Solar Powered Lawn Mower Cuts The Grass So You Don’t Have To
MowerFea2
It takes a lot of power and energy to keep grass levels down to an appropriate level; especially when it’s hot out. If cool glasses of lemonade aren’t around, the task at hand may not be completed any time soon causing the unkempt blades of green (or yellow) vegetation outside to continue their path of growth towards the sun.
Instead of braving the oven-like temperatures which will inevitably drench the person in sweat, this solar powered robot has been created ready to take on the job. With the heart of an Arduino, this device shaves down the grass on a regular basis, rather than only chopping down the material when it gets too long. This helps to save electricity since the mower is only dealing with young and soft plants whose heads are easily lopped off without much effort.
Internally, the robot’s circuitry interfaces with an underground wiring system that defines the cutting zones within the lawn, and proves to be a simple, accurate, and reliable approach to directing the robot where to go. If the device travels under a shaded area, a battery kicks in supplying energy to the engine. When sunlight is available, that same battery accumulates the electricity, storing it for later.
Continue reading “Solar Powered Lawn Mower Cuts The Grass So You Don’t Have To”
The BlueOkiris Gameduino Console
3011851406903369314
[Dylan] created an easy to make gaming console with an Arduino Uno, a makeshift button, an analog stick, and a TFT LCD touchscreen shield. Plus, he fashioned together a simple button with some duct tape.
So far, he has made 2 games. One is the infamous Pong. The other is a ‘Guess the Number’ type experience. The whole project is run within the code, and does not access the bootloader directly like you would with 2boots or a regular Gameduino adapter.
Build instructions can be found on [Dylan]’s hackaday.io project page (linked above). Essentially, all that is needed is to gather up the supplies, then take the button and analog stick and complete a circuit, fitting the open wires into the slots at digital pin 9. Solder the wires in place and connect ground to ground, 5v to 5v, x to A4, and y to A5. Add the TFT shield, insert a micro SD card, and upload a game.
To see it in action, check out the video after the break:
Continue reading “The BlueOkiris Gameduino Console”
Building The NSA’s Tools
Fake ANT Catalog Entry for HackRF
Back in 2013, the NSA ANT Catalog was leaked. This document contained a list of devices that are available to the NSA to carry out surveillance.
[Michael Ossmann] took a look at this, and realized that a lot of their tools were similar to devices the open source hardware community had built. Based on that, he gave a talk on The NSA Playset at Toorcamp 2014. This covered how one might implement these devices using open hardware.
The above image is a parody of an ANT Catalog page, which shows [Michael]’s HackRF, an open source software defined radio. In the talk, [Michael] and [Dean Pierce] go over the ANT Catalog devices one by one, discussing the hardware that would be needed to build your own.
Some of these tools already have open source counterparts. The NIGHTSTAND WiFi exploitation tools is essentially a WiFi Pineapple. SPARROW II is more or less a device running Kismet attached to a drone, which we’ve seen before.
A video of the Toorcamp talk is available on [Michael]’s blog. There will also be a variety of talks on this subject at DEFCON next week, which we’re looking forward to. For further reading, Wikipedia has a great summary of the ANT Catalog.
Arduino SPI Library Gains Transaction Support
Transaction SPI Timing
To prevent data corruption when using multiple SPI devices on the same bus, care must be taken to ensure that they are only accessed from within the main loop, or from the interrupt routine, never both. Data corruption can happen when one device is chip selected in the main loop, and then during that transfer an interrupt occurs, chip selecting another device. The original device now gets incorrect data.
For the last several weeks, [Paul] has been working on a new Arduino SPI library, to solve these types of conflicts. In the above scenario, the new library will generate a blocking SPI transaction, thus allowing the first main loop SPI transfer to complete, before attempting the second transfer. This is illustrated in the picture above, the blue trace rising edge is when the interrupt occurred, during the green trace chip select. The best part, it only affects SPI, your other interrupts will still happen on time. No servo jitter!
This is just one of the new library features, check out the link above for the rest. [Paul] sums it up best: “protects your SPI access from other interrupt-based libraries, and guarantees correct setting while you use the SPI bus”.
DEFCON Shenanigans: Hack The Hackaday Hat
We don’t want to call it a challenge because we fear the regulars at DEFCON can turn our piece of hardware into a smoking pile of slag, but we are planning to bring a bit of fun along with us. I’ll be wearing this classy headgear and I invite you to hack your way into the WiFi enabled Hackaday Hat.
I’ll be wearing the hat-of-many-scrolling-colors around all weekend for DEFCON 22, August 7-10th in Las Vegas. You may also find [Brian Benchoff] sporting the accessory at times. Either way, come up and say hello. We want to see any hardware you have to show us, and we’ll shower you with a bit of swag.
Don’t let it end there. Whip out your favorite pen-testing distro and hack into the hat’s access point. From there the router will serve up more information on how to hack into one of the shell accounts. Own an account and you can leave your alias for the scoreboard as well as push your own custom message to the hat’s 32×7 RGB LED marquee.
You can learn a bit more about the hat’s hardware on this project page. But as usual I’ve built this with a tight deadline and am still trying to populate all the details of the project.
Thumbnail that say The Hacklet
Hacklet #9 Bugs And Fire
9 This week on the Hacklet, we’re spending some time looking at bugs and fire! honeybeeFirst up we have [Noel] who is saving the bees with Bee-O-Neo-Tweet-O. Bees are incredibly important, both to Earth’s ecosystem and the food chain we humans need to survive. Unfortunately bees are also sensitive to some of the chemicals humans dump into the atmosphere. Sometimes it results in colored honey, but more often than not it’s detrimental to the bees.
Neonicotinoids are a class of insecticide that has been causing problems to hives near where they are used. [Noel] is banking on sensors created with bismuth electrodes to detect the chemical near the entrance to hives. The data can be collected by beekeepers all over the world and sent to a central server. He’s using an Arduino Yun as a WiFi connected base station. Each individual hive has an Adafriut Trinket and a 433MHz radio link to send data to the base. [Noel] is even hoping to detect individual bees by the sound of their wings beating.
hivemonitor
[Ken] is keeping his own bees, and wants to monitor more than just chemicals. His honeybee hive monitoring system keeps track of the temperature and weight (and thus the honey produced) by his hives. Rather than buy an expensive load cell setup, [Ken] modified a standard digital bathroom scale to suit his needs. The insects connect to the IOB (Internet of Bees) with a bit of help from the Apitronics platform and a BeagleBone Black. Ken even added a solar-powered weather station with the Apitronics system.
bug-killa[Mike] is taking a slightly different approach. He doesn’t want to save the bugs, he wants to kill the ones that bug him! [Mike] doesn’t want to get his hands dirty, so he’s created Lazy Killer 9000 for easy bug killing. Lazy Killer uses the business end of an electrified fly swatter to do its work. This project wouldn’t be complete without an Arduino, so [Mike] is adding one, as well as a WiFi shield. The entire system will have a friendly interface to turn the juice on. One of the best features of Lazy Killer is the internet connected kill count. [Mike] knows that there aren’t any bugs in the vacuum of space, so he’s entered Lazy Killer in The Hackaday Prize.
fire-charger
From bugs, we move on to Fire! [mr.jb.swe] needed a reliable portable power source. He found it in LiFePO4 batteries, but still needed a way to charge them. Toward that end he’s created The Multicharger, a watt meter and charger which can be powered from solar, wind, or thermometric power. A Powerpot X provides the fire and the power to charge the batteries. [mr.jb.swe’s] charger converts that into the standard constant current->constant voltage charging system needed by lithium chemistry batteries. The Multicharger isn’t a complete battery management system yet, but it’s well on its way.
Unitycandle candles have become a staple at wedding ceremonies.[Quinn] has taken things to the next level and beyond with this take on the classic unity candle. This candle throws fireballs 30 feet into the sky! We covered the candle back in June, but [Quinn] has been busy since then. With over 20 updates, [Quinn] has created one of the most well documented projects on Hackaday.io. Of course, being that this project is dealing with propane and monstrous fires, [Quinn] mentions you shouldn’t try unless you really know what you’re doing. Don’t set any brides on fire! That’s it for this week’s Hacklet! Tune in next week, same hack time, same hack channel, for more of the best of Hackaday.io!
Astronaut Or Astronot: Totally Giving Away A Power Supply
Hey! It’s time for another round of Astronaut or Astronot, where we try to give away a jumbo power supply to someone on hackaday.io if they have voted in the most recent community voting round.
Before I get around to telling you who won, we need to go over the criticism of the current voting scheme. There’s a lot of valid criticism out there about how the algorithm that presents projects to the voting page is broken. Yes, it weights projects so some are seen more often than others. And yes, it can be frustrating. However, the results of the voting have no bearing on The Hackaday Prize (the space thing), and the purpose of the entire community voting is to get people looking at the projects, give away t-shirts to the project creators and 3D printers, o-scopes, and power supplies to random people who have voted. We listened to your suggestions and we’re tweaking the algorithm that presents projects for the next round of voting. That starts Monday, we’re doing the drawing on Wednesday, and votes don’t carry over from round to round.
With that out of the way, it’s time to do the whole ‘pick a random person on hackaday.io and see if they voted’ thing. For this week’s lottery, I chose five random people on the site, hoping I wouldn’t go through all of them before giving away a nice bench power supply. The first person, [in3rtial], didn’t vote. You just lost out on a really cool prize there, man.
The second person randomly selected was [tyler]. He voted a total of six times this round. I voted fifty times, but we’re not picky. That means he wins a nice power supply. Everyone go congratulate him for living somewhere that’s cheap to ship a power supply to.
That’s it for this round of Astronaut or Astronot. We’ll have a new round of voting up on Monday. For a change of pace (and because we’re going to be at DEFCON at this time next week), we’re going to do the drawing on Wednesday nevermind, we’re totally doing the drawing from DEFCON. Oh, and if you haven’t, you might want to submit a project to The Hackaday Prize. There’s still time, and your odds of winning something are really, really good.
