The Amazon Echo is an attempt to usher in a new product category. A box that listens to you and obeys your wishes. Sort of like Siri or Google Now for your house. Kickstarter creator [Joshua Montgomery] likes the idea, but he wants to do it all Open Source with a Raspberry Pi and an Arduino.
The Kickstarter (which reached its funding goal earlier this month) claims the device will use natural language to access media, control IoT devices, and will be open both for hardware and software hacking. The Kickstarter page says that Mycroft has partnerships with Lucid and Canonical (the people behind Ubuntu). In addition, they have added stretch goals to add computer vision and Linux desktop control to Mycroft.
Every so often – and usually not under the best of circumstance – the field of engineering as a whole is presented with a teaching moment. Volkswagen is currently embroiled in a huge scandal involving emissions testing of 11 Million diesel cars sold in recent years. It’s a problem that could cost VW dearly, to the tune of eighteen Billion dollars in the US alone, and will, without a doubt, end the careers of more than a few Volkswagen employees. In terms of automotive scandals, this is bigger than Unsafe at Any Speed. This is a bigger scandal than the Ford Pinto’s proclivity to explode. This is engineering history in the making, and an enormously teachable moment for ethics in engineering.
Ready to feel inadequate with your programming skills? You’ve been warned. Take a look at [Voja’s] single chip video game console using the PIC24. It produces the VGA signal, 5-channel sound, and is presented in a gamepad form-factor with directional pad and two buttons.
He’s been working with PIC24 for a while now generating VGA signals, and he decided it might be fun to create a 2D video game… so he decided to see if he could program a replica of the old Spectrum game Jumping Jack (play it online here).
It uses a PIC24EP512GP202 microcontroller, complete with 512K flash memory, 48k data, and a whopping 28-pins. The game, which is extremely well documented, is laid out over on his projects page. It makes our heads spin just looking at it! This is a great project to compare with the ArduinoCade from last week. Both do an amazing job of pumping out audio and video while leaving enough room for the game to actually run.
Anyway, enough talking about it — just take a look at the following demo!
On the scale of awesomeness, writing an operating system ranks near the top for software hackers and ranks just below writing a whole new language. [Lukas F. Hartmann] is reaching for the epic status with the Raspberry Pi operating system dubbed Interim. In an interesting mixture of old and new, it’s written in LISP!
LISP (LISt Processing) is the second oldest high-level programming language that received wide-spread usage. The only one older is FORTRAN (FORMula TRANslation), and that is just by one year. LISP is generally associated with artificial intelligence research but it also surfaced as a utilitarian scripting language in various applications like AutoCad. You may have also heard of a more recent dialect, Clojure, which has been receiving a lot of attention.
The source code, an image for the Pi 2, and directions for making it all work are available. [Lukas] also describes how to get a new OS up and running on a Pi.
GPS-based location services will be around with us forever. If you’re in the outback, in the middle of the ocean, or even just in a neighborhood that doesn’t have good cell coverage, there’s no better way to figure out where you are than GPS. Using satellites orbiting thousands of miles above the Earth as a location service is an idea that breaks down at some very inopportune times. If you’re in a parking garage, you’re not using GPS to find your car. If you’re in a shopping mall, the best way to find your way to a store is still a map. Anyone every tried to use GPS and Google Maps in the hotel/casino labyrinth that is the Las Vegas strip?
[Blecky]’s entry for the Best Product competition of the Hackaday Prize aims to solve this problem. It’s an indoor location service using only cheap WiFi modules called SubPos. With just a few ESP8266 modules, [Blecky] can set up a WiFi positioning system, accurate to half a meter, that can be used wherever GPS isn’t.
The idea for a GPS-less positioning system came to [Blecky] after a caving expedition and finding navigation though subterranean structures was difficult without the aid of cell coverage and GPS. This got [Blecky] thinking what would be required to build a positioning service in a subterranian environment.
A SubPos node, equipped with an ESP8266 WiFi module
The answer to this question came in the form of a cheap WiFi module. Each of the SubPos nodes are encoded with the GPS coordinates of where they’re placed. By transmitting this location through the WiFi Beacon Frame, along with the transmitted power, any cell phone can use three or more nodes to determine its true location, down to a few centimeters. All of this is done without connecting to a specific WiFi network; it’s a complete hack of the WiFi standard to allow positioning data.
The most shallow comparison to an existing geolocation system would be a WiFi positioning system (WPS), but there are several key differences. In WPS, the WiFi APs don’t transmit their own location; the AP is simply cross-referenced with GPS coordinates in a database. Secondly, APs do not transmit their own transmit power – important if you’re using RSSI to determine how far you are from an Access Point.
The best comparison to an indoor location service comes from a new Decawave module that sets up ‘base stations’ and figures out a sensor’s location based on time of flight. This, however, requires additional radios for each device receiving location data. SubPos only requires WiFi, and you don’t even need to connect to an AP to get this location data; everything is broadcast as a beacon frame, and every device with WiFi detects a SubPos node automatically.
As an entry to the Hackaday Prize Best Product competition, there is an inevitable consideration as to how this product will be marketed. The applications for businesses are obvious; shopping malls could easily build a smartphone app showing a user exactly where in the mall they are, and provide directions to The Gap or one of the dozens of GameStops in the building. Because the SubPos nodes also work in 3D space, parking garage owners could set up a dozen or so SubPos nodes to direct you to your exact parking spot. Disney, I’m sure, would pay through the nose to get this technology in their parks.
Already [Blecky] is in talks with one company that would like to license his technology, but he’s not focused only on the high-dollar business accounts. He already has a product that needs manufacturing, and if he wins the Best Product competition, he will be working on something for the hacker/homebrew market. The price point [Blecky] sees is around $15 a node. The economics of this work with the ESP WiFi module, but [Blecky] is also looking at alternative chip sets that would allow for more than just RSSI position finding; an improved version of the SubPos node not based on the ESP-8266 could bring time of flight into the mix, providing better position accuracy while still being cheaper to manufacture than the current ESP-based solution.
[Blecky] has a great project on his hands here, and something we will, undoubtedly, see more of in the future. The idea of using WiFi beacon frames to transmit location data, and received signal strength to suss out a position is groundbreaking and applicable to everything from spelunking to finding your car in a parking garage. Since the SubPos system isn’t tied to any specific hardware, this could even be implemented in commercial routers, giving any device with WiFi true location data, inside or out. It’s also one of the top ten finalists for the Hackaday Prize Best Product competition, and like the others, it’s the cream of the crop.
In this excellent video, he describes the simple (but remarkably sophisticated) engineering of the mechanism that allows a pen to pop the ballpoint mechanism out, then back in again. It is a great example of how to illustrate and explain a complex concept, much like his videos on how the CCD sensor of your camera works.
Perhaps the most interesting part of the video is an off the cuff observation he makes, though. The Parker company, who first developed the retractable mechanism, were worried that this new design might flop. So they didn’t put the distinctive Parker arrow clip onto the pen until a few years later, when the pen was a big seller. It seems that while some engineering problems are easy to solve, short-sighted accountants are a harder problem.
As laptops have become smaller and easy to carry around, they have also picked up the most unfortunate property of being easy to steal. We’ve read the stories of how some victims are able to track them down via webcam still images of the thief. [Mastro Gippo] decided to take it one step further and add a remotely operated hardware self destruct to his laptop. The idea is if the laptop becomes unrecoverable, it will become useless and any sensitive data will be destroyed without harming the area around it.
It’s somewhat inception like, as it’s a hack within a hack. It’s based on the Crunchtrack, a CAN bus reverse engineering tool equipped with GPS and a SIM800 GSM module, which was also developed by [Mastro Gippo]. The idea is to tuck the small board somewhere in the laptop and wire it up between the battery and some sensitive parts. Send a single SMS text and ‘poof’, bye-bye laptop.
He wrote all the code in less the 24 hours for the BattleHack Hackathon. He decided to spice up the act with some firecrackers and a detonator, which made his team the crowd favorite and earned a victory.
