[Wei] salvaged the internals from an Airport Express that had a blown power supply. From there he built this streaming music box. The case is from an IKEA clock with the face removed. He added some decorative fabric around a grill to make an acoustically transparent front panel. Inside you’ll find the Airport guts connected to a USB charger (replaces the dead PSU) and a set of powered stereo speakers. This simple mashup looks good and frees up space in your junk-parts box.
Day: August 27, 2010
Hydropower Generator
[Paul] wanted to have access to renewable energy at his cabin. It’s a relaxing place, nestled in a tall forest that shelters him from the sun and wind. This also means that solar and wind energy aren’t an option. But there is a stream running through the property so he decided to build his own version of a small water-powered generator.
He tapped into a reservoir about 200 feet upstream, split the flow into four smaller hoses, and channeled that into a five-gallon bucket. Inside the bucket you’ll find a Pelton wheel he built which turns a low-RPM generator. He manages to generate 56 VDC at 10 A with this setup, more than enough to charge a bank of batteries.
He does a great job of explaining his setup in the video after the break. If you’re looking for other ideas of how to cut down on your environmental impact check out this compost-powered water heater.
IPhone Drum Machine Isn’t Synthesized
There was a time when a drummer would grab some sticks and lay out a groove using the items around him as instruments. [Lsa Wilson] would rather not work quite that hard and has chosen to do the same thing by tapping on an iPhone screen. As you can see in the clip after the break, many of the items in the room around him have been fitted with solenoids. Each is connected to an Arduino which is then controlled by Open Sound Control and interfaced with the iPhone via TouchOSC. We love the sounds being created and can’t help being reminded of the Multixylophoniomnibus.
Devote Your Life To Replicating A Lightsaber
Life-sized Star Wars replica props, it’s one way to keep the ladies away. But if you’re going to make them, you should do it right. [Bradley W. Lewis] spent some serious time getting this [Obi-Wan Kenobi] lightsaber right. The seven-page build log provides plenty of eye-candy. We especially enjoyed the machine and coloring of he grenade-fin portion. The LED ladder that lights the blade is also quite interesting. For the icing on the cake he incorporated a high-performance speaker connected to the sound board from a Hasbro Force FX which provides that classic swashbuckling sound from a galaxy far, far away.
Spy Video TRAKR: First Impressions
At the Bay Area Maker Faire this past May, we had our first glimpse of Wild Planet’s Spy Video TRAKR, a $130 radio-controlled toy with some surprises under the hood.
On the surface, the Spy Video TRAKR — the latest addition to the popular Spy Gear toy line — is an R/C tank with a video camera and night vision, with the added ability to download new “apps” from the internet for extra functions. With a little detective work, one uncovers the TRAKR’s secret double life: it’s also an eminently hackable robotics platform! Prior Spy Gear toys have been popular hack targets, providing inexpensive, mass-produced sources of unusual items such as head-mounted displays. Rather than throw up barriers, Wild Planet has chosen to embrace this secondary market, with plans to release development tools and documentation making it possible to extend the device’s capabilities.
Read on for our image-heavy unboxing and initial impressions.
