Perhaps the worst possible way to transmit video would be to send all pixel data in parallel. That’s exactly how [Gebhard Sengmüller’s] parallel image device works. To be fair, this is an art piece called “A Parallel Image” that addresses the concept of where we would be if serial data transmission had never come to fruition. The brochure (PDF) accompanying the exhibit gives the juicy details we’re always looking for.
The device consists of a photo sensor unit and a display unit. Both are one-square-meter stripboard panels made of epoxy. The sensor unit consists of a 50×50 grid of photo-conductors that have their counterparts in the 50×50 grid of light bulbs on the display unit. Things start to get pretty crazy when you throw in the 7500 meters of magnet wire that connect the 2500 pixel sensor unit to the display unit.
You should be able to put together how this works. The sensors pick up light and then effect the brightness of the corresponding light bulbs. The result is an interesting image, and a nightmare of wire porn that would drive any TV repairman to drink.
