a two-layer board, and I have to admit that I seriously enjoy such designs. Managing to put a whole lot of things into two layers is quite cool in my book, and I have great fun doing so whenever I get the opportunity. There’s nothing wrong with taking up more layers than needed – in fact, if you’re concerned about emitted/received noise or you have high-speed interfaces, four-layer is the way to go. But making complex boards with two layers is a nice challenge, and, it does tend to make these boards cheaper to manufacture as a very nice bonus.
Let’s improve upon it, and support [Vas]’s design. From what I can see looking at this board, we can help [Vas] a lot with ease of assembly, perhaps even help save a hefty amount of money if they go for third-party PCBA instead of sitting down with a stencil – which you could do with this board pretty easily, since all of the components on it, save for the display, are the ones you’d expect JLCPCB to stock.
Continue reading “PCB Design Review: ESP32-S3 Round LCD Board”
99% Partspiration
Thomas Edison once said that genius was 1% inspiration and 99% perspiration. That doesn’t leave much room for partspiration.
I’m working on a top-secret project, and had to place a parts order on AliExpress with a minimum order quantity of five in order to get decent shipping times. No big deal, financially, and it’s always great to have spares as backup for the ones you fry.
But as I started lighting up the little round smartwatch displays to put them through their paces, I started thinking of all sorts of ways that I could use something like this. I had no idea how easy to drive they were, or frankly, how good they looked in person. When you get a round display in your hands, you find that you need dial indicators everywhere.
And then my son came by and said “Oh neat. I want one!” and started thinking up all sorts of gizmos that I could put them in. Two of them would make awesome eyes, and he’s been on a chameleon kick – the animal, you know. So we’re looking for chameleon eye animations online.
And all of a sudden, I have more projects lined up than I have remaining screens. I’m calling this phenomenon “partspiration”. You know, when you figure out how to use something and then you see uses for it everywhere? Time to place another Ali order.
Gearing Up for the Hackaday Prize
And don’t forget, we just started the next round of the Hackaday Prize: Gearing Up. In this challenge round we want to see your best DIY tools, jigs, and workflow accelerators. Custom reflow plates, home-built power supplies, or even software tools – as long as it helps you get the job done, it has a place here. You’ve got until Aug. 8 to get your entry finished, but head on over to Hackaday.io and get started now.
Tackle The Monkey: Raspberry Pi Gets Round Screen
You could argue that the project to add a round screen to a Raspberry Pi from [YamS1] isn’t strictly necessary. After all, you could use a square display with a mask around it, giving up some screen real estate for aesthetics. However, you’d still have a square shape around the screen and there’s something eye-catching about a small round screen for a watch, an indicator, or — as in this project — a talking head.
The inspiration for the project was a quote from a Google quote about teaching a monkey to recite Shakespeare. A 3D printed monkey with a video head would be hard to do well with a rectangular screen, you have to admit. Possible with a little artistry, we are sure, but the round head effect is hard to beat. Honestly, it looks more like an ape to us, but we aren’t primate experts and we think most people would get the idea.
Continue reading “Tackle The Monkey: Raspberry Pi Gets Round Screen”
