a.ntivir.us wanted to use a different antenna for their Netgear mbr624gu WiFi router. Unfortunately, this model comes with an antenna that is not removable. As with other antenna retrofits, this involves no soldering. But because there is already a mounting area for an antenna, no case altering is needed either. After opening the router with a Torx driver it was discovered that the non-removable antenna was connected to the board with a mini rf connector (U.FL). The antenna and its mounting bracket were removed and a U.FL to RP-SMA adapter was put in its place using a washer to secure it to the rear plate of the router. Now any external antenna can be used and the router still looks brand new.
