Announcing The 2025 Hackaday Superconference Communicator Badge
It’s the moment you hard-core hardware nerds have been waiting for: the reveal of the 2025 Hackaday Supercon Communicator Badge. And this year, we’ve outdone ourselves, but that’s thanks to help from stellar collaboration with folks from the community, and help from sponsors. This badge is bigger than the sum of its parts, and we’ve planned for it to be useful for you to hack on in the afterlife. Indeed, as always, you are going to be the final collaborator, so we can’t wait to see what you’ll do with it.
We’re going out – wide out – on a limb and trying to create a dense mesh network of badges talking to each other at Supercon. It’s going to be like a badge-hosted collection of chat rooms, as connected as we can make them without talking over each other.
You look up a topic, say Retro Computing or SAO trading, punch in the channel number on the numpad, and your badge starts listening to everything going on around that topic. But they also listen to everything else, and repeat anything they hear on to their neighbors. Like IRC, but LoRa.
Continue reading “Announcing The 2025 Hackaday Superconference Communicator Badge”
Front and back view of the 13.7" monitor kit
Modos Is Open Hardware, Easy On The Eyes
Since e-ink first hit the market a couple decades back, there’s always murmurs of “that’d be great as a second monitor”— but very, very few monitors have ever been made. When the commecial world is delivering very few options, it leaves room for open source hardware projects, like the Modos Glider and Paper Monitor, projects now seeking funding on Crowd Supply.
As far as PC monitors go, the Modos isn’t going to win many awards on specs alone. The screen is only 13.3″ across, and its resolution maxes out at 1600 x 1200. The refresh rate would be totally unremarkable for a budget LCD, at 75 Hz. This Paper Monitor isn’t an LCD, budget or otherwise, and for e-ink, 75 Hz is a blazing fast refresh rate. Continue reading “Modos Is Open Hardware, Easy On The Eyes”
Who Is Your Audience?
Here at Hackaday HQ, we all have opinions about the way we like to do things. And no surprise, this extends to the way we like to lay out circuits in schematics. So when we were discussing our own takes on this piece on suggested schematic standards, it was maybe more surprising how much we did agree on than how much we had different preferred styles. But of course, it was the points where we disagreed that provoked the most interesting discussion, and that’s when I had a revelation.
Besides torturing electronics, we all also write for you all, and one thing we always have in mind is who we’re writing for. The Hackaday audience, not to blow you up, is pretty knowledgeable and basically “full-stack” in terms of the hardware/software spectrum. This isn’t to say that everyone is a specialist in everything, though, and we also have certain archetypes in mind: the software type who is just starting out with hardware, the hardware type who isn’t as savvy about software, etc. So, back to schematic layout: Who is your audience? It matters.
For instance, do you organize the pinout for an IC by pin number or by pin function, grouping the power pins and the ADC pins and so on? If your audience is trying to figure out the circuit logic, you should probably go functional. But if you are trying to debug a circuit, you’re often looking at the circuit diagram to figure out what a given pin does, and the pin-number layout is more appropriate.
Do you lay out the logical flow of the circuit in the schematic, or do you try to mimic the PCB layout? Again, it could depend on how your audience will be using it. If they have access to your CAD tool, and can hop back and forth seamlessly from schematic to PCB, the logical flow layout is the win. However, if they are an audience of beginners, or stuck with a PDF of the schematic, or trying to debug a non-working board, perhaps the physical layout is the right approach.
Al Williams, who has experience with projects of a much larger scale than most of us self-taught hackers, doesn’t even think that a schematic makes sense. He thinks that it’s much easier to read and write the design in a hardware description language like VHDL. Of course, that’s certainly true for IC designs, and probably also for boards of a certain complexity. But this is only true when your audience is also familiar with the HDL in question. Otherwise, you’re writing in Finnish for an audience of Spaniards.
Before this conversation, I was thinking of schematic layout as Tom Nardi described it on the podcast – a step along the way to get to the fun parts of PCB layout and then to getting the boards in hand. But at least in our open-source hardware world, it’s also a piece of the documentation, and a document that has an audience of peers who it pays to keep in mind just as much as when I’m sitting down and writing this very newsletter. In some ways, it’s the same thing.
(And yeah, I know the featured image doesn’t exactly fit the topic, but I love it anyway.)
Open Source Watch Movement Really Ticks All The Boxes
When you think of open-source hardware, you probably think of electronics and maker tools– RepRap, Arduino, Adafruit, et cetera. Yet open source is an ethos and license, and is in no way limited to electronics. The openmovement foundation is a case in point– a watch case, to be specific. The “movement” in Openmovement is a fully open-source and fully mechanical watch movement.
Openmovement has already released STEP files of OM10 the first movement developed by the group. (You do need to sign up to download, however.) They say the design is meant to be highly serviceable and modular, with a robust construction suited for schools and new watchmakers. The movement uses a “Swiss pallets escapement” that runs at 3.5 Hz / 25,200 vph. (We think that’s an odd translation of lever escapement, but if you’re a watchmaker let us know in the comments.)  An OM20 is apparently in the works, as well, but it looks like only OM10 has been built from what we can see.
If you don’t have the equipment to finely machine brass from the STEP files, Openmovement is running a crowdfunding campaign to produce kits of the OM10, which you can still get in on until the seventh of June.
If you’re wondering what it takes to make a mechanical watch from scratch, we covered that last year. Spoiler: it doesn’t look easy. Just assembling the tiny parts of an OM10 kit would seem daunting to most of us. That might be why most of the watches we’ve covered over the years weren’t mechanical, but at least they tend to be open source, too.
Today In Edinburgh: The Open Hardware Summit
Just a quickie for anyone who is in the neighborhood, today the Open Source Hardware Association’s annual Open Hardware Summit conference starts in Edinburgh, Scotland. If you’re able to make it, it’s a microcosm of the open-source hardware world, and full of great talks and great hackers.
If you’re not in Scotland, they have a livestream on YouTube that you should check out, as well as a Discord server for discussions during the event.  It’s going on right now!
Open Source Multimeter Raises The Bar For DIY Tools
Whether you only dabble in electronics as a hobby or it’s your full-time job, there are few tools as indispensable as the multimeter. In fact, we’d be willing to bet nearly everyone reading this site owns at least one of them. But as common and mindbogglingly useful as they may be, they aren’t perfect. Even the high-end models will invariably have some annoyance that only reveals itself once you become intimately acquainted with it.
Most people would just live with those quirks, especially when dealing with a cheaper model. But not [John Duffy]. Deciding nothing but perfection would do, he took every favorite feature he’d ever run into while using other multimeters and combined them into his scratch-built HydraMeter. In the process, he managed to come up with a few new ideas that push this device into a league of its own.
Some of the features of the HydraMeter will look familiar. You might even have them on your own personal meter, such as the wireless removable display module. Other features you’ll wish your meter had, such as the removable cartridge on the front of the device that lets you rapidly swap out a burned fuse. On the other side of the spectrum, there are some esoteric features that might leave you scratching your head. The ability to tell exactly how the meter is configured at a glance thanks to its exclusive use of toggle switches has a certain hacker appeal, but it’s a tricky user interface for most folks.
While the overall design of the HydraMeter may be divisive, one thing we can all agree on is that getting the project to this state took incredible determination. Over the years we’ve only seen a handful of individuals attempt to develop their own multimeters, and even then, none of them approached this level of fit and finish. The fact that [John] has turned all that effort over to the community by releasing his design under the CERN license is truly admirable.
[John] brought the HydraMeter out to Pasadena back in November for Supercon, and it got quite a reaction. And if you don’t like the user interface, it’s not hard to imagine how you could change it. This project has unquestionably pushed the state of the art for open source multimeters forward, and we’re eager to see where it goes from here.
Continue reading “Open Source Multimeter Raises The Bar For DIY Tools”
Art of 3D printer in the middle of printing a Hackaday Jolly Wrencher logo
Open Source, Forced Innovation, And Making Good Products
The open-source hardware business landscape is no doubt a tough one, but is it actually tougher than for closed-source hardware? That question has been on our minds since the announcement that the latest 3D printer design from former open-source hardware stalwarts Prusa Research seems like it’s not going to come with design files.
Ironically, the new Core One is exactly the printer that enthusiasts have been begging Prusa to make for the last five years or more. Since seeing hacker printers like the Voron and even crazy machines like The 100 whip out prints at incredible speed, the decade-old fundamental design of Prusa’s i3 series looks like a slow and dated, if reliable, workhorse. “Bed slinger” has become a bit of a pejorative for this printer architecture in some parts of the 3DP community. So it’s sweet to see Prusa come out with the printer that everyone wants them to make, only it comes with the bitter pill of their first truly closed-source design.
Is the act of not sharing the design files going to save them? Is it even going to matter? We would argue that it’s entirely irrelevant. We don’t have a Core One in our hands, but we can’t imagine that there is anything super secret going on inside that couldn’t be reverse engineered by any other 3DP company within a week or so. If anything, they’re playing catch up with other similar designs. So why not play to one of their greatest strengths – the engaged crowd of hackers who would most benefit from having the design files?
Of course, Prusa’s decision to not release the design files doesn’t mean that they’re turning their backs on the community. They are also going to offer an upgrade package to turn your current i3 MK4 printer into the new Core One, which is about as hacker-friendly a move as is possible. They still offer kit versions of the printers at a discount, and they continue to support their open-source slicer software.
But this one aspect, the move away from radical openness, still strikes us as bittersweet. We don’t have access to their books, of course, but we can’t imagine that not providing the design files gains them much, and it will certainly damage them a little in the eyes of their most devoted fans. We hope the Core One does well, but we also hope that people don’t draw the wrong lesson from this – that it does well because it went closed source. If we could run the experiment both ways, we’d put our money on it doing even better if they released the design files.
