In the world of Doctor Who, the sonic screwdriver is a versatile tool with a wide range of capabilities. [Hartley] wanted some of that action for himself, and built a device of his own.
Unable to recreate the broad swathe of features from the show, he settled on something easier. The device is fitted with an ATTiny85, and a 433MHz transmitter. It’s programmed to switch wirelessly controlled mains sockets on and off. This lets him control appliances in his house with a flick of a screwdriver. Power is supplied by the classic AA battery, with a boost converter stepping it up to 5V to run the electronics.
It’s all wrapped up in a 3D printed case, that was carefully designed to fit all the parts inside. A paper mockup of the PCB layout was also used in the design phase. [Hartley] took full advantage of CAD software, to ensure everything fit correctly first time.
It’s a fun project, as sonic screwdrivers often are. Video after the break.
Many weekends later [Sam] and his dad finished the body of the screwdriver and started work on the electronics. To keep it simple they used an Arduino Pro Mini 5V with a Sparkfun OpenLog to record all the data — and a handful of sensors of course!
