Remembering The BBC Computer Literacy Project
There comes a point in everybody’s life when things that they were a part of are presented as history, and for the 8-bit generation, that time is now. It’s interesting to see the early history of 8-bit home computers presented as history, not from a 2026 perspective but from the early 1990s. The BBC archive has recently posted a retrospective from 1992 looking at ten years of the Computer Literacy Project, a British government programme intended to equip the young people of the 1980s with the skills they would need to approach the information age. It’s a much more immediate history of something which was largely still in place at the time, making it a time capsule in which this past isn’t quite the other country we see it as today.
The Computer Literacy Project was run by the nation’s broadcaster and included a raft of TV programming about computers, as well as the commissioning of a machine specifically for the project. You know this machine as the Acorn BBC Micro, and aside from eventually providing the genesis of what would become ARM, it remains one of the most high-spec 8-bit machines in terms of built-in hardware. We hear from the luminaries of Acorn about the development of this machine, and then the film moves into some of the wider cultural effects.
If you were there, you’ll doubtless remember some of the TV programmes featured, and you might have used a BBC Micro at school. If you weren’t there, it’s an encapsulation of the promise on offer in that era, an optimism that seems sad when you reflect that educational computing descended into learning Microsoft Word during the following decade. It would be another two decades before the Raspberry Pi and BBC micro:bit picked up that fallen torch.
The Beeb, it seems, has long had an interest in home computers. Schools, too.
Continue reading “Remembering The BBC Computer Literacy Project” →
British Train Departures As They Should Be Viewed
The first generation of real-time train information screens for British railways came in the form of suspended color CRTs in familiar rounded fiberglass housings. They were a ubiquitous sight across the network for years, until of course suddenly, they weren’t. Can they be brought back? [Heliomass] has come about as close as it’s possible to be, with a modern emulation that runs from live data feeds.
The screens were recognizably using the same graphics standards as Teletext, and thus it was no surprise back in the day to see from time to time an Acorn boot screen in a railway station.
We remember some debate at the time as to whether they were running Archimedes of BBC Micro hardware behind the scenes, though it seems likely it might have been the industrial BBC Micro derivative.
The modern recreation uses an emulated BBC Micro for the signage, with a serial connection to a server component running in Python on more modern hardware. This handles grabbing the data and sending it to the Beeb for display. The result is an unexpected bit of nostalgia for anyone who spent the 1980s or ’90s in south east England.
Take A Little Bit Of Acorn To Work
When we think of 8-bit computers, it’s natural to start with home computers. That’s where they live on in the collective memory. But a Z80, a 6502, or similar was more likely to be found unseen in a piece of industrial machinery, doing the job for which we’d today reach for a microcontroller. Sometimes these two worlds intersected, and thus we come to the EuroBEEB, a derivative of Acorn’s BBC Micro on a Eurocard. [Steve Crozier] has performed extensive research into this system and even produced a recreated PCB, providing a fascinating window into embedded computing in the early 1980s.
The EuroBEEB was the work of Control Universal, a Cambridge-based company specialising in embedded computers. They produced systems based upon 6502 and 6809 processors, and joining their product line to the then-burgeoning BBC Micro ecosystem would have been an obvious step. The machine itself is a Eurocard with a simple 6502 system shipped with ACORN BBC Basic on ROM, and could be seen as a cut-down BBC Micro with plenty of digital I/O, accesible through a serial port. It didn’t stop there though, as not only could it export its graphics to a “real” BBC Micro, it had a range of expansion Eurocards that could carry the missing hardware such as analogue input, Teletext, or high-res graphics.
The reverse-engineered PCB comes from analysis of surviving schematics, and included a couple of gate array logic chips to replace address decoding ROMs in the original. If it seems overkill for anyone used to a modern microcontroller, it’s worth remembering that by the standards of the time this was a pretty simple system. Meanwhile if you only fancy trying BBC BASIC, there’s no need to find original hardware.
Old BBC Micro Gets Some Disk Help From A Raspberry Pi
[Peter Mount] had a simple problem. He’d treated himself to a retro purchase in the form of a BBC Master 128—a faster sequel to the BBC Micro Model B. The only problem was he needed a way to get software on to it. Cue a creative hack using a Raspberry Pi Zero W.
When [Peter] received the machine, it already had a GoTek floppy emulator, which pulled disk images off a USB drive. However, he wanted an easier and quicker way to get disk images to and from the machine for development purposes. Swapping the USB drive to and from another machine seemed too tedious.
Instead, he decided to swap in a Pi Zero W for this purpose, setting it up to emulate a flash drive by following instructions from MagPi Magazine. This would allow him to use the SCP tool to copy disk images over to the Pi Zero W via its WiFi connection. Basically, the Pi Zero W was acting as a wirelessly-updated storage device hooked up to the GoTek floppy emulator.
It’s a nifty way of doing things. [Peter] could have set about creating his own floppy emulator from scratch with wireless capability included. However, there was no need. He just needed a wirelessly-accessible USB drive, and the Pi Zero W was more than happy to act in that role.
The BBC Micro is a beloved machine of many in the British Isles, and it had rather an extended family. If you’ve pulled off your own nifty hack on this classic machine, be sure to hit us up on the tipsline!
Documented Source Code For Elite On The C64, BBC Micro And Others
If you ever wanted to dive into the source code for the 1980s space game Elite, but didn’t want to invest many hours reverse-engineering the 6502 assembly code, then [Mark Moxon]’s annotated code has you covered. The systems referenced range from the BBC Micro and Commodore 64 to the NES and Apple II, with some of these versions based on the officially released source code. For other systems the available source code was used together with decompiled game binaries to determine the changes and to produce functional, fully commented source code.
The cutting-edge gameplay of Elite on the 8502.
This particular game is fascinating for being one of the first to use wire-frame 3D graphics with hidden-line removal and a sprawling universe in which to trade and deal with less than friendly parties using a variety of weapons. After this initial entry it would go on to spawn many sequels and inspired countless games that’d follow a similar formula.
On the respective GitHub project page for each version, you can find instructions on how to build the code for yourself, such as for the Commodore 64. Of note here is the license, which precludes anyone from doing more than forking and reading the code. If this is no concern, then building the game is as simple as using the assembler (BeebAsm) and the c1541 disk image utility from the VICE project.
Screen caps of upgraded BBC Micro, and OS 9 code
BBC Micro: A Retro Revamp With The 68008 Upgrade
The BBC Microcomputer, launched in the early 1980s, holds a special place in computing history. Designed for educational purposes, it introduced a generation to programming and technology. With its robust architecture and community-driven modifications, the BBC Micro remains a beloved project for retro computing enthusiasts. [Neil] from Retro4U has been delving into this classic machine, showcasing the fascinating process of repairing and upgrading his BBC Micro with a 68008 CPU upgrade.
Last week, [Neil] shared his progress, unveiling advancements in his repairs and upgrades. After tackling a troublesome beep issue, he successfully managed to get the BBC running with 32 KB of functional memory, allowing him to boot into BASIC. But he wasn’t stopping there. With ambitions set on installing the 68008 CPU, [Neil]’s journey continued.
The 68008 board offers significant enhancements, including multitasking capabilities with OS-9 and its own hard drive and floppy disk controller. However, [Neil] quickly encountered challenges; the board’s condition revealed the usual broken capacitors and a few other faulty components. After addressing these issues, [Neil] turned his attention to programming the necessary ROM for OS-9.
Looking to get your hands dirty? [Neil] has shared a PDF of the upgrade circuit diagram. You can also join the discussion with fellow enthusiasts on his Discord channel, linked in the video description.
Continue reading “BBC Micro: A Retro Revamp With The 68008 Upgrade” →
Celebrating The [Jack Ells] Automatic Photometric Telescope
Here at Hackaday, we take pride in presenting the freshest hacks and the best of what’s going on today in the world of hardware hacking. But sometimes, we stumble upon a hack from the past so compelling that we’ve got to bring it to you, so we can all marvel at what was possible in the Before Times.
This one, a completely homebrewed automatic photometric telescope, was designed and built by the father-son team of [Jack Ells] and [Peter Ells]. From the elder [Ells]’ field notes, the telescope saw its first light in 1988, giving us some idea of the scale of problems that had to be overcome to get this wonderful machine working. The optics are straightforward, as least as telescopes go — it’s an f-4.0 Newtonian reflector with an 8.5″ (221 mm) primary mirror on an equatorial mount. The telescope is very rugged-looking indeed, and even stands on brick piers for stability. The telescope’s mount is controlled by a BBC Micro running custom BASIC software.
For the photometric parts, the [Ells] boys installed a photo-multiplier tube at the focus of the telescope. More precisely, they used a liquid light guide to connect the eyepiece to a rack full of equipment, which included the PM tube, its high-voltage power supply, and a series of signal conditioners and counter circuits. The idea was to view a single star through a pinhole mask over the objective of the telescope and count the rate of photons received over time. Doing so would reveal periodic changes in the star’s brightness. Today we’d use similar data to search for exoplanet transits; while we don’t think that was a thing back in 1988, it looks like this telescope could easily have handled the job.
Sadly, [Jack Ells] died only two years after finishing the telescope. But he left it with his son, who eventually moved it to a location with better seeing conditions, where it gathered data for another eight years. The quality of the work is amazing, and as father-son projects go, this one is tough to beat.
Continue reading “Celebrating The [Jack Ells] Automatic Photometric Telescope” →
