Three breakout boards connected with a few wires
Breakout Boards For The Blind
Connecting an LED to a battery seems trivial. If you have any knowledge of using breadboards, knowing that red goes with red, and that black goes with black, it’s as easy as tying your shoes. Except there’s one problem: what if you can’t see the difference between red and black? [Tara] had a student who struggled with a problem just like this, so of course, they made a whole suite of breakout boards to the rescue!
Breadboards rely almost completely on the visual cues of rows, columns, and if the part is even in the hole correctly. [Tara] fixed these issues while attempting to keep the usefulness of a breadboard. Using tactile cues rather than the traditional visual, a visually impaired individual can figure out what is positive or negative.
Braille is the obvious choice for general communication of inputs and outputs. Where [Tara]’s ingenuity came in was the method of incorporating Braille into the boards — solder joints. After reading a Hackaday article on solder Braille, [Tara] managed a fitting and efficient method of allowing ease of use.
Currently, the boards are in a prototyping stage; however, if you want to try them out yourself early, let [Tara] know. Others with visual impairments are needed to properly stress test the device. If you are someone who does not struggle with any major visual impairments, it can be hard to put yourself in their shoes. For those empathic (and with VR capabilities) among us, be sure to try it yourself!
This Week In Security: DEF CON Nonsense, Vibepwned, And 0-days
DEF CON happened just a few weeks ago, and it’s time to cover some of the interesting talks. This year there were two talks in particular that are notable for being controversial. Coincidentally both of these were from Track 3. The first was the Passkeys Pwned, a talk by SquareX about how the passkey process can be hijacked by malware.
[Dan Goodin] lays out both the details on Passkeys, and why the work from SquareX isn’t the major vulnerability that they claim it is. First, what is a Passkey? Technically it’s a public/private keypair that is stored by the user’s browser. A unique keypair is generated for each new website, and the site stores the public key. To authenticate with the Passkey, the site generates a random string, the browser signs it with the private key, and the site checks it against the public key. I stand by my early opinion, that Passkeys are effectively just passwords, but with all the best-practices mandated.
So what is the claim presented at DEF CON? Malicious code running in the context of the browser tab can hijack the passkey process. In the demonstrated attack flow, a browser extension caused the Passkey login to fail, and prompted the user to generate a new Passkey. This is an interesting observation, and a clever attack against Passkeys, but is not a vulnerability in the Passkey spec. Or more accurately, it’s an accepted limitation of Passkeys, that they cannot guarantee security in the presence of a compromised browser. Continue reading “This Week In Security: DEF CON Nonsense, Vibepwned, And 0-days”
No Die? No Problem: RealDice.org Has You Covered
Have you ever been out and about and needed to make a check against INT, WIS or CON but not had a die handy? Sure, you could use an app on your phone, but who knows what pseudorandom nonsense that’s getting up to. [Lazy Hovercraft] has got the solution with his new site RealDice.org, which, well, rolls real dice.
Well, one die, anyway. The webpage presents a button to roll a single twenty-sided die, or “Dee-Twenty” as the cool kids are calling it these days. The rolling is provided by a unit purchased from Amazon that spins the die inside a plastic bubble, similar to this unit we covered back in 2020.  (Alas for fans of the venerable game Trouble, it does not pop.) The die spinner’s button has been replaced by a relay, which is triggered from the server whenever a user hits the “roll” button.
You currently have to look at the camera feed with your own eyes to learn what number was rolled, but [Lazy Hovercraft] assures us that titanic effort will be automated once he trains up the CVE database. To that end you are encouraged to help build the dataset by punching in what number is shown on the die.
This is a fun little hack to get some physical randomness, and would be great for the sort of chatroom tabletop gaming that’s so common these days. It may also become the new way we select the What’s That Sound? winners on the Hackaday Podcast.
Before sitting down for a game session, you might want to make sure you’re all using fair dice. No matter how fair the dice, its hard to beat quantum phenomena for random noise.
CAD, From Scratch: MakerCAD
It’s likely that many of you use some form of CAD package, but how many of you have decided you didn’t like the software on offer? [Marcus Wu] did, and instead of griping, he wrote his own CAD software. It’s called MakerCAD, it’s published under an MIT licence, and you can try it yourself.
It’s written in Go, and it’s superficially similar to OpenSCAD in that the interface is through code. The similarity is skin deep though, as it provides the user with constraint solving as described in the video below the break.
As it stands it’s by no means feature complete, but it is now at a point at which it can be evaluated. Simple models can be created and exported as STEP files, so it can be used as a real-world CAD tool.
Whether it will flourish is down to the path it takes and how its community guides it. But we’re pleased to see any new open source projects in this space, which remains overly dominated by proprietary packages. If you try it, write up your experiences, we’d love to see how this develops.
Continue reading “CAD, From Scratch: MakerCAD”
