A Simple Commodore 64 Cart Dumper
c64
While [Rob] was digging around in his garage one day, he ran across an old Commodore 64 cartridge. With no ROM to be found online, he started wondering what was stored in this ancient device. Taking a peek at the bits stored in this cartridge would require dumping the entire thing to a modern computer, and armed with an Arduino, he created a simple cart dumper, capable of reading standard 8k cartridges without issue.
The expansion port for the C64 has a lot of pins corresponding to the control logic inside these old computers, but the only ones [Rob] were really interested in were the eight data lines and the sixteen address lines. With a little bit of code, [Rob] got an Arduino Mega to step through all the address pins and read the corresponding data at that location in memory. This data is then sent over USB to a C app that dumps everything in HEX and text.
While the ROM for just about every C64 game can be found online, [Rob] was unlucky enough to find one that wasn’t. It doesn’t really matter, though, as we don’t know if [Rob] has the 1541 disk drive that makes this cart useful. Still, it’s a good reminder of how useful an Arduino can be when used as an electronic swiss army knife.
Upgraded Nerf Gun Keeps Track Of Your Ammo
[Paul] and his buddy [Jonathan] recently had a zombie themed Larp event to go to, so in the spirit of making the experience more realistic, they decided to upgrade their Nerf N-Strike Stryfe gun.
They started by cracking open the gun and making note of the available space for a few bells and whistles. Luckily, thanks to traditional plastic injection molding practices — there’s lots of room!
Upgrades include a magazine sensor, a jam sensor, a trigger sensor and a voltmeter to make the gun a little bit smarter. A knockoff Arduino Pro Mini takes in all these inputs and outputs it to a 7-segment LED display for easy visibility. Our favorite part is the ammo sensor, which keeps a tally of how many shots you’ve used. It’s simply an IR photo-diode and IR transistor in a Darlington configuration, connected to the GPIO interrupt pin on the fake Arduino.
Continue reading “Upgraded Nerf Gun Keeps Track Of Your Ammo”
A Most Impractical Gear Position Indicator
GPI A few years ago, [Pat] sent in a really nice gear position indicator for his Suzuki V-Strom. With a single seven-segment display , a small microcontorller, and wires tied right into the bike’s ECM, it’s more than enough to do its job, and is much cheaper than aftermarket gear indicators. A simple, elegant solution that does one job well. How could this possibly be any better?
‘Better’ is a relative term, and depending on what you’re optimizing for, a more complex solution can easily be superior. [Pat] figured tripling the value of his motorcycle is a worthwhile goal, so he replaced that seven-segment display with an oscilloscope. It’s the world’s only oscilloscope based motorcycle gear position indicator, and now [Pat] needs a really, really long extension cord.
Like the earlier, more practical version, This build reads the voltage off the bike’s ECM to determine what gear the bike is in. The current gear is then displayed on a Tek MDO3000 with two PWM pins on a microcontroller. Practical? No, but it does look cool. Video below.
Continue reading “A Most Impractical Gear Position Indicator”
ServoBender, The Electronic Pedal Steel
You’ve most certainly heard a pedal steel guitar before, most likely in any ‘old’ country song, or more specifically, any country song that doesn’t include the word ‘truck’ in its lyrics. Pedal steels are strange devices, looking somewhat like a 10-string guitar with levers that change the pitch of individual strings. Historically, there have been some attempts to put a detuning mechanism for individual strings in normal electric guitars, but these are somewhat rare and weird. [Gr4yhound] just nailed it. He’s come up with the perfect device to emulate a pedal steel in a real guitar, and it sounds really, really good.
The imgur album for this project goes over the construction of the ServoBender in a bit more detail than the video. Basically, four servos are mounted to a metal plate below the bridge. Each servo has a spring and cam system constructed out of 3D printed parts. The detuning is controlled by an Arduino and a few sustain pedals retrofitted with hall effect sensors. Simple, really, but the effect is astonishing.
[Gra4hound]’s contraption is actually very similar to a B-Bender where a guitarist pushes on the neck to raise the pitch of the B string. This setup, though, is completely electronic, infinitely adjustable, and can be expanded to all six strings. Very, very cool, and it makes us wonder what could be done with one of those freaky robot guitars, a soldering iron, and a bit of code.
Video below, because you should watch it again.
Continue reading “ServoBender, The Electronic Pedal Steel”
Light Pen Draws On LED Matrix
dot-matrix01
Who needs a 1920×1080 OLED display when you can have an 8×8 matrix of LED goodness? That’s the question [Kathy] asked when she built this LED matrix light pen project. It looks simple enough – a 64-LED matrix illuminates as the pen draws shapes. But how does the circuit know which LED is under the pen? Good old fashioned matrix scanning is the answer. Only one LED is lit up at any time.
[Kathy] used a pair of 74LS138 3-to-8 line decoders to scan the matrix. The active low outputs on the ‘138 would be perfect for a common cathode matrix. Of course [Kathy] only had a common anode matrix, so 8 PNP transistors were pressed into service as inverters.
The pen itself is a phototransistor. [Kathy] originally tried a CdS photoresistor, but found it was a bit too slow for matrix scanning. An LM358 op-amp is used to get the signal up to a reasonable level for an Arduino Uno to detect.
The result is impressive for such a simple design. We’d love to see someone use this platform as the start of an epic snake game.
THP Entry: TOME, The Portable 3D Printer
TOME Alright, 3D Printers exist. They’re machines you can simply buy for a few hundred dollars, set them on your desk, and have them start churning out plastic parts. A little pedestrian, isn’t it? How about something you can take into the field for a client, and print out some new parts right there? How about sending a printer to the latest humanitarian crisis? After all, all those humanitarian uses for 3D printers we’ve been hearing about won’t do any good without a 3D printer.
TOME is [Philip]’s attempt at portabilizing a 3D printer and also his entry into The Hackaday Prize. The preliminary goals for TOME are the ability to print for four hours on a single battery, an auto leveling bed, and an accessible hot end that’s easy to replace.
Already the design for TOME is rather interesting. The astute printer aficionado will notice there is no stepper motor on the X carriage. The task of moving the head in the X axis is taken care of by a stepper in the base, with a square shaft and set of gears moving everything back and forth.
With this odd yet ingenious motor setup, the entire printer is able to collapse in on itself, allowing it to be installed in a waterproof plastic case. That’s something you’re going to need if you’re taking a printer on the road.
SpaceWrencherThe project featured in this post is an entry in The Hackaday Prize. Build something awesome and win a trip to space or hundreds of other prizes.
The Future Of Distraction, Right In Front Of Your Face
Bird
Say you’re meeting someone new, and instead of communicating like a normal person that wasn’t born in a barn, they play with their phone the entire time. How about a cashier or sales person who is so insufferably distracted with the Facebooks you’d guess they had a side job in the QA department of some developer? All these things will soon be a distant, horrible memory, because now you can play Flappy Bird on Google Glass.
[Rich] has had his Glass for a while now, and has been meaning to write an app for it. It took a little bit of inspiration, but when the idea of using the eye sensor to control everyone’s favorite 8-bit bird, everything fell into place. It ended up being an interesting use for the Glass, and something we actually wouldn’t mind trying out.
The bird is controlled by a double blink. In the video below, you can see there might be a little bit of latency depending on how [Rich] put the video together. Better grab that .APK while there’s still time. [Rich] says it’s a free download for anyone who’s already overpaid for a Google Glass.
Continue reading “The Future Of Distraction, Right In Front Of Your Face”
