Oral-B Hopes You Didn’t Use Your $230 Alexa-Enabled Toothbrush
With companies desperate to keep adding more and more seemingly random features to their products, Oral-B made the logical decision to add Alexa integration to its Oral-B Guide electric toothbrush. Taking it one step beyond just Bluetooth in the toothbrush part, the Guide’s charging base also acted as an Alexa-enabled smart speaker, finally adding the bathroom to the modern, all-connected smart home. Naturally Oral-B killed off the required Oral-B Connect smartphone app earlier this year, leaving Guide owners stranded in the wilderness without any directions. Some of the basics of this shutdown are covered in a recent Ars Technica article.
Amidst the outrage, it’s perhaps good to take a bit more of a nuanced view, as despite various claims, Oral-B did not brick the toothbrush. What owners of this originally USD$230 device are losing is the ability to set up the charging base as an Alexa smart speaker, while the toothbrush is effectively just an Oral-B Genius-series toothbrush with Bluetooth and associated Oral-B app. If you still want to have a waterproof smart speaker listening in while in the bathroom, you’ll have to look elsewhere, it seems. Meanwhile existing customers can contact Oral-B support for assistance, while the lucky few who still have the Connect app installed better hope it doesn’t disconnect, as reconnecting it to the smart speaker seems to be impossible, likely due to services shut down by Oral-B together with the old “oralbconnect.com” domain name.
We recently looked at a WiFi-enabled toothbrush as well, which just shows how far manufacturers of these devices are prepared to go, whether they intend to support it in any meaningful fashion or not.
Put More Power In Your Dental Hygiene Routine!
What do you do, when you move into a shared apartment and find only one socket is available among four electric toothbrushes? Revert to an old-style manual brush? If you’re [luisengineering], not a bit of it. He’s modified an electric toothbrush with the only sensible power plant, a three-horsepower twin cylinder four-stroke gasoline motor. You’ll need to turn on translated subtitles from the original German to watch it, but we hope you’ll agree it’s worth it.
After explaining the problem, the video below the break continues with the assembly of the motor, a model unit available through the usual online suppliers. This alone is interesting, for no doubt many of us have seen these motors for sale and retain some curiosity about them. We expected him to retain the electric drive for the toothbrush and use a generator, but instead, he hooks up the motor via a shaft directly to the input gear. With three horsepower behind the brush, this will surely shift that stubborn plaque! Astoundingly as you can see in the video below the break the contraption works, and both he and a friends perform their dental ablutions with it.
We like the blend of craziness and engineering embodied by this project, and we commend it to you on that basis. If you’re short of electric toothbrush modding ideas, how about an engraving tool?
Continue reading “Put More Power In Your Dental Hygiene Routine!” →
Hacking A “Smart” Electric Toothbrush To Reset Its Usage Counter
The visible circuitry inside the brush head.
Following the trend of stuffing more electronics in everyday devices, the new Philips Sonicare electric toothbrush that [Cyrill Künzi] purchased ended up having a ‘brush head replacement reminder’ feature that wasn’t simply a timer in the handle or base of the unit, but ended up involving an NFC chip embedded in every single brush head containing the usage timer for that particular head. Naturally, this asked for it to be solidly reverse-engineered and hacked.
The NFC chip inside the brush head turned out to be an NXP NTAG213, with the head happily communicating with the NFC reader in a smartphone and the NFC Tools app. This also revealed the memory layout and a few sections that had write access protected by a password, one of which was likely to be the counter. This turned out to be address 0x24, with a few experiments showing the 32-bit value at this address counting the seconds the brush head had been used.
Continue reading “Hacking A “Smart” Electric Toothbrush To Reset Its Usage Counter” →
Toothbrush Goes From Mouth-Whitening To Room-Brightening
Some of the hacks we see make us wonder why they aren’t already a commercial product, and this electric toothbrush turned rechargeable flashlight is one of them. Sure, these things exist, but we haven’t seen one with a dedicated charging stand. They usually just take micro USB or whatever, so it’s on you to remember to plug it in. How great would it be to have a fully-charged flashlight always at the ready, especially one in a position to illuminate the room? Although [wannabemadsci] makes it look easy, this conversion took quite a bit of doing.
Perhaps the most amazing part is that [wannabemadsci] found a halfway decent flashlight at the dollar store. Better than average, this thing has a main light, a side light, and takes 3xAAs instead of a couple of AAAs. The only issue is that the toothbrush batteries don’t quite put out enough voltage for the flashlight’s LED, so [wannabemadsci] used a booster board.
Of course, there’s a lot more to this hack than sawing off the USB connector from the boost converter so it fits. The toothbrush handle had to be modified to accept the flashlight guts, and the threads relocated from the flashlight. Since the battery charge indicator shines through the momentary button on the toothbrush, [wannabemadsci] wanted to reuse it, but it required a small board that converts it to a latching push button. Finally, the flashlight bezel had to be painted white. Paint is such an easy thing to do, and this detail makes all the difference in how professional this looks.
There’s a lot you can do with a functioning electric toothbrush as your base, like brute-forcing the pins of a lock with vibration.
An assortment of whole-mouth toothbrushes that brush all of your teeth at once, in the span of 30 seconds.
Don’t Bristle; Teethbrush Won’t Hurt You
A whole-mouth toothbrush that brushes all of your teeth at once, in the span of 30 seconds.Good dental hygiene is the first line of defense when it comes to your health, and– you’re already bored, aren’t you? It’s totally true, though. Take care of your teeth, and the rest of you has a better chance of staying fairly healthy.
This is like, the one thing we have control over after diet and exercise, and most people just plain fail on this front. They brush for 30 seconds, tops. Or they rarely floss. Maybe they’ve never even considered brushing or scraping their tongue.
Okay, fine. You don’t want to spend the recommended two minutes twice a day working the brush around your mouth. The good news is, technology has finally caught up with you and your habits, if you can call them that. How about using something that can truly be called a teethbrush? As in, it brushes all of your teeth at once? Well, half of your teeth anyway. Allegedly, you can spend as little as 10 seconds on each arch and effectively scour your smile — that’s because the thing vibrates at an astonishing 40,000 per minute or so.
Sounds kind of scary, doesn’t it? Wait ’til you hear how much they cost. One brand is $150 off the bat, and replacement heads are close to $40 each, although they’re supposed to last for six months each (eww!). Most of them have some fancy extras that make the cost more palatable, such as a tooth-whitening mode.
What do you think? Would you use a teethbrush? We’re still on the fence. It could be interesting to develop our own, but you have to crawl before you can run. Guess we’ll start with a manual.
When Toothbrushes, Typewriters, And Credit Card Machines Form A Band
Many everyday objects make some noise as a side effect of their day job, so some of us would hack them into music instruments that can play a song or two. It’s fun, but it’s been done. YouTube channel [Device Orchestra] goes far beyond a device buzzing out a tune – they are full fledged singing (and dancing!) performers. Watch their cover of Take on Me embedded after the break, and if you liked it head over to the channel for more.
The buzz of a stepper motor, easily commanded for varying speeds, is the easiest entry point into this world of mechanical music. They used to be quite common in computer equipment such as floppy drives, hard drives, and flatbed scanners. As those pieces of equipment become outdated and sold for cheap, it became feasible to assemble a large number of them with the Floppotron being something of a high-water mark.
After one of our more recent mentions in this area, when the mechanical sound of a floppy drive is used in the score of a motion picture, there were definite signs of fatigue in the feedback. “We’re ready for something new” so here we are without any computer peripherals! [Device Orchestra] features percussion by typewriters, vocals by toothbrushes, and choreography by credit card machines with the help of kitchen utensils. Coordinating them all is an impressive pile of wires acting as stage manager.
We love to see creativity with affordable everyday objects like this. But we also see the same concept done with equipment on the opposite end of the price spectrum such as a soothing performance of Bach using the coils of a MRI machine.
[Thanks @Bornach1 for the tip]
Continue reading “When Toothbrushes, Typewriters, And Credit Card Machines Form A Band” →
Hacked Electric Toothbrush Defeats Locks With Ease
The movie version of lockpicking tends to emphasize the meticulous, delicate image of the craft. The hero or villain takes out a slim wallet of fine tools, applies them with skill and precision, and quickly defeats the lock. They make it look easy, and while the image isn’t far from reality, there are other ways to pick a lock.
This expedient electric toothbrush lockpick is a surprisingly effective example of the more brute force approach to lockpicking. As [Jolly Peanut] explains, pin tumbler locks work by lining up each pin with the shear line of the cylinder, which allows the lock to turn. This can be accomplished a pin at a time with picks, or en masse by vibrating the pins until they randomly line up with the shear line just long enough for the lock to turn. A locksmith might use a purpose-built tool for the job, but a simple battery-powered electric toothbrush works in a pinch too. [Jolly Peanut] removed the usual business end of the brush to reveal a metal drive rod that vibrates at a high frequency. The rod was slimmed down by a little grinding to fit into the keyway of a lock, and with the application of a little torque, the vibration is enough to pop the pins into the right position. He tries it out on several locks in the video below, and it only takes a few seconds each time.
Such brute force methods have their drawbacks, of course. They’re not exactly subtle, and the noise they create may attract unwanted attention. In that case, hone your manual lockpicking skills with a giant 3D-printed see-through lock.
Continue reading “Hacked Electric Toothbrush Defeats Locks With Ease” →
