Rat Propulsion Via Brain-machine Interface
Our little red-eyed friend can drive this vehicle around with his mind. WITH HIS MIND, MAN!
This is the product of research into adaptive technologies. The process is pretty invasive, implanting neural electrodes in the motor cortex of the brain. The hope is that some day this will be a safe and reliable prospect for returning mobility to paralysis victims.
We found it interesting that the vehicle was trained to react to the rats’ movements. They were allowed to move around a test space under their own power while brain signals were monitored by the electrodes. Video tracking was used to correlate their movements with those signals, and that data is used to command the motors for what the Japanese researchers are calling RatCar.
We can see the possibilities opening up for a mechanized cockroach v. RatCar free-for-all. Something of a battlebots with a live tilt. But we kid, this is actually quite creepy.
[via Neatorama and PopSci]
Build A Simple Switch
Forget hacking an easy button, grab a couple of those outdated CD-Rs and build your own switch for that next project. This was developed with handicapped accessibility in mind; assembled easily with common products and it’s fairly robust. In fact, our junk box has everything you need except the adhesive backed copper foil. Combine two old CD’s, covered in copper on facing sides, separated by two strips of Velcro to separate the conductors. When pressure is applied, one CD flexes to make contact with the other and complete the circuit. So easy, yet we never thought of it. We’ll add it to our list of homebrew input devices.
[Thanks Michael]
Cheap(er) Biometric Gun Safe
[Greg] sent in his biometric pistol safe lock. He keeps his guide light on details so not every Joe can crack the system (there is a thread to sift through if you really wanted to), but the idea runs fairly simple anyway. [Greg] took an old garage door opening fingerprint scanner and wired it into a half broken keypad based pistol safe. While he did have some issues finding a signal that only fired when the correct fingerprint is scanned, a little magic with a CMOS HEX inverter fixed that problem quick.
This does bring one question to our minds, are fingerprint scanners as easy to crack as fingerprint readers?
Munchausen Makes NES A Cartridge Programmer
What a beautiful image of NES cartridges showing their private parts. These are the raw materials for the Munchausen Flash Cartridge project. A combination of a modified game cartridge and special USB cable makes it possible to program NES cartridges while inside an unmodified console. The cartridge has an added flash chip that is running a bootloader. By connecting a USB-to-NES cable to the second controller port a game image (or custom code image) can be flashed to one of the three game slots on the writable cartridge. The bootloader provides a menu at power-up to select between the three stored images, or can go straight to the previously selected image by holding down A when the console is turned on. There’s even a recovery routine in case of problems. Check out the demo after the break.
One thing we find interesting from the forum thread is a mention that it is technically possible to run code on the NES directly from the PC. That would sure make it easy to perform live chiptunes on NES.
Continue reading “Munchausen Makes NES A Cartridge Programmer” →
A Ride Into Space, But Nothing Fancy
[Luke Geissbuhler] wanted to send something into space, a fun project his kids could get in on too. Instead of sending up a suite of electronic components they went with consumer electronics. The key element, an HD camera to record the event, is protected by a styrofoam shell and soft foam padding. To help ensure that the device was recovered an iPhone also made the trip, running a GPS tracking program that continuously updated the package’s location. To combat the ill-effects of severe cold some chemical hand warming packs also joined the flight.
As you can see after the break, it was a success. The camera documented an incredible ride, with a balloon rupture at 19 miles above the earth (that must be a calculated height as there’s no altimeter in the package). The pod came down gently thanks to a parachute and was recovered just 30 miles from where it launched.
Continue reading “A Ride Into Space, But Nothing Fancy” →
Build A Beach Winch For Wakeboarding
beachwinching itself is a hack of common wakeboarding. No waves? hrm... lets hack something together.
Here’s a build log for  a nice beach winch for your next trip out to go beachwinching. Beachwinching is when you use a fast winch on shore to pull you in, allowing you to wakeboard, wakeskate, or water skii without the need of waves or a boat or jet ski to pull you along. While there’s nothing amazingly groundbreaking here, we do love a nicely documented build log. We think a remote way to initialize the pull would be nice too.
You can catch an example video of beachwinching after the break
Continue reading “Build A Beach Winch For Wakeboarding” →
Bronze Casting With MakerBot
That, dear readers, is the smell of a new Hackspace opening up in Davenport Iowa. It is also the lovely scent of burning plastic. Because how do you celebrate a new Hackerspace? By casting bronze coins of course!
Begin by having a MakerBot extrude plastic coins, then compact the plastic coin in sand to produce a mold. Heat up your bronze in a trashcan furnace and pour it into the mold. The plastic melts away and you’re left with a bronze coin.
There are probably some safety measures and precautions that should be followed as well…
