How Hot Is That Soldering Iron?
It is common these days to have a soldering iron where you can set the temperature using some sort of digital control. But how accurate is it? Probably pretty accurate, but [TheHWCave] picked up a vintage instrument on eBay that was made to read soldering iron temperature. You can see the video below, which includes an underwhelming teardown.
The device is a J thermocouple and a decidedly vintage analog meter. What’s inside? Nearly nothing. So why did the meter not read correctly? And where is the cold junction compensation?
Continue reading “How Hot Is That Soldering Iron?”
Building A DIY MSX Mega Cartridge
[Mike] from Leaded Solder has a soft spot for old computers, and a chance encounter with a friend sent them deep down the deep hole that is the world of 80s and 90s-era Japanese home computers.  Many people playing with these machines have all kinds of issues to deal with, such as rotting cartridges, failing components, and just dirt and mank in critical places. [Mike] decided that working on an MSX-standard custom programmable cartridge would be sensible, but then got stuck on how the MSX cartridge mapping works.
The Konami 128K scheme uses 4 to 4-of-8 mapping.
You may recall that the MSX platform is not a single computer but a standard to which many (mainly Japanese) manufacturers designed their products. This disconnected the software writers from the hardware makers and is essentially a mirror of the IBM-PC clone scene.
The MSX is based around the Z80, which has a 16-bit address bus, restricting it to 64K of ROM or RAM. The MSX has two cartridge slots, an ‘internal’ slot for the BIOS and RAM and a fourth for ‘misc’ use. Each of these is mapped internally into the physical address space. The cartridge slots have 64K of addressable space mapped into the Z80 physical space.
If this was not complicated enough, many MSX games and applications exceeded this restriction and added a layer of mapping inside the cartridge using bank switching. A register in the cartridge could change the upper bits of the address allowing ROMs larger than 64K.
Continue reading “Building A DIY MSX Mega Cartridge”
Rendering Skin Transparent Using The Food Dye Tartrazine
Although we generally assume that opacity is the normal look for animals like us humans, this factoid is only correct for as long as you maintain the dissimilar optical refraction indices of skin and the more aqueous underlying structures. What if you could change the refraction index of skin? If you could prevent the normal scattering at the interface, you could reveal the structures underneath, effectively rendering skin transparent. [Zihao Uo] and others demonstrate this in a paper published in Science.
The substance they used was the common food dye known as tartrazine, which also goes by the names of Yellow 5 and E102 when it is used in food (like Doritos), cosmetics, and drugs. By rubbing the tartrazine into the skin of mice, the researchers were able to observe underlying blood vessels and muscles. Simulations predicted that the dye would change the refraction index mismatch between lipids and water which normally causes the light scattering that creates the skin’s opaque appearance. With the dye rubbed into the skin, the effect worked to a depth of about 3 mm, which makes it useful for some research and possible medical applications, but not quite at the ‘jellyfish-transparency’ levels that some seem to have imagined at the news.
Continue reading “Rendering Skin Transparent Using The Food Dye Tartrazine”
Get Thee To Git
While version control used to be reserved for big corporate projects, it is very mainstream these days. You can attribute much of that to Git, the software that has nearly displaced other version control. Git works well, it is versatile, and it scales well. It is easy to use as an individual developer or as part of a worldwide team. But Git is also one of those things that people don’t always study, they just sort of “pick it up” as they go. That motivated [Glasskube] to create “The Guide to Git I Never Had.”
If you are ready to click away because you are not a software person, hang on. Git is actually useful for many different kinds of data, and there are a number of hardware projects that use Git in some form. That’s especially true if the project has some code associated with it, but there are projects that consist of PCBs, reverse engineering documentation, or schematics.
Continue reading “Get Thee To Git”
Should You Run Servo Horns Or Direct Couplings In Your RC Planes?
Whenever you buy a servo, it usually comes with a little baggie full of various plastic horns. Most of us pick our favorite and use it in our projects. Some of us hack them up, glue them back together, and do all kinds of weird things with them. And others skip them entirely, going for direct drive instead. In a new video, [Dynamix Systems] explores when going direct drive is the right solution.
The video primarily concerns servos as they’re used in the context of aero modeling. In this regard, the video points out that while stock servo horns are easy to use, they can be cumbersome and clumsy. For example, you often end up with horns and control linkages protruding out into the airstream, adding drag and generally making things a bit inelegant. They can also snag on things and easily damage your servos or controls.
Using direct shaft couplers can be a much tidier solution in some respects. The servo can be coupled directly to the axis of motion, allowing it to be hidden inside a wing or tail surface. It can require a little more finesse in installation and design, but they’re much less likely to snag on things or be damaged. There’s also a drag benefit if you do it right. [Dynamix Systems] notes that you’ll want to source some shaft couplers to do this properly, which you can make yourself or buy online fairly easily.
It’s great to see how tidy direct drive really is. We’ve seen some other nifty servo tricks of late, too. Video after the break.
Continue reading “Should You Run Servo Horns Or Direct Couplings In Your RC Planes?”
Fun And Failure
My sister is a beekeeper, or maybe a meta-beekeper. She ends up making more money by breeding and selling new queen bees to other beekeepers than she does by selling honey, but that doesn’t mean that she doesn’t also process the sweet stuff from time to time. She got a free steam-heated oscillating hot knife, used for cutting the waxy caps off of the tops of the cells before spinning the combs down to extract honey, and she thought it might be easier to use than her trusty hand-held electric hot knife.
The oscillating knife, which was built something like a century ago, hadn’t been used in decades. All of the grease had turned to glue, and the large v-belt wheel that made it go was hard to turn by hand, and the motor was missing anyway. So she gave it to my father and me as a project. How could we resist?
We found the original manual on the Internet, which said that it would run from any 1/2 hp motor, or could be optionally driven by a takeoff wheel from a tractor – unfortunately not an option in my sister’s honey house. But we did find a 3/4 hp bench grinder at Harbor Freight that conveniently fit inside the case, and bought the smallest v-belt pulley wheel that would fit the grinder’s arbor. We thought we were geniuses, but when we hooked it all up, it just stalled.
We spent more than a few hours taking the mechanism apart. It was basically an eccentric shaft with a bearing on the end, and the bearing ran back and forth in the groove of a sliding mechanism that the knife blade attached to. As mentioned above, everything was gunked, so we took it all apart. The bearing was seized, so we freed that up by getting the sand out of the balls. The bearing couldn’t move freely in the slide either, but we filed that down until it just moved freely without noticeable play. We added grease from this century, and reassembled it. It turned fine by hand.
But with the belt and motor attached, the mechanism still had just enough friction to stall out the motor. Of course we wrapped some rope around the shaft and pull-started it, and it made a hell of a racket, nearly vibrated itself off the table, and we could see that the marvelous zinc-coated frame that held it all together was racking under the tension. It would require a wholly new housing to be viable, and we hadn’t even figured out a source of steam to heat the knife.
In short, it was more trouble than it was worth. So we packed up the bench grinder in the original container, and returned it no-worse-for-wear to the Freight. But frankly, we had a fantastic time playing around with a noble machine from a long-gone past. We got it “working” even if that state was unworkable, and we were only out the cost of the small v-belt pulley. Who says all of your projects have to be a success to be fun?
A chicken's egg with many holes glows beneath a glass globe set atop an inverted wooden bowl.
Glowing Egg Is A One-Oeuf Solution For Tracking Cycles
Look, if something happened to you every three weeks or so to basically turn you into a different person and factored heavily into whether any new humans were created, you’d probably want to keep abreast of the schedule, yeah? Yeah. So, while there are, of course, a ton of ways to do this with your phone, most of those apps do gross things with your data. Are you angry yet?
A standard chicken's egg with many holes both large and small.[Jakoba the Online Witch] certainly was, or if not angry, at least annoyed. So she built a glowing egg timer, which shines a different color based on current point in her cycle, to let her know when she is fertile and expecting Aunt Flo.
The coolest part is that this is an actual egg from one of [Jakoba]’s backyard chickens. No. The coolest part is how she was able to make so many holes without breaking it. (It took four tries.)
After bleaching the insides, the egg was ready to glow. As [Jakoba] says, the guts are simple — just a Wemos D1 Mini ESP8266, a WS2812 LED, and a heatsink. The enclosure consists of an inverted peanut bowl with a glass ornament hot-glued in place.
Once it was put together, all she had to do was add it in Home Assistant and use the current calendar state to trigger services from the YAML configuration.
Would you prefer an on-body solution? Here’s an earring that tracks temperature.
