Arduino Sticker Dispenser Saves Time
What’s the worst part about packaging up a whole lot of the same basic thing? It might just be applying the various warning stickers to the outside of the shipping box. Luckily, [Mr Innovative] has built an open-source automatic sticker dispenser that does the peeling for you, while advancing the roll one at a time quite satisfyingly.
This tidy build is made primarily of 20×20 extruded aluminium and stainless steel smooth rod. All the yellow bits are 3D printed. The brains of this operation is an Arduino Nano, with an A4988 stepper motor driver controlling a NEMA17.
Our favorite part of this build is the IR sensor pair arranged below the ready sticker. It detects when a sticker is removed, then the stepper advances the roll by one sticker height. The waste is collected on a spool underneath.
Between the video and the instructions, [Mr Innovative] has made it quite simple to build one for yourself. Definitely check this one out after the break.
[Mr Innovative] may as well go by [Mr. Automation]. Check out this automated wire prep machine from a few years ago.
Continue reading “Arduino Sticker Dispenser Saves Time” →
TwinTeeth: The Delta Bot PCB Factory
There are a few all-in-one CNC/milling/plotting/3D printing/engraving bots out there that claim to be mini factories for hobbyists, prototypers, and other homebrew creators. The latest is Diyouware’s TwinTeeth, a bot obviously inspired by a few 3D printers, but something that has a few interesting features we hope will propagate through the open hardware ecosystem.
The design of the TwinTeeth is an inverse delta bot, kinematically similar to a large number of 3D printers out there. Instead of suspending the tool from a trio of arms, the TwinTeeth puts the work surface on the arms and suspends the tool from the top of the machine. There are a few neat bonuses for this setup – all the tools, from a BluRay laser diode, a Dremel, solder paste dispenser, and a plastic extruder for 3D printing can be mounted in easy to mount adapters. The TwinTooth design uses three locking pins to keep each toolhead in place, and after a little bit of software setup this machine can quickly switch between its various functions.
One very interesting feature of this bot is the ability to mask off PCBs for chemical etching with a BluRay laser diode. This actually works pretty well, as evidenced by the teams earlier work with a purpose-built PCB masker machine. The only problem with this technique is that presensitized boards must be used. If that’s an issue, no problem, just use the Dremel attachment with a v-bit cutter.
LIB3 Plans To Bring Contract Manufacturing To The Masses
LIB3's paste system
LIB3’s paste system
LIB3 is an open source hardware start-up from upstate New York. Thus far, the team has made some interesting products such as the piLED kit. However, they have big dreams for the future. LIB3 plans to become a contract assembly house specifically targeting low volume makers. To do this they have to build their own tools. LIB3’s latest project is a solder paste dispenser for surface mount components. Traditionally solder paste is applied with stencils made of stainless steel. In more recent years laser cut kapton has become a favorite for low volume production.
Both of these systems require a stencil to be made up. LIB3 took a different approach, and modified an old CNC glue dispenser for paste. The team got their hands on an 1991 vintage X/Y glue dispensing system. X/Y systems in this era were big, heavy affairs with powerful motors. LIB3 removed all the control electronics and built their own system from scratch. New features include direct computer control, and a vision system.
Continue reading “LIB3 Plans To Bring Contract Manufacturing To The Masses” →
