PoX: Super-Fast Graphene-Based Flash Memory
Recently a team at Fudan University claimed to have developed a picosecond-level Flash memory device (called ‘PoX’) that has an access time of a mere 400 picoseconds. This is significantly faster than the millisecond level access times of NAND Flash memory, and more in the ballpark of DRAM, while still being non-volatile. Details on the device technology were published in Nature.
In the paper by [Yutong Xing] et al. they describe the memory device as using a two-dimensional Dirac graphene-channel Flash memory structure, with hot carrier injection for both electron and hole injection, meaning that it is capable of both writing and erasing. Dirac graphene refers to the unusual electron transport properties of typical monolayer graphene sheets.
Demonstrated was a write speed of 400 picoseconds, non-volatile storage and a 5.5 × 106 cycle endurance with a programming voltage of 5 V. It are the unique properties of a Dirac material like graphene that allow these writes to occur significantly faster than in a typical silicon transistor device.
What is still unknown is how well this technology scales, its power usage, durability and manufacturability.
Jolly Wrencher Down To The Micron
RepRap was the origin of pushing hobby 3D printing boundaries, and here we see a RepRap scaled down to the smallest detail. [Vik Olliver] over at the RepRap blog has been working on getting a printer working printing down to the level of micron accuracy.
The printer is constructed using 3D printed flexures similar to the OpenFlexure microscope. Two flexures create the XYZ movement required for the tiny movements needed for micron level printing. While still in the stages of printing simple objects, the microscopic scale of printing is incredible.
Continue reading “Jolly Wrencher Down To The Micron” →
Trekulator: A Reproduction Of The 1977 Star Trek Themed Calculator
A recent project over on Hackaday.io from [Michael Gardi] is Trekulator – Where No Maker Has Gone Before.
This is a fun build and [Michael] has done a very good job of emulating the original device. [Michael] used the Hackaday.io logging feature to log his progress. Starting in September 2024 he modeled the case, got his original hardware working, got the 7-segment display working, added support for sound, got the keypad working and mounted it, added the TFT display and mounted it, wired up the breadboard implementation, designed and implemented the PCBs, added some finishing touches, installed improved keys, and added a power socket back in March.
Continue reading “Trekulator: A Reproduction Of The 1977 Star Trek Themed Calculator” →
Remembering UCSD P-System, The Pascal Virtual Machine
Long before the Java Virtual Machine (JVM) was said to take the world by storm, the p-System  (pseudo-system, or virtual machine) developed at the University of California, San Diego (UCSD) provided a cross-platform environment for the UCSD’s Pascal dialect. Later on, additional languages would also be made available for the UCSD p-System, such as Fortran (by Apple Computer) and Ada (by TeleSoft), not unlike the various languages targeting the JVM today in addition to Java. The p-System could be run on an existing OS or as its own OS directly on the hardware. This was extremely attractive in the fragmented home computer market of the 1980s.
After the final release of version IV of UCSD p-System (IV.2.2 R1.1) in 1987, the software died a slow death, but this doesn’t mean it is forgotten. People like [Hans Otten] have documented the history and technical details of the UCSD p-System, and the UCSD Pascal dialect went on to inspire Borland Pascal.
Continue reading “Remembering UCSD P-System, The Pascal Virtual Machine” →
Illustrated Kristina with an IBM Model M keyboard floating between her hands.
Keebin’ With Kristina: The One With The Part Picker
If you do a lot of 3D computer work, I hear a Spacemouse is indispensable. So why not build a keyboard around it and make it a mouse-cropad?
A Spacemouse with an arcing keyboard built around it.
Image by [DethKlawMiniatures] via reddit
That’s exactly what [DethKlawMiniatures] did with theirs. This baby is built with mild steel for the frame, along with some 3D-printed spacers and a pocket for the Spacemouse itself to live in.
Those switches are Kailh speed coppers, and they’re all wired up to a Seeed Xiao RP2040. [DethKlawMiniatures] says that making that lovely PCB by hand was a huge hassle, but impatience took over.
After a bit of use, [DethKlawMiniatures] says that the radial curve of the macro pad is nice, and the learning curve was okay. I think this baby looks fantastic, and I hope [DethKlawMiniatures] gets a lot of productivity out of it.
Continue reading “Keebin’ With Kristina: The One With The Part Picker” →
Restoration Of Six-Player Arcade Game From The Early 90s
Although the video game crash of the mid-80s caused a major decline in arcades from their peak popularity, the industry didn’t completely die off. In fact, there was a revival that lasted until the 90s with plenty of companies like Capcom, Midway, SEGA, and Konami all competing to get quarters, francs, loonies, yen, and other coins from around the world. During this time, Namco — another game company — built a colossal 28-player prototype shooter game. Eventually, they cut it down to a (still titanic) six-player game that was actually released to the world. [PhilWIP] and his associates are currently restoring one of the few remaining room-sized games that are still surviving.
Continue reading “Restoration Of Six-Player Arcade Game From The Early 90s” →
A photo of Aaron Danner with a current mirror schematic in an overlay.
Biasing Transistors With Current Sources
Over on his YouTube channel [Aaron Danner] explains biasing transistors with current sources in the 29th video of his Transistors Series. In this video, he shows how to replace a bias resistor (and consequently an additional capacitor) with a current source for both common-emitter and common-collector amplifiers.
A current source provides electrical energy with a constant current. The implication is that if the resistance of the load changes the current source will vary the voltage to compensate. In reality, this is exactly what you want. The usual resistor biasing arrangement  just simulates this over a narrow voltage range, which is generally good enough, but not as good as a true current source.
Continue reading “Biasing Transistors With Current Sources” →
