When robots take over the earth, it will be important that they maneuver across various types of terrain quickly and effectively. Bipedal motion is a tricky feat to accomplish for machines, so [Carter Hurd] decided, why not invent a better wheel? Even wheels can be improved, right?
Making excellent use of the prototyping capabilities of a 3D printer, [Carter] designed a set of bulb-shaped mechanisms which act effectively to drive themselves around on a smooth surface. The bulb is split radially into a series of wedge slices which can articulate outward, transforming the robot into something of a spiky razor-beast, able to tear through piles of fall leaves or wakes of loose sand. In order to unfurl itself however, the shaft driving the central mounting plate of the wedges has to fight the robot’s own weight. To solves this, [Carter] modified his design so that the rest of the wedges would unfold around the one supporting the load, the wheels would then rotate to shift the weight, allowing the last piece to extend.
[Carter] shows a proof of concept from earlier this year, explaining his hinge design which stretches a tendon-like connector in order to tension the wedges in one state or the other. Since then it looks like his transforming wheel has evolved a bit. You can get a better view of his robot in action here :
Continue reading “Reinventing The Wheel Makes For A Better Wheel…”
