Getting A Rise With Laser Cutting
Your first 3D print probably seemed pretty amazing. But if you revisit it after a few years, you’ll likely notice it wasn’t nearly as good as you thought. We improve our printers and our processes and the new better results become normal. If you have a laser cutter, you may go through the same iteration. At first, you are happy just to get scorch marks on the workpiece. But when you move to cutting, you want cleaner cuts. You put tape over the work, add air assist, and invest in a honeycomb bed. Each step gets you better results, but you can always improve.
[The Louisiana Hobby Guy] (also known as [Rich]) knows a lot about the practical side of lasers. He suggests using standoff pins to not just secure the part to the honeycomb bed but lift it up a little, allowing air to flow under the part and lets the laser easily cut all the way through. You can see them in action in the video below.
This is a cheap upgrade to prevent flashback when cutting. [Rich] explains how to size them properly and even how to make your own if you don’t want to buy them off the shelf. You can laser cut hold-down pins from plans [Rich] provides, although he prefers to 3D print them, and you can do that, too. Most beds look similar, but if yours is an oddball, you might have to modify them slightly. He has regular dog clamps and the antiflashback standoffs, so you can make some of each. You can also buy them online. Most do not have the antiflashback feature, but at least one vendor that [Rich] points out does have them
If you don’t like the ones [Rich] shows, you can find 3D models for similar pins in the usual places. You can also design them yourself if you want them exactly how you want.
A good thing to add to your laser cutting workflow. [Rich’s] channel is full of great stuff. If you want to know more about air assist, we’ve added it to our cutters. If you are serious about precision cuts, know your kerf, too.
Continue reading “Getting A Rise With Laser Cutting” →
This Week In Security: Bogus CVEs, Bogus PoCs, And Maybe A Bogus Breach
It appears we have something of a problem. It’s not really a new problem, and shouldn’t be too surprising, but it did pop up again this week: bogus CVEs. Starting out in the security field? What’s the best way to jump-start a career? Getting a CVE find to your name certainly can’t hurt. And as a result, you get very junior security researchers looking for and reporting novel security vulnerabilities of sometimes dubious quality. Sometimes that process looks a lot like slinging reports against the wall to see what sticks. Things brings us to an odd bug report in the OBS Studio project.
A researcher put together a script to look for possible password exposure on Github projects, and it caught a configuration value named “password” in a .ini file, being distributed in the project source. Obvious credential leak in Git source, right? Except for the little detail that it was in the “locale” folder, and the files were named ca-es.ini, ja-jp.ini, and similar. You may be in on the joke by now, but if not, those are translation strings. It wasn’t leaked credentials, it was various translations of the word “password”. This sort of thing happens quite often, and from the viewpoint of a researcher looking at results from an automated tool, it can be challenging to spend enough time with each result to fully understand the code in question. It looks like this case includes a language barrier, making it even harder to clear up the confusion.
Things took a turn for the worse when a CVE was requested. The CVE Numbering Authority (CNA) that processed the request was MITRE, which issued CVE-2023-34585. It was a completely bogus CVE, and thankfully a more complete explanation from OBS was enough to convince the researcher of his error. That, however, brings us back to CVE-2023-36262, which was published this week. It’s yet another CVE, for the same non-issue, and even pointing at the same GitHub issue where the alleged bug is debunked. There’s multiple fails here, but the biggest disappointment is MITRE, for handing out CVEs twice for the same issue. Shout-out to [Netspooky] on Twitter for spotting this one. Continue reading “This Week In Security: Bogus CVEs, Bogus PoCs, And Maybe A Bogus Breach” →
Improved Hydrogen Fuel Cells Are Groovy
According to [Charles Q. Choi], a new study indicates that grooves in the hydrogen fuel cells used to power vehicles can improve their performance by up to 50%. Fuel cells are like batteries because they use chemical reactions to create electricity. Where they are different is that a battery reacts a certain amount of material, and then it is done unless you recharge it somehow. A fuel cell will use as much fuel as you give it. That allows it to continue creating electricity until the fuel runs out.
Common hydrogen fuel cells use a proton exchange membrane — a polymer membrane that conducts protons to separate the fuel and the oxidizer. You can think of it as an electrolyte. Common fuel cells use an electrode design that hasn’t changed in decades. The new research has catalyst ridges separated by empty grooves. This enhances oxygen flow and proton transport.
Conventional electrodes use an ion-conducting polymer and a platinum catalyst. Adding more polymer improves proton transport but inhibits oxygen flow. The grooved design allows for dense polymer on the ridges but allows oxygen to flow in the grooves. In technical terms, the proton transport resistance goes down, and there is little change in the oxygen transport resistance.
The grooves are between one and two nanometers wide, so don’t pull out your CNC mill. The researchers admit they had the idea for this some time ago, but it has taken several years to figure out how to fabricate the special electrodes.
Creating A Joule-Thomson Cryocooler And A Little Bit Of History At Home
The fun part about crycoolers is that there are so many different and exciting ways to make stuff cold, based on a wide variety of physics. This is why after first exploring the Stirling/GM cycle and vapor-compression to create a cryocooler that he could liquefy nitrogen with, [Hyperspace Pirate] is exploring a Joule-Thomson cooler, which is also misspelled as ‘Joule-Thompson’ by those who don’t mind take some liberties with history. Either way, the advantage of the adiabatic Joule-Thomson effect is that it is significantly simpler than the other methods — having been invented in the 19th century and used for the earliest forms of refrigeration.
This is what peak Joule-Thomson prototype cooler performance looks like.
The big difference between it and other technologies is that the effect is based on throttling the flow of a gas as it seeks to expand, within specific temperature and pressure ranges to ensure that the temperature change effect is positive (i.e. the temperature of the gas decreases). The net result is that of a cooling effect, which as demonstrated in the video can be used with successive stages involving different gases, or a gas mixture, to reach a low enough temperature at which nitrogen (contained in the same gas mixture) liquefies and can be collected.
Although not a very efficient process, if your local electricity costs allow it, running the compressor in a closed loop version isn’t that expensive and worth it for the science alone. Naturally, as with any experimental setup involving a range of gases, a compressor and other components, getting it to run perfectly on the first try is basically impossible, which is why this is so far Part 1 of another series on cryocoolers at home (or in the garage).
If you’re interested in the previous work [Hyperspace Pirate] has done with DIY cyrocoolers, take a look at our coverage from earlier this year.
Continue reading “Creating A Joule-Thomson Cryocooler And A Little Bit Of History At Home” →
