Hacking Window Blinds To Interface With Home Automation System
dscn0248
Home automation is great, but what happens when you start mixing different systems around the house together? Follow [Bithead’s] journey of interfacing with his motorized blinds!
After having his original blinds fall apart many times, [Bithead] and his wife decided to invest in some new, motorized blinds — but [Bithead] wanted to add it to his home automation setup… Unfortunately, commercial offerings for that are very expensive, so [Bithead] knew he’d have to figure out how to interface with the system manually.
The problem is, companies don’t typically advertise the kind of in depth information us hackers would love to know about products, so [Bithead] started checking out store showrooms. Salespeople didn’t quite understand his focused attention on the control boxes!
Continue reading “Hacking Window Blinds To Interface With Home Automation System” →
Hackaday Links: March 16, 2014
hackaday-links-chain
Tape decks are fertile hacking ground. In this offering from [Erich] the speed of the motor has been turned into a MIDI instrument. Drive it faster and the pitch rises, slower and it falls. There are all kinds of other magnetic tape hacks around here, this tape delay is a classic.
[Dbever] needed a reason to use a big 7-segment display module. He opened up the drill press at his Hackerspace, Pumping Station One, and added a sensor which shows the RPM of the drill on the display. Hackaday was lucky enough to be invited for a tour of the space last fall.
There’s a lot of hype about 3D printing… and rightly so since it’s the radest; which is even better than being “the most rad”. But if you don’t have access to one that shouldn’t stop you. Here’s an example of making robot parts using polymorph instead of 3D printing (or laser cutting) them.
If you’re living in the east-coast metroplex and are unable to travel to Maker Faire Bay Area this Spring you can still get in on some live hacking. Check out MassHack which takes place the same May weekend but in Boston instead of San Fran.
Blimps; not as cool as quadcopters but orders of magnitude less likely to go down in flames (as it were). Draw some inspiration for your own build from silent_runner. The graceful travel of these lighter-than-air-craft make for an interesting camera platform. Here’s a POV video inside of a church, and some shots from the ground while in the woods. [Thanks Oliver]
We try not to pimp crowd-funding campaigns just for the sake of getting them to the goal. But we hope you’ll agree that the Gamebuino we saw a few months back makes a strong argument for backers. Their Indiegogo for the Arduino-compatible handheld gaming rig is over half-way there after just a couple of days.
Developed On Hackaday: Security And Arduino Compatibility
2013-12_Developed_on_Hackaday
Some of our readers noticed that the Hackaday community open-source offline password keeper (aka Mooltipass) has two incompatible characteristics: being secure and Arduino compatible.
Why is that? Arduino compatibility implies including a way to change the device firmware and accessing the microcontroller’s pins to connect shields. Therefore, some ill-intentioned individuals may replace the original firmware with one that would log all user’s inputs and passwords, or in another case simply sniff the uC’s signals. The ‘hackers’ would then later come to extract the recorded data. Consequently, we needed a secure tamper-proof Mooltipass version and an Arduino-compatible one, while allowing the former to become the latter.
Olivier’s design, though completely closed, will have several thinner surfaces directly above the Arduino headers. As a compromise, we therefore thought of sending a bootloader-free assembled version to the people only interested in the password keeper functionality, while sending a non-assembled version (with a pre-burnt bootloader) to the tinkerers. The Arduino enthusiasts would just need to cut the plastic at the strategic places (and perhaps solder headers to save costs). The main advantage of doing so is that the case would be the same for both versions. The drawback is that each board would have a different firmware depending on who it is intended for.
What do our reader think? For more detailed updates on the Mooltipass current status, you can always join the official Google group.
DIY Mini-Drill Would Make Mad Max Proud
mini-drill
That’s not a prison tattoo gun up there, it’s [Szabolcs] DIY mini drill. Hackaday has been on a bit of a DIY tool kick lately – with improvised saws, grinders, and grinders converted to saws, among other things. We haven’t had any DIY drills yet, though. [Szabolcs] needed a drill for his home-made printed circuit boards. Usually a Dremel or similar rotary tool is pressed into service for drilling PCBs. However, for some reason he didn’t have access to one. [Szabolcs] called upon his inner MacGyver and built a drill from parts he had on hand.
Every drill needs a chuck, or at least a collet holder. This drill’s chuck is sourced from a drafting compass. Long ago in the dark ages before CAD, mechanical drawings were manually drawn up. Companies employed entire drafting departments to draw designs, blueprints, and schematics. These draftsmen used the compass to create accurate circles and arcs. [Szabolcs] re-used the lead holder from the compass as a chuck for his drill. A 540 or 550 brushed sealed endbell can motor, common to the R/C cars spins the drill up. We originally thought [Szabolcs] used an Erector or Meccano set piece as a shaft coupling. The truth is it’s the internals of a Euro style terminal strip. A small tactile button is used to activate the motor. Some electrical tape wrapped around the motor holds the button in place. The tape also makes sure that the user isn’t cut by the sheet metal field ring wrapped around the can. Power for the system can come from just about anywhere, though [Szabolcs] says he uses the 12v rail of an old ATX power supply.
MRRF: 3D Printed Resin Molds
Visiting the Midwest RepRap Festival, you will, of course, find a ton of 3D printed baubles and trinkets. A slightly more interesting find at this year’s MRRF was a lot of resin cast parts from [Mark VanDiepenbos]. He’s the guy behind the RotoMAAK, a spinny, ‘this was in the movie Contact‘-like device designed for spin casting with resins. At the festival, he’s showing off his latest project, 3D printed resin molds.
With the right mold, anyone with 2-part resins can replicate dozens of identical parts in an hour. The only problem is you need a mold to cast the parts. You could print a plastic part and make a silicone mold to cast your part. The much more clever solution would be to print the mold directly and fill it with resin.
[Mark] printed the two-part rabbit mold seen above out of ABS, filled it with urethane resin, and chucked it into his RotoMAAK spin casting machine. Six minutes later the part popped right out, and the mold was ready to make another rabbit.
Video below.
Continue reading “MRRF: 3D Printed Resin Molds” →
Stuffing An RFID Card Into A Finger Ring
[Benjamin Blundell] loves wearable technology — but isn’t very happy with commercial offerings — at least not yet. He wanted to take one of his personal RFID cards, and fit it into a much smaller form factor, a 3D printed RFID ring.
The cool thing with most RFID cards today is they are made of a plastic that is quite easily dis-solvable in Acetone. Simply soak the card for about 30 minutes (depends on the card) and the plastic will simply peel away, revealing the microchip and copper antenna coil. It kind of looks alive when it’s melting…
The problem is, the antenna coil is generally the size of the card — how exactly are you going to fit that into a ring? [Benjamin] managed to find some surrogate RFID key tags, with a much smaller antenna coil. A little bit of solder later and he was able to attach his RFID microchip onto the new antenna! He mentions it is possible to wind your own antenna… but to get the frequency just right might be a bit challenging.
Continue reading “Stuffing An RFID Card Into A Finger Ring” →
A 3-Axis Paper Cutting Mini Laser
LaserCutter
Laser are awesome, and so are projects that use lasers. A recent Instructable by [kokpat] gives an overview of how to create a fully functional laser paper cutter using CDROM stepper motors and an Arduino.
What is special about this build, is that it showcases how easy it can be to build a 3-axis mechanical system used for laser cutters, CNC machines, and 3D printers. Using a stepper stage that consist of a motor screw with a nut slider based carriage, the mechanical system can be put together quite easily and cost effectively. Luckily, from an electronics and software perspective, everything is quite standardized with the proliferation of the RepRap and similar machines. Simply pick any three stepper drivers, find the most pertinent firmware, and voilà! You’re done! Well, almost. Don’t forget a 100mW violet laser!
We have seen a ton of really cool laser cutters before, but this has to be one of the cheapest. See the laser cutter in action after the break.
Continue reading “A 3-Axis Paper Cutting Mini Laser” →
