Magnetic Propeller Balancer Takes Away The Shakes
prop-balancer
[Danijel0frk’s] friends may call him unbalanced, but his propellers are always spot on. His well-balanced props are thanks to this magnetic balancer he built from scrap PC parts and pilfered office supplies. Propeller balance has always been important for radio controlled models. Flying for hours with a poorly balanced prop can wreak havoc on an air frame and the radio equipment within.  With today’s drones and R/C vehicles carrying cameras, accelerometers, and gyros, propeller balance has become even more important. A vibrating propeller can ruin a picture at best. At worst it can throw gyroscope and accelerometer readings off and cause a crash.
[Danijel0frk’s] balancer is based upon several commercial designs. A steel shaft from a CD-ROM drive is cut and the ends ground to points. A propeller to be balanced is mounted to the shaft. Propellers don’t all have the same hole size so two pen tips are pressed into service as self centering mounts. [Danijel0frk’s] picture shows one tip pointing toward the prop hub while the other points away. The balancer will work better if both tips point inward, ensuring the shaft sits directly in the center of the propeller hub’s hole. Hard drive magnets suspend the prop and shaft from a drive rail and wood frame.  We should note that this type of balancer will only perform a static balance. Dynamic balance would require the propeller to be spinning on a motor with force sensors on the shaft. To perform a static balance, material is added to or removed from the propeller until it balances in any orientation. Click past the break for a good tutorial video on balancing.
Continue reading “Magnetic Propeller Balancer Takes Away The Shakes”
Fluke Issues Statement Regarding Sparkfun’s Impounded Multimeters
fluke-reponds-to-sparkfun-dmm-impounding
Fluke just issued a response to the impounding of multimeters headed for market in the United States. Yesterday SparkFun posted their story about US Customs officials seizing a shipment of 2000 multimeters because of trademark issues. The gist of the response is that this situation sucks and they want to do what they can to lessen the pain for those involved. Fluke is providing SparkFun with a shipment of genuine Fluke DMMs which they can sell to recoup their losses, or to donate. Of course SparkFun is planning to donate the meters to the maker community.
Anyone with a clue will have already noticed the problem with this solution. The impounded shipment of 2k meters will still be destroyed… eh. The waste is visceral. But good for Fluke for trying to do something positive.
Before we sign off let’s touch on the trademark issue for just a moment. We can’t really blame Fluke too much for this. The legal crux of the matter is you either defend your trademark in every case, or you don’t defend it at all. In this case it was the border agents defending the filing, but for ease of understanding we’ll not go into that. On the other hand, speaking in general business terms, the way things are set up it is advantageous to acquire a trademark specification that is as broad as possible because it helps to discourage competitors from coming to market. So trademark is good when it keep hucksters from trying to rip off consumers. But it is bad if applied too broadly as a way of defending a company’s market share.
Where does Fluke come down in all of this? Who knows. There is literally no right answer and that’s why the discussion around yesterday’s post was full of emphatic arguments. A Fluke meter is a cream-of-the-crop device and they have the right (and obligation) to ensure that reputation is not sullied. SparkFun serves a market that probably can’t afford a Fluke at this time but may some day in the future. And this is the reason we can feel okay about this outcome.
[via Twitter]
Fail Of The Week: The Demise Of Lil’ Screwy
fotw-demise-of-lil-screwy
The subject of this Fail of the Week installment is entertaining if nothing else. [Chris] decided to see what kind of forces his home-built 100 ton press could stand up to. Turns out the press failed at punching a 1.5″ hole through 1/2″ plate steel.
If you didn’t see it back in February make sure you take a gander at the premier of Lil’ Screwy. The diminutive press packed quite a bit of punch, using four hand-cranked screws to knock out holes in metal. [Chris] decided to tie-one-on and take his lathe for a spin to machine the larger 1.5″ punch set.
He probably should have known when he switched from a 4-foot ratchet to a crescent wrench with a 12-foot pipe for leverage that this was going to be more than the press could handle. The bottom plate seen in the image above is beginning to cup, which in turn jams up the screws in the off-kilter threads.
We fell a bit guilty in admitting we love to see equipment pushed to the point of failure like this. But perhaps that’s part of what this column is all about. Our favorite is still the PCB shear failure, but this comes in at a close second. Check out the video presentation after the break; just be warned that there’s a bit of rough language as part of the narrative.
Continue reading “Fail Of The Week: The Demise Of Lil’ Screwy”
MRRF: Roundtable And Roundup
Last weekend Hackaday made a trip out to the Midwest RepRap Festival in Goshen, Indiana. We met a ton of interesting people, saw a lot of cool stuff, and managed to avoid the Amish horse and buggies plying the roads around Goshen.
We’ve already posted a few things from MRRF, including [Jordan Miller] and co.’s adventures in bioprinting, a very cool printable object repo that’s backed by a nonprofit LLC, some stuff from Lulzbot that included a new extruder, stretchy filament, and news of a 3D scanner that’s in development, ARM-based CNC controllers including the Smoothieboard and capes for the Beaglebone, 3D printed resin molds, the newest project from [Nicholas Seward], creator or the RepRap Wally, Simpson, and Lisa, and 3D printed waffles. It really was an amazing event and also the largest DIY 3D printer convention on the planet. How this happened in Goshen, Indiana is anyone’s guess, but we’d like to give a shout out to SeeMeCNC for organizing this event.
With so many famous RepRappers in one place, it only made sense to put together a round table discussion on the state of RepRap, 3D printers, and microfabrication. We have a 40-minute long video of that, which you can check out after the break.
Continue reading “MRRF: Roundtable And Roundup”
Piezoelectric Crystal Speaker For Clock Radio Is Alarmingly Easy To Make
cockadoodledooLet’s face it: most of us have trouble getting out of bed. Many times it’s because the alarm isn’t loud enough to rouse us from our viking dreams. [RimstarOrg]’s homeowner’s association won’t let him keep a rooster in the backyard, so he fashioned a piezoelectric crystal speaker to pump up the volume.
[RimstarOrg]’s speaker uses a Rochelle salt crystal strapped to a bean can diaphragm. In his demonstration, he begins by connecting an old clock radio directly to the crystal. This isn’t very loud at all, so he adds a doorbell transformer in reverse. This is louder, but it still won’t get [RimstarOrg] out of bed.
Enter the microwave oven transformer. Now it’s sufficiently loud, though it’s no fire bell alarm. He also demonstrates the speaker using a piezo igniter from one of those long barbecue lighters and a crystal radio earpiece. As always, the video is after the jump. [RimstarOrg] has a lot of relevant linkage in the summary so you can learn how to grow your own Rochelle crystals.
Continue reading “Piezoelectric Crystal Speaker For Clock Radio Is Alarmingly Easy To Make”
You Are Fined 1 Credit For A Violation Of The Verbal Morality Statute
demolition-man-verbal-morality-monitor
Some citizens can control their language and others cannot. What is a civilized society to do? In a dystopian future you can count on electronic monitoring. But wait, the future is now… or it will be in a few weeks. [Tdicola] is building the verbal morality monitor from Demolition Man as his entry in Hackaday’s ongoing Sci-Fi Contest.
Currently the project is in the early planning phase, but holy cow this is a fantastic idea! For those that didn’t see the glorious 1993 feature film, the young [Stallone] pictured above is accepting a ticket (as in: he must pay for his violation) from the tattle-tale wall-mounted computer. Everything about this device is completely feasible using today’s tech. It needs voice recognition and a list of naughty words, a way to play a pre-recorded message, and a printer to spit out the tickets. The build log for the project outlines all of this, as well as possible cost and sources for each.
We’ve been wondering who it was that injected an Artificial Intelligence into our project hosting system. We see both [tdicola] and [colabot] are on the team for this build. The names are too conveniently similar to be a coincidence, don’t you think?
KamerMaker Begins Printing A House
kamermaker-wordpress182-1024x723-634930_610x431
The KamerMaker is the world’s largest portable 3D printing pavilion built out of a shipping container — it has started printing an entire house out of plastic.
We first shared the KamerMaker (literally “Room Maker” in Dutch) a few years ago when it was first designed and built as a collaboration project between Utilimaker and Architectburo DUS. Their intention was the ability to print 1:1 architectural designs, and now it has begun its biggest project yet — an entire house along the canal in Amsterdam.
So far the KamerMaker has printed one corner of the Canal House, which features part of a staircase. It weighs about 400lbs and took a week to print. To increase the strength of these 3D printed parts, the company uses a honeycomb infill and before assembly will fill the gaps inside the piece with a type of foam that becomes as hard as concrete.
The project is estimated to take three years for completion, and until then you can visit it at Tolhuisweg 7, 1031 CL in North Amsterdam, where it is open to the public for a small fee of €2.50 — this is a tourist city after all! When completed it will be a design museum, although the team at DUS hope it will be only the first of many 3D printed buildings.
To learn more about the project, stick around for the following video.
Continue reading “KamerMaker Begins Printing A House”
