The library at 3DCarParts, no filters applied.
3DCarParts.org May Have STLs For Your Next Auto Repair
Statistically speaking, you’re likely to own an automobile. If you don’t, feel free to skip reading and be smug in the comments, but those of us who do require two-tonne death machines to get around also know they need repairs from time to time. Some of those repairs involve things that make one think, “Surely I could print this”– which is the thought that led [Will Leuke] to found 3DCarParts.org, a clearinghouse for 3D models of car parts.
Most of the parts in the library seem to be simple replacements for a wide range of parts, from knobs and handles to trim, vents, and even drive gears for power seating. There are, however, some parts to help you make aftermarket modifications, like adding a touchscreen to an old Mustang. The site hosts files locally and indexes files on Thingiverse, but its ability to search by make and model is what makes it stand out. If you’ve scanned or otherwise redesigned a replacement part, you can upload it to the site as well– this is by no means a one-man show.
Continue reading “3DCarParts.org May Have STLs For Your Next Auto Repair” →
Printable Homelab Racks You Can Design In A Browser
If you’re whipping up a homelab, you might find that you’ve got a mess of little machines and cables all over your desk or other working area. If you’re wanting to get all that organized and tidied away, a rack solution might be just what you’re looking for.
Printable Racks aims to provide a simple, accessible solution for just this situation. If you want to whip up a 10-inch rack for your homelab, you start by picking a frame from a range of printable or ready-made designs. Then you can drop in a variety of gear from the catalog of 700 parts, and use the browser-based tool to check for fit issues between all your different gear. You can even import your own parts if what you’re planning to use isn’t already in the catalog.
It’s not a do-everything tool; it only really allows you to check for basic physical fit between different components. Leaving room for cables is really up to you, as well as factors like airflow and such. But it’s still plenty useful when it comes to whipping up a tidy housing solution for all your little bits of gear.
Homelabbing is a fun hobby. We particularly love to see fun examples built in weird and wonderful ways. Send your very best to the tipsline, won’t you?
Embedded 3D Printing With Liquids On A Bricked Prusa FDM Printer
Recently [Riley] got his paws on an old Prusa i3 FDM printer that had clearly seen better days, with a hot-end that had suffered an explosive blow-out. For the project he had in mind this was of course perfect, as his intention was to replace the hot-end with a syringe system for embedded 3D printing (E3DP), which uses a supportive medium to allow for the printing of materials and structures that would be impossible with just air.
Generally in additive manufacturing (AM) methods like fused deposition modelling (FDM) the material is extruded onto a build plate or a previous layer where it solidifies. This works great for materials like thermoplastics, but for other materials having only the surrounding air as support is just a recipe for a big mess. With E3DP the liquid is instead extruded into a supportive material at a selectable depth and volume, opening up a whole range of possibilities.
Continue reading “Embedded 3D Printing With Liquids On A Bricked Prusa FDM Printer” →
Self-Repairing Conductive Material From Liquid Metal
PCB circuits are cool, but you know what is cooler? Terminator circuits that’s what! And what if the same material that makes Terminator circuits could also be used for smart heat sinks, flexible circuits, and self-healing material properties? Well, that is exactly what the lab at Virginia Tech’s VT MADE Lab has created, presented by Joel from [3DPrintingNerd].
Continue reading “Self-Repairing Conductive Material From Liquid Metal” →
3D Printable Lenticular Indicators
You can 3D print all kinds of things, from Yoda heads to little models of Pikachu. Eventually, though, most of us get to a point where we want to print something a little more interesting. The lenticular prints developed by MIT CSAIL are very much that. (h/t Core77).
The ShiftLens concept is simple enough—there’s a lens layer printed in transparent material. Beneath that, lives a patterned layer in alternating colors, corresponding with the linear lenses of the layer above. Then, there’s an actuation mechanism that can shift the lens layer relative to the pattern layer. This creates a changing color effect as the mechanism is shifted. The actuation mechanism can be a knob, switch, or roller—anything that moves the layers relative to each other. On its own, it’s a bit of a curio—but there are some fun demos. In particular, using the lenticular printing on a bottle to form an indicator for when the container is closed properly. There isn’t a publicly available design tool for these prints yet, though the team developed one for Rhino that they used internally for the project.
It’s a pretty interesting application of 3D printing, and one that we fully expect a bunch of YouTubers to replicate within the month. We’ve featured some other great print hacks lately, too, like a slicer that lets you print horizontal overhangs without support. Video after the break.
Continue reading “3D Printable Lenticular Indicators” →
Are Desktop PC-ABS Prints Outperformed By Industrial FDM? Not Really
[Igor] of [My Tech Fun] set out to discover what differences, if any, can be found between parts printed in PC-ABS filament on an industrial 3D printer, and those from prosumer-grade machines and filament. His video is full of his usual attention to detail as he compares a test suite of parts printed at home in Polymaker PC-ABS with those from a Stratasys Fortus 450mc using proprietary PC-ABS filament.
PC-ABS is a filament that strives to deliver the benefits of both polycarbonate and ABS. It’s durable and has fantastic impact resistance, but it costs a bit more than either PC or ABS and requires a heated chamber.
In the end, PC-ABS from a home printer compares favorably to an industrial system, at a fraction of the price.
[Igor] has previously compared industrial ABS with comsumer ABS, but what made him curious about PC-ABS in particular was the large difference in print temperatures between Polymaker PC-ABS, and Stratasys’s own proprietary PC-ABS.
[Igor] prints Polymaker filament at 280º C in a 60-65º C  chamber, whereas the Stratasys filament prints at 325º C with a chamber temperature of 95º C. That’s quite a difference. The industrial printer has over double the print time, to boot. Would test objects printed from the industrial filament, on an industrial machine, be noticeably different from those printed at home?
To find out, [Igor] orders a test suite of parts from a company with a Stratasys Fortus 450mc (who was also kind enough to take a short video of the machine in action) and prints his own on both a Prusa Core One L, and a Bambu Labs H2D. He then proceeds to compare them in a variety of ways while testing them to destruction.
What’s the bottom line? The industrial prints have better dimensional accuracy, but the home prints have the edge in appearance. When it comes to performance the differences are mostly minor, and not always in the industrial system’s favor. Broadly speaking, PC-ABS from the home workshop compares very favorably from an expensive industrial system and proprietary filament, at a fraction of the price. See it for yourself in the video, embedded just below.
Continue reading “Are Desktop PC-ABS Prints Outperformed By Industrial FDM? Not Really” →
Corners Lifting On 3D Prints? Guide Gives Prevention Tips
Large prints have a risk of warping, by which we mean corners can lift off the print bed as the object sort of curls inward on itself. It’s not always due to poor filament quality or an unclean build plate. Sound like something you’ve dealt with? Check out this handy roundup to understand why it happens, and learn ways to prevent it.
A big flat area with sharp corners is susceptible to warping. Breaking the footprint into a grid pattern helps distribute stresses instead of concentrating them at the corners.
The reason some objects have trouble while others don’t is physics. Deposited plastic shrinks ever so slightly as it cools, and some shapes — like wide, flat surfaces with sharp corners — are worse for this than others. This sort of problem is what the guide addresses with a number of techniques.
Some are simple, like turning on brims which increases an object’s footprint. This increased surface area offers more adhesion, but also increases heat transfer from the print bed into the model, slowing the cooling process. Thinner walls and an altered infill pattern is another option. Other techniques are more complex.
The most effective methods involve modifying the model itself to reduce or eliminate stress points. One such method is to break the model’s footprint into multiple zones with a shallow grid. Instead of one big flat bottom, the object has multiple smaller ones. Because big flat areas are more susceptible to warping than small ones, turning the bottom into a grid pattern helps spread those stresses out and prevent lifting.
If you design your own models, you’ll find several design tips worth keeping in mind. It’s always smart to practice good DFM (Design For Manufacturability) which means taking 3D printer strengths and weaknesses into account when designing an object. In this case, it can help prevent print failures. Good DFM can also make parts much, much stronger just by designing in the right features.
