JTAG Hat Turns Raspberry Pi Into A Networked Debugger
Over the last year or so we’ve noticed a definite uptick in the number of folks using OpenOCD on the Raspberry Pi. It’s a cheap and convenient solution for poking around with various microcontrollers and embedded devices, but not always the most elegant. Looking to improve on the situation somewhat, [Matthew Mets] has been working on a purpose-built JTAG Hat to clean things up a bit.
Onboard level shifters allow you connect to JTAG and SWD interfaces from 1.8 to 5 V, and if you power the target device from the Pi itself, there’s even support for measuring the voltage and current. To connect up to your target, the open hardware board features a “legacy” pin header perfect for jumper wires, as well as a dedicated 10-pin Cortex Debug Connector. Whether you spin up your own or buy one assembled, it certainly looks like a tool worth having around if you often find yourself working with the appropriate chips.
In addition to the design files for the hardware, [Matthew] has also provided some nice documentation on how to get the software side of things up and running. Starting with a blank SD card, it walks you through the initial setup of the Raspberry Pi all the way through the installation and configuration of a patched version of OpenOCD designed to support the JTAG Hat.
If you spend more time working with 8-bit AVR chips, don’t worry. Last year we covered a similar project to turn everyone’s favorite Linux SBC into an all-in-one microcontroller development powerhouse.
3D Printing A Centrifugal Water Pump
Once upon a time, 3D printing was about churning out tiny Yodas and Pikachus, but these days, useful things are regularly 3D printed too. A great example is this centrifugal water pump that can really deliver the juice, courtesy of  [Connor].
The pump’s housings and impeller are all 3D printed in PLA, as well as the inlet which is designed for a 2L soda bottle to screw into. Gaskets are printed in pliable TPU to help seal the housings. There are a few ball bearings inside to allow the impeller to spin nicely, too, with hex head fasteners used to hold everything together and a long bolt used as the main impeller shaft. Notably, no shaft seal is included, so the pump does leak a bit, but it’s not a major concern assuming you’re just pumping water and don’t mind spilling a bit of excess. Turned with a drill at 1800 rpm, the pump is able to achieve a flow rate of 13 litres per minute, or a maximum head of 1.2 meters. The design is on Onshape, for the curious.
It’s a great example of how 3D printing can allow the creation of machines with complex geometry without the need for advanced machining skills. Instead, all the hard work is done on the CAD side of things. We’ve seen 3D printed pumps put to real work before, too, like this fertilizer dispenser. Video after the break.
Continue reading “3D Printing A Centrifugal Water Pump”
Put APIs To Work Wth This ArduinoJson Walkthrough
One of the things this community is famous for is the degree to which people will pitch in to fill an obvious need. Look at the vast array of libraries available for Arduino as an example of how people are willing to devote their time to making difficult tasks easier, often for little more than a virtual pat on the back.
One level up from the library writers are those who go through the trouble of explaining how all these libraries work in real-world applications. [Brian Lough] recently rose to that challenge with a thorough explanation of the use of the ArduinoJSON library, a very useful but often confusing library that makes IoT projects easier.
The need for an ArduinoJSON explainer no knock on its author, [Benoît Blanchon], who has done excellent work documenting the library; it’s more of a realization that the nature of JSON itself means a library that works with it is going to be complex. [Brian]’s contribution here is sharing his insights into getting ArduinoJSON up and running in a real-world ESP32 example, and dealing with the potential pitfalls of parsing a human-readable text file that can be used to represent almost any data object using the limited resources of a microcontroller. Along with the basics, we found the warning about how pointers refer back to the dynamic JSON document object particularly helpful; the bit about using filters to winnow down a large data set was useful too.
Thanks to [Brian] for taking the time to put this valuable information out there. Here’s hoping this encourages others to share the wealth of hard-earned knowledge in a similarly clear and concise manner.
Continue reading “Put APIs To Work Wth This ArduinoJson Walkthrough”
The Many Levels Of Autonomous Motoring
For years now we have been told that self-driving cars will be the Next Big Thing, and we’ve seen some companies — yes, Tesla but others too — touting current and planned features with names like “Autopilot” and “self-driving”. Cutting through the marketing hype to unpacking what that really means is difficult. But there is a standard for describing these capabilities, assigning them as levels from zero to five.
Now we’re greeted with the news that Honda have put a small number of vehicles in the showrooms in Japan that are claimed to be the first commercially available level 3 autonomous cars. That claim is debatable as for example Audi briefly had level 3 capabilities on one of their luxury sedans despite having few places to sell it in which it could be legally used. But the Honda Legend SENSING Elite can justifiably claim to be the only car on the market to the general public with the feature at the moment. It has a battery of sensors to keep track of its driver, its position, and the road conditions surrounding it. The car boasts a “Traffic Jam Pilot” mode, which “enables the automated driving system to drive the vehicle under certain conditions, instead of the driver, such as when the vehicle is in congested traffic on an expressway“.
Sounds impressive, but just what is a level 3 autonomous car, and what are all the other levels?
Continue reading “The Many Levels Of Autonomous Motoring”
Hackaday Podcast 120: Chip Shortage, VGA Glitching, Truly Owning Roku, And Omniballs
Hackaday editors Elliot Williams and Mike Szczys recount a week of awesome hacks. One you might have missed involves a Roku-based smart TV that was rooted and all secrets laid bare for the sole purpose of making an Ambilight setup work with it. We take a look at a creative blade-tracking system for a scrollsaw CNC project, and a robot arm that brings non-flat layers to 3D printing and envisions composite material printing. There’s a great template for video glitching using inexpensive VGA to CGA converter boards, cleanly squeezed into a nice enclosure. We are a bit giddy for the omniwheel robot designs [James Bruton] has been showing off. And we finish out the show with a great conversation happening this week on Hackaday: people from throughout the community share how the chip shortage is affecting their projects.
Take a look at the links below if you want to follow along, and as always, tell us what you think about this episode in the comments!
Direct download (Weighing in around 55 MB.)
Places to follow Hackaday podcasts:
Continue reading “Hackaday Podcast 120: Chip Shortage, VGA Glitching, Truly Owning Roku, And Omniballs”
3D Printed Mars Rover Smiles For The Camera
You’d be forgiven for thinking these pictures of NASA’s Perseverance Mars rover were renderings of the real deal on the Red Planet, if it wasn’t for the golf ball tucked in for scale, anyway. What you’re actually looking at is a 3D printed model made by [Alex Givens] that he brought out to the desert for a photo shoot by his friend [Josh Jalil].
[Alex] printed the parts for the model on the Ender 5 Pro, while [Josh] snapped the shots using a Canon EOS 90D. The realism of the final shots serves as a testament to how well they’ve honed their respective tools, but credit for the 3D model itself has to go to the good folks over at NASA.
The highly detailed Perseverance model came from the space agency’s extensive “3D Resources” collection, which has models for an incredible array of present and historical spacecraft. They’ve also got models for a number of interesting astronomical objects, just in case you’re in the market for a 3D printed asteroid or two.
We know, this isn’t exactly a hack in the traditional sense. But it’s a fantastic reminder of a great resource from NASA, as well as a practical demonstration of how high quality photographs can really bring a project to life.
This Week In Security: M1RACLES, The Full Half-Double, And Patch Gaps
We occasionally make fun of new security vulnerabilities that have a catchy name and shiny website. We’re breaking new ground here, though, in covering a shiny website that makes fun of itself. So first off, this is a real vulnerability in Apple’s brand-new M1 chip. It’s got CVE-2021-30747, and in some very limited cases, it could be used for something malicious. The full name is M1ssing Register Access Controls Leak EL0 State, or M1RACLES. To translate that trying-too-hard-to-be-clever name to English, a CPU register is left open to read/write access from unprivileged userspace. It happens to be a two-bit register that doesn’t have a documented purpose, so it’s perfect for smuggling data between processes.
Do note that this is an undocumented register. If it turns out that it actually does something important, this vulnerability could get more serious in a hurry. Until then, thinking of it as a two-bit vulnerability seems accurate. For now, however, the most we have to worry about is that two processes can use this to pass information back and forth. This isn’t like Spectre or Rowhammer where one process is reading or writing to an unrelated process, but both of them have to be in on the game.
The discoverer, [Hector Martin], points out one example where this could actually be abused: to bypass permissions on iOS devices. It’s a clever scenario. Third party keyboards have always been just a little worrying, because they run code that can see everything you type, passwords included. The long-standing advice has been to never use such a keyboard, if it asks for network access permissions. Apple has made this advice into a platform rule — no iOS keyboards get network access. What if a device had a second malicious app installed, that did have Internet access permissions? With a covert data channel, the keyboard could shuffle keystrokes off to its sister app, and get your secrets off the device.
So how much should you care about CVE-2021-30747? Probably not much. The shiny site is really a social experiment to see how many of us would write up the vulnerability without being in on the joke. Why go to the hassle? Apparently it was all an excuse to make this video, featuring the appropriate Bad Apple!! music video.
Half-Double’ing Down on Rowhammer
A few days ago, Google announced the details of Half-Double, and the glass is definitely Half-Double full with all the silly puns that come to mind. The concept is simple: If Rowhammer works because individual rows of ram are so physically close together, does further miniaturization enable attacks against bits two rows away? The answer is a qualified yes.
Quick refresher, Rowhammer is an attack first demonstrated against DDR3 back in 2014, where rapid access to one row of memory can cause bit-flip errors in the neighboring row. Since then, there have been efforts by chip manufacturers to harden against Rowhammer, including detection techniques. At the same time, researchers have kept advancing the art through techniques like Double-Sided Rowhammer, randomizing the order of reads, and attempts to synchronize the attack with the ram’s refresh intervals. Half-Double is yet another way to overcome the protections built into modern ram chips.
We start by specifying a particular ram row as the victim (V). The row right beside it will be the near aggressor row (N), and the next row over we call the far aggressor row (F). A normal Rowhammer attack would simply alternate between reading from the near aggressor and a far-off decoy, rapidly toggling the row select line, which degrades the physical charge in neighboring bits. The Half-Double attack instead alternates between the far aggressor and a decoy row for 1000 cycles, and then reads from the near aggressor once. This process is repeated until the victim row has a bit flip, which often happens within a few dozen iterations. Because the hammering isn’t right beside the victim row, the built-in detection applies mitigations to the wrong row, allowing the attack to succeed in spite of the mitigations.
More Vulnerable Windows Servers
We talked about CVE-2021-31166 two weeks ago, a wormable flaw in Windows’ http.sys driver. [Jim DeVries] started wondering something as soon as he heard about the CVE. Was Windows Remote Management, running on port 5985, also vulnerable? Nobody seemed to know, so he took matters into hiis own hands, and confirmed that yes, WinRM is also vulnerable to this flaw. From what I can tell, this is installed and enabled by default on every modern Windows server.
And far from his optimistic assertion that surely no-one would expose that to the Internet… It’s estimated that there over 2 million IPs doing just that.
More Ransomware
On the ransomware front, there is an interesting story out of The Republic of Ireland. The health system there was hit by Conti ransomware, and the price for decryption set at the equivalent of $20 million. It came as a surprise, then, when a decryptor was freely published. There seems to be an ongoing theme in ransomware, that the larger groups are trying to manage how much attention they draw. On the other hand, this ransomware attack includes a threat to release private information, and the Conti group is still trying to extort money to prevent it. It’s an odd situation, to be sure.
Inside Baseball for Security News
I found a series of stories and tweets rather interesting, starting with the May Android updates at the beginning of the month. [Liam Tung] at ZDNet does a good job laying out the basics. First, when Google announced the May Android updates, they pointed out four vulnerabilities as possibly being actively exploited. Dan Goodin over at Ars Technica took umbrage with the imprecise language, calling the announcement “vague to the point of being meaningless”.
Shane Huntley jumped into the fray on Twitter, and hinted at the backstory behind the vague warning. There are two possibilities that really make sense here. The first is that exploits have been found for sale somewhere, like a hacker forum. It’s not always obvious if an exploit has indeed been sold to someone using it. The other possibility given is that when Google was notified about the active exploit, there was a requirement that certain details not be shared publicly. So next time you see a big organization like Google hedge their language in an obvious and seemingly unhelpful way, it’s possible that there’s some interesting situation driving that language. Time will tell.
The Patch Gap
The term has been around since at least 2005, but it seems like we’re hearing more and more about patch gap problems. The exact definition varies, depending on who is using the term, and what product they are selling. A good working definition is the time between a vulnerability being public knowledge and an update being available to fix the vulnerability.
There are more common reasons for patch gaps, like vulnerabilities getting dropped online without any coordinated disclosure. Another, more interesting cause is when an upstream problem gets fixed and publicly announced, and it takes time to get the fix pulled in. The example in question this week is Safari, and a fix in upstream WebKit. The bug in the new AudioWorklets feature is a type confusion that provides an easy way to do audio processing in a background thread. When initializing a new worker thread, the programmer can use their own constructor to build the thread object. The function that kicks off execution doesn’t actually check that it’s been given a proper object type, and the object gets cast to the right type. Code is executed as if it was correct, usually leading to a crash.
The bug was fixed upstream shortly after a Safari update was shipped. It’s thought that Apple ran with the understanding that this couldn’t be used for an actual RCE, and therefore hadn’t issued a security update to fix it. The problem there is that it is exploitable, and a PoC exploit has been available for a week. As is often the case, this vulnerability would need to be combined with at least one more exploit to overcome the security hardening and sandboxing built into modern browsers.
There’s one more quirk that makes this bug extra dangerous, though. On iOS devices, when you download a different browser, you’re essentially running Safari with a different skin pasted on top. As far as I know, there is no way to mitigate against this bug on an iOS device. Maybe be extra careful about what websites you visit for a few days, until this get fixed.
Via Ars Technica
