PIR Jack-o-Lantern Sees Them Coming
Planning to make that carved a pumpkin last past Halloween night? Forget the tealight or LED candle—here’s an easy, no-solder project that will make it extra special. By default, this jack-o-lantern looks like it has a flickering flame, but get close enough to it and it goes crazy with color.
All you need is an LED matrix, a Rainbowduino to drive it, a PIR motion sensor to trigger the random colors, and a power source. [Alpha Charlie] kept the electronics from becoming pumpkin-flavored with some plastic bags. Since he used the PIR as the jack-o-lantern’s nose, there is a bit of plastic behind it to keep moisture from interfering.
[Alpha Charlie]’s build instructions are quite detailed, which makes this project even simpler if you’ve never used a PIR before. There are lots of ways you could build on this project to make it your own, like using trick-or-treater motion to trigger screams or spooky sounds, or add more sensors to make it more interactive. Watch it react after the break.
If you have nothing else at all to do between now and trick-or-treat time, you could bust out the soldering iron and recreate this 70-LED matrix jack-o-lantern. Blinkenlights too safe for your tastes? Fire-breather it is, then.
Continue reading “PIR Jack-o-Lantern Sees Them Coming”
Your Handwriting Is Now Your Font
They say your handwriting is as unique to you as is your fingerprint. Maybe they are right – perhaps every person adds a little bit of his or her personality to their penmanship. Just maybe there are enough ways to vary pressure, speed, stroke, and a dozen other almost imperceptible factors that all 7 billion of us have a slightly different style.
The study of handwriting is called Graphology, and people have been at it for a quite a long time. Most experts agree that a person’s handwriting can reveal their gender, where it starts to get fuzzy is that others claim they can tell much more including age, race, weight, and even mood. Going further down the rabbit hole, some employers have tried to use handwriting analysis to determine if an applicant is a match for a position. That seems a bit of a stretch to us.
Now, if you want to digitize a tiny bit of what makes you, you – then all you have to do it to fill out this (PDF) form and upload it to the interwebs. Out the other end will pop a true type font that you can save for yourself or share with the world. Why would you want to do that? This hack caught our eye as a way of adding annotations to our work in a more informal, yet still personal manner. Or maybe we just wanted to upload it to the cloud in hopes it would live forever. Either way, if you want to see some really amazing style, head on over to the “Penmanship Porn” subreddit where you can find some amazing chicken scratch.
Zombie Slap Results In Glorious Selfie
[Donnie Plumly] likes to spice things up at the office around holidays. This Halloween he decided to make an office photo booth — with a bit of a twist. He calls it the Zombie Selfie.
He cast his arm in silicone to make a gruesome zombie hand, which he set up with a vibration sensor. If you touch the arm (he encourages you to slap it), an Arduino picks up the vibration which initiates the picture taking sequence!
He’s using an IR LED with the Arduino to trigger the camera, and then an Eye-Fi card in it automatically transfers it to a computer in a DropBox. An IFTTT script then publishes it to Twitter for all to see under the account @ZombieSelfie! There are some pretty amusing ones already!
And so you can preview your Zombie Selfie, he also threw a monitor up — there’s no going back after the picture is taken though! It’ll be posted straight to Twitter.
When it comes to custom photo booths though, its hard to top this robotic artist who will actually paint your picture for you!
Mass Effect Rubber Band Gun A Beauty To Be-holster
This Halloween, crafting most of your props and replicas wont be as easy as hitting “print.” This Mass Effect M-6 Carnifex Rubber Band Gun is the exception, though, and it’s all thanks to the detailed efforts of [eggfooyoung]. Like many others in childhood, [eggfooyoung] dreamed of sporting his own rubber-band gun. Year’s later, he’s made that dream a reality, and one for many others as well.
rubber_band_gun_internals
Mechanically, rubber-band guns, especially semi-automatic ones, are a finely tuned escapade into complex levers and joints. [eggfooyoung] took it upon himself to learn from the best in the craft, in this case, YouTube user [RBGuns] who has posted designes for numerous rubber band weapons. Overall, the M-6 Carnifex is a triumph of shared knowledge, as it’s an iteration of [RBGun’s] M9 build. [eggfooyoung’s] documentation is also everything we’d love to see in a weekend project: design files [PDF], detailed pictures documenting the step-by-step gluing process, and resources to dig more deeply into building your own rubber band guns.
Hacklet 82 – Halloween Hacks 2015
Halloween is when the ghouls start haunting and the hackers start hacking. All hallows eve is the perfect holiday for eerie blinking LEDs, spooky audio oscillators, and wild animatronics. We had a double dose of Halloween hacks last year on the Hacklet. This year we’re bringing you even more of the best Halloween hacks on hackaday.io!
eyes1We start with [dougal] and Halloween Blinky Eyes. [Dougal] wanted to create the effect of creatures peeking at you from the dark corners of the room, and he’s certainly nailed it. A strip of WS2812 LEDs is the trick here. Pairs of LEDs light up, blink, and fade away like spooky eyes. The Strip is controlled by a Particle Core using Adafruit’s NeoPixel Library, though [Dougal] plans to move to the FastLed library. Everything is powered by a USB power pack. This hack isn’t much to look at with the lights on, so check out the video to see these eyes really shine!
witch1Next up is [controlmypad] with Blair the Witch Project. A normal trip to Home Depot turned paranormal when [controlmypad] spotted an awesome witch decoration. The free-standing mannequin had some basic animatronics and the all important manual trigger. [controlmypad] already had a discarded electric wheelchair. After replacing the chair batteries he modified it with a Sabertooth 2×32 Motor Controller and a standard radio control receiver. A spare channel was connected to Blair’s manual trigger. An aluminum tube joins the witch and the scooter. The hardest part of this hack was keeping Blair’s skirt out of the scooter wheels. Home Depot to the rescue! A simple hoop made of lawn edging plastic keeps the fabric and wheels apart.
tweet-trick
[Alex Cordonnier] and his team participated in Boilermake 2015, a 24 hour Hackathon at Purdue University. The fruit of their labor is Trick or Tweet, the tweeting Jack-o’-lantern. Yes folks, we now have the internet of gourds. Hiding inside Trick or Tweet is a Raspberry Pi and a Pi Camera. The pumpkin itself is also a giant capacitive touch switch. Touching the pumpkin triggers a count down after which Trick or Tweet snaps a photo. It then adds some spooky Halloween overlays, a pun or two, and throws the whole thing up on twitter @PumpkinPiPics. [Alex] hasn’t uploaded the code yet, but we’re guessing it consists of a few Python scripts. Pretty awesome for 24 hours of work!
hariSometimes Halloween hacks take on a life of their own. That’s exactly what happened when [Hari Wiguna] sat down with a few parts he ordered from China. Happy Halloween 2015 is the result. [Hari’s] order included some potentiometers, a two color OLED display, and some Arduino clones. In no time [Hari] had three pots wired up to the Arduino’s analog inputs. The OLED quickly followed, displaying graphics via the Arduino’s I2C bus. He really wanted a Jack-o’-lantern though. It took a bit more tweaking, but eventually [Hari] was successful. The first pot sets eye size.  The second controls eye rotation. The third pot changes the width of Jack’s mouth. [Hari] has all the code for this hack up on his most recent project log.
Not spooked enough? If you want to see more Halloween projects, check out our newly updated Halloween hacks list! Did I miss your project? Don’t be shy, just drop me a message on Hackaday.io. That’s it for this week’s Hacklet; As always, see you next week. Same hack time, same hack channel, bringing you the best of Hackaday.io!
A Peek Under The Hood Of The 741 Op-Amp
First introduced as an IC back in 1968, but with roots that go back to 1941, the 741 has been tweaked and optimized over the years and is arguably the canonical op-amp. [Ken Shirriff] decided to take a look inside everybody’s favorite op-amp, and ended up with some good-looking photomicrographs and a lot of background on the chip.
canRather than risk the boiling acid method commonly used to decap epoxy-potted ICs, [Ken] wisely chose a TO-99 can format to attack with a hacksaw. With the die laid bare for his microscope, he was able to locate all the major components and show how each is implemented in silicon. Particularly fascinating is the difference between the construction of NPN and PNP transistors, and the concept of “current mirrors” as constant current sources. And he even whipped up a handy interactive chip viewer – click on something in the die image and find out which component it is on the 741 schematic. Very nice.
We’ve seen lots of chip decappings before, including this reveal of TTL and CMOS logic chips. It’s nice to see the guts of the venerable 741 on display, though, and [Ken]’s tour is both a great primer for the newbie and a solid review for the older hands. Don’t miss the little slice of history he included at the end of the post.
3D Scanned, CNC-Milled, Pumpkin Selfie
When you have a CNC mill sitting around, it almost seems anachronistic to pull out a kitchen knife to carve a pumpkin. You can hardly blame [Nathan Bentall] for choosing an endmill instead. If you’re feeling the same, check out his blog post where [Nathan] works through all the steps involved in going from a raw pumpkin to a 3D RGB LED bust of himself. To put his head on the pumpkin’s shoulders he captured a depth map using a Kinect and then got down to some unorthodox milling.
Continue reading “3D Scanned, CNC-Milled, Pumpkin Selfie”
