Running DOOM On A Custom CPU Built From Scratch
Running DOOM on weird obscure hardware is a fun hacker pastime that’s been around for a long time now. It’s always enjoyable to see someone port it to an egg timer, or a hat, or whatever else. But what about running the iconic shooter on a CPU of your very own? [Armaan] and [Liam] have done just that.
The CPU in question was designed at the logic gate level, deployed on to an FPGA, and hooked up with the necessary peripherals to run as a going concern. Early testing of the CPU involved running straightforward code to generate Mandelbrot sets and to play a simple game of Pong. But [Armaan] and [Liam] had bigger goals: to port the game that everybody ports to everything. Doing that took some work.
To get DOOM running, the CPU had to get faster, and it needed many tweaks to how memory was handled. There was also work to be done to create a keyboard interface, an HDMI video output, and a hardware timer. From there, the game itself had to then be ported to the custom CPU’s architecture. Eventually, the duo had the game running… at a glacial 0.7 FPS. A success, but not the magical end result that was desired. A bump to clock speed and further optimizations and compiler tweaks eventually got the game up to an impressive 15-20 FPS. The goal for future work is to push it to an entirely-playable figure of 30 FPS or better.
It’s worth checking out the (apparently unembeddable) videos on Instagram to see the CPU in action. We’ve also featured plenty of fun DOOM ports before, too. If you’re brewing up custom CPUs or DOOM ports of your own, keep them coming to the tipsline. The latter in particular is often a wonderful milk run for the writer that happens across it. Happy hacking out there!
WheatForce: Learning From CPU Architecture Mistakes
Nothing ever made is truly perfect and indeed, CPU architectures like x86, RISC-V, ARM, and PowerPC all have their own upsides and downsides. Today, I aim to make an architecture that learns from all these mistakes and improves architecture design for everyone.
I’ve consulted with many people opinionated on the matter, both from a software perspective, and from a hardware perspective. I have taken all their feedback in mind while creating this initial draft of the WheatForce architecture (PDF). It is inspired by pieces from many architectures: segmentation inspired by x86, hash table-like paging from PowerPC, dynamic endianness control from RISC-V and PowerPC, and more. Let’s look into each feature in a little bit more detail. Continue reading “WheatForce: Learning From CPU Architecture Mistakes” →
Benchmarking Chinese CPUs
When it comes to PCs, Westerners are most most familiar with x86/x64 processors from Intel and AMD, with Apple Silicon taking up a significant market share, too. However, in China, a relatively new CPU architecture is on the rise. A fabless semiconductor company called Loongson has been producing chips with its LoongArch architecture since 2021. These chips remain rare outside China, but some in the West have been benchmarking them.
[Daniel Lemire] has recently blogged about the performance of the Loongson 3A6000, which debuted in late 2023. The chip was put through a range of simple benchmarking tests, involving float processing and string transcoding operations. [Daniel] compared it to the Intel Xeon Gold 6338 from 2021, noting the Intel chip pretty much performed better across the board. No surprise given its extra clock rate. Meanwhile, the gang over at [Chips and Cheese] ran even more exhaustive tests on the same chip last year. The Loongson was put through typical tasks like  compressing archives and encoding video. The outlet came to the conclusion that the chip was a little weaker than older CPUs like AMD’s Zen 2 line and Intel’s 10th generation Core chips. It’s also limited as a four-core chip compared to modern Intel and AMD lines that often start at 6 cores as a minimum.
If you find yourself interested in Loongson’s product, don’t get too excited. They’re not exactly easy to lay your hands on outside of China, and even the company’s own website is difficult to access from beyond those shores. You might try reaching out to Loongson-oriented online communities if you seek such hardware.
Different CPU architectures have perhaps never been more relevant, particularly as we see the x86 stalwarts doing battle with the rise of desktop and laptop ARM processors. If you’ve found something interesting regarding another obscure kind of CPU, don’t hesitate to let the tipsline know!
Musings On A Good Parallel Computer
Until the late 1990s, the concept of a 3D accelerator card was something generally associated with high-end workstations. Video games and kin would run happily on the CPU in one’s desktop system, with later extensions like MMX, 3DNow!, and SSE providing a significant performance boost for games that supported them. As 3D accelerator cards (colloquially called graphics processing units, or GPUs) became prevalent, they took over almost all SIMD vector tasks, but one thing that they’re not good at is being a general-purpose parallel computer. This really ticked [Raph Levien] off and it inspired him to cover his grievances.
Although the interaction between CPUs and GPUs has become tighter over the decades, with PCIe in particular being a big improvement over AGP and PCI, GPUs are still terrible at running arbitrary computing tasks, and even PCIe links are still glacial compared to communication within the GPU and CPU dies. With the introduction of asynchronous graphic APIs this divide became even more intense. [Raph]’s proposal is to invert this relationship.
There’s precedent for this already, with Intel’s Larrabee and IBM’s Cell processor merging CPU and GPU characteristics on a single die, though both struggled with developing for such a new kind of architecture. Sony’s PlayStation 3 was forced to add a GPU due to these issues. There is also the DirectStorage API in DirectX, which bypasses the CPU when loading assets from storage, effectively adding CPU features to GPUs.
As [Raph] notes, so-called AI accelerators also have these characteristics, with often multiple SIMD-capable, CPU-like cores. Maybe the future is Cell after all.
Close-up of a CPU
Register Renaming: The Art Of Parallel Processing
In the quest for faster computing, modern CPUs have turned to innovative techniques to optimize instruction execution. One such technique, register renaming, is a crucial component that helps us achieve the impressive multi-tasking abilities of modern processors. If you’re keen on hacking or tinkering with how CPUs manage tasks, this is one concept you’ll want to understand. Here’s a breakdown of how it works and you can watch the video, below.
In a nutshell, register renaming allows CPUs to bypass the restrictions imposed by a limited number of registers. Consider a scenario where two operations need to access the same register at once: without renaming, the CPU would be stuck, having to wait for one task to complete before starting another. Enter the renaming trick—registers are reassigned on the fly, so different tasks can use the same logical register but physically reside in different slots. This drastically reduces idle time and boosts parallel tasking. Of course, you also have to ensure that the register you are using has the correct contents at the time you are using it, but there are many ways to solve that problem. The basic technique dates back to some IBM System/360 computers and other high-performance mainframes.
Register renaming isn’t the only way to solve this problem. There’s a lot that goes into a superscalar CPU.
Continue reading “Register Renaming: The Art Of Parallel Processing” →
What Happens If You Speedrun Making A CPU?
Usually, designing a CPU is a lengthy process, especially so if you’re making a new ISA too. This is something that can take months or even years before you first get code to run. But what if it wasn’t? What if one were to try to make a CPU as fast as humanly possible? That’s what I asked myself a couple weeks ago.
Left-to-right: Green, orange and red rectangle with 1:2 aspect ratio. Each rectangle further right has 4x the area of its neighbor on the left.
Relative ROM size. Left: Stovepipe, center: [Ben Eater]’s, right: GR8CPU Rev. 2
Enter the “Stovepipe” CPU (I don’t have an explanation for that name other than that I “needed” one). Stovepipe’s hardware was made in under 4 hours, excluding a couple small bugfixes. I started by designing the ISA, which is the simplest ISA I ever made. Instead of continuously adding things to make it more useful, I removed things that weren’t strictly necessary until I was satisfied. Eventually, all that was left were 8 major opcodes and a mere 512 bits to represent it all. That is far less than GR8CPU (8192 bit), my previous in this class of CPU, and still less than [Ben Eater]’s breadboard CPU (2048 bit), which is actually less flexible than Stovepipe. All that while taking orders of magnitude less time to create than either larger CPU. How does that compare to other CPUs? And: How is that possible?
Continue reading “What Happens If You Speedrun Making A CPU?” →
Why X86 Needs To Die
As I’m sure many of you know, x86 architecture has been around for quite some time. It has its roots in Intel’s early 8086 processor, the first in the family. Indeed, even the original 8086 inherits a small amount of architectural structure from Intel’s 8-bit predecessors, dating all the way back to the 8008. But the 8086 evolved into the 186, 286, 386, 486, and then they got names: Pentium would have been the 586.
Along the way, new instructions were added, but the core of the x86 instruction set was retained. And a lot of effort was spent making the same instructions faster and faster. This has become so extreme that, even though the 8086 and modern Xeon processors can both run a common subset of code, the two CPUs architecturally look about as far apart as they possibly could.
So here we are today, with even the highest-end x86 CPUs still supporting the archaic 8086 real mode, where the CPU can address memory directly, without any redirection. Having this level of backwards compatibility can cause problems, especially with respect to multitasking and memory protection, but it was a feature of previous chips, so it’s a feature of current x86 designs. And there’s more!
I think it’s time to put a lot of the legacy of the 8086 to rest, and let the modern processors run free. Continue reading “Why X86 Needs To Die” →
