The Liquid Trees Of Belgrade: The Facts Behind The Furore
Historically, nature has used trees to turn carbon dioxide back into oxygen for use by living creatures. The trees play a vital role in the carbon cycle, and have done so for millennia. Recently, humans have thrown things off a bit by getting rid of lots of trees and digging up a lot more carbon.
While great efforts are underway to replenish the world’s tree stocks, Belgrade has gone in a different direction, creating artificial “liquid trees” to capture carbon dioxide instead. This has spawned wild cries of dystopia and that the devices are an affront to nature. Let’s sidestep the hysteria and look at what’s actually going on.
Continue reading “The Liquid Trees Of Belgrade: The Facts Behind The Furore” →
Screenshot of the demonstration video that shows the desktop being unlocked with face recognition, with a camera feed and a terminal showing how the software works.
Open-Source FaceID With RealSense
RealSense cameras have been a fascinating piece of tech from Intel — we’ve seen a number of cool applications in the hacker world, from robots to smart appliances. Unfortunately Intel did discontinue parts of the RealSense lineup at one point, specifically the LiDAR and face tracking-tailored models. Apparently, these haven’t been popular, and we haven’t seen these in hacks either. Until now, that is. [Lina] brings us a real-world application for the RealSense face tracking cameras, a FaceID application for Linux.
The project is as simple as it sounds: if the camera’s built-in face recognition module recognizes you, your lockscreen is unlocked. With the target being Linux, it has to tie into the Pluggable Authentication Modules (PAM) subsystem for authentication, and of course, there’s a PAM module for RealSense to go with it, aptly named pam_sauron. This module is written in Zig, a modern C-like language, so it’s both a good example of how to create your own PAM integrations, and a path towards doing that in a different language for once. As usual, there’s TODOs, like improving the UX and taking advantage of some security features RealSense cameras have, but it’s nevertheless a fun and self-sufficient application for one of the F4XX-series RealSense cameras in case you happen to own one.
Ever since the introduction of RealSense we’ve seen these cameras used in robotics and 3D scanning, thanks at least in part due to their ability to be used in Linux. Thankfully, Intel only discontinued the less popular RealSense cameras, which didn’t affect the main RealSense lineup, and the hacker-beloved depth cameras are still available for all of our projects. Wondering about the tech behind it? Here’s a teardown of a RealSense camera module intended for laptop use.
CP/M 6502-Style
There are projects you create to share with the world, but there are also those you do just because you want something for yourself. Lucky for us, [Dietrich-L]’s 30-year-long project to create CPM-65, a CP/M-like OS for the 6502, has become both.
[Dietrich-L] does admit that the documentation is “sparse” and “for my personal needs.” Still, the OS has most of what you’d expect and runs well on the target system, a heavily-modified Elektor Junior with 57 kB of RAM. The disk structure is compatible with CP/M, although the Transient Program Area (TPA) apparently starts at $200, which is a bit different from a typical CP/M. Apparently, the system uses some low memory which necessitated the relocation. Just in case you were hoping, CPM-65 doesn’t emulate an 8080 system, so you can’t run normal CP/M programs. You just get a similar operating environment and tools.
The 31 commands listed include an assembler, BASIC, Forth, an editor, and some disk tools, along with a debugger. Xmodem is available, too. Everything is written in assembly for the CPM-65 assembler, so bootstrapping could be an issue if you need to make any changes.
Speaking of changes, there is some documentation in the docs sub-directory, including the layout of [Dietrich-L]’s system, which would be handy if you were trying to run this on your own hardware. You’ll also find basic commands for the editor, details of the assembler, and some other documents.
[Dietrich-L] notes that he was unaware when he started the project that there were other similar projects. DOS/65 (which has a port for the Commodore 64), OUP/M (which hasn’t been updated since 1983), and CPM65 (apparently no relation, but very impressive), which appeared in 2022.
If you need a 6502 computer, grab a breadboard, although adding the disk drive is an exercise left to the reader. Or, grab an FPGA but expect more work.
Thanks [Stephen Walters] for the tip!
