Perfecting The Shape-Changing Fruit Bowl
Fruit bowls have an unavoidable annoyance– not flies and rotten fruit, those would be avoidable if your diet was better. No, it’s that the bowl is never the right size. Either your fruit is sad and lonely in a too-large bowl, or it’s falling out. It’s the kind of existential nightmare that can only be properly illustrated by a late-night infomercial. [Simone Giertz] has a solution to the problem: a shape-changing fruit bowl.
See, it was one thing to make a bowl that could change shape. That was easy, [Simone] had multiple working prototypes. There are probably many ways to do it, but we like [Simone]’s use of an iris mechanism in a flat base to allow radial expansion of the walls. The problem was that [Simone] has that whole designer thing going on, and needs the bowl to be not only functional, but aesthetically pleasing. Oh, and it would be nice if expanding the bowl didn’t create escape routes for smaller fruits, but that got solved many prototypes before it got pretty.
It’s neat to see her design process. Using 3D printing and CNC machining for prototyping is very familiar to Hackaday, but lets be honest — for our own projects, it’s pretty common to stop at “functional”. Watching [Simone] struggle to balance aesthetics with design-for-manufacturing makes for an interesting 15 minutes, if nothing else. Plus she gives us our inspirational quote of the day: “As much as I feel like I’m walking in circles, I know that product development is a spiral”. Something to keep in mind next time it seems like you’re going around the drain in your own projects. Just be warned, she does have a bit of a potty mouth.
We’ve featured [Simone]’s design decisions here, if you’re interested in seeing how she goes the rest of the way from project to product. We’re pretty sure her face-slapping-alarm clock never made it into the SkyMall catalog, though.
Continue reading “Perfecting The Shape-Changing Fruit Bowl”
A woman in a richly-colored blue head scarf leans over a wooden table looking at the timer between her hands. The timer has a yellow circle on black flip panels on the left and black and white CT scans of a human torso on the right side. The frame is wood, and there is an electric motor on the upper right of the frame and a silver drum on the left of the frame beneath the woman's hand.
A Flip Clock Becomes A Flip Timer
Sometimes it’s nice to have a widget to do a single task and avoid getting distracted by the supposed simplicity of doing it with an app on a smartphone. [Dina Amin] built a timer from an old flip clock to stay focused.
Starting with a disassembly of the flip clocks she found at a flea market with [Simone Giertz], [Amin] decided to change the twenty four hour mechanism to a twenty four minute one which was similar to the amount of time she was already using for several different practices. Since she’s an expert in animation, she planned on turning a set of CT scans into the animation that would play on the section that had previously been the minutes of the clock.
As much of the original clock’s components were damaged, and [Amin] didn’t have a chance to learn clockmaking from scratch in a week, she tried a few different drive mechanisms for the build. The drum from an air fryer timer driven with an electric motor fit the bill, but off enough from proper minutes that [Amin] switched from numerals to a yellow circle that fills in as it approaches the satisfying ding of completion.
If you want to see Simone’s Moon flip clock we’ve covered that project too.
Continue reading “A Flip Clock Becomes A Flip Timer”
A woman in a ball cap and black tank top holds a black and white image of the Moon printed on black acrylic. It can fold and is mounted on a black plastic mechanism with turning knobs affixed to the ends. There are out-of-focus shelves in the background with various items and books on them.
Moon Phase Flip Clock Is Fantastic
We love clocks, but we especially love unusual timepieces that aren’t just about showing the hour of the day. [Simone Giertz] built a flip clock moon phase tracker for a friend.
While in Egypt for Cairo Maker Faire, [Giertz] and [dina Amin] found some old flip clocks at a flea market and had to have them. [Amin] mentioned wanting to make a moon phase tracker with one, and [Giertz] decided to try her hand at making her own version. A side quest in more comfortable flying is included with the price of admission, but the real focus is the process of figuring out how to replicate the flip clocks original mechanism in a different size and shape.
[Giertz] cut out 30 semi-circle flaps from polystyrene and then affixed vinyl cut-outs to the flaps. The instructions for the assembly suggest that this might not be the best way to do it, and that printing stickers to affix to the flaps might work better since the cut vinyl turned out pretty fiddly. We really like the part where she built a grid jig to determine the optimal placement of the beams to keep the flaps in the right position after a disheartening amount of difficulties doing it in a more manual way. Her approach of letting it rest for twenty minutes before coming back to it is something you might find helpful in your own projects.
Best of all, if you want to build your own, the files are available for the flip moon station on the Yetch website. You’ll have to come up with your own method to drive it though as that isn’t in the files from what we saw.
Continue reading “Moon Phase Flip Clock Is Fantastic”
A picture of a stainless steel ring with a phillips screwdriver bit protruding from it sitting slightly askance atop a matching ring with a phillips head cut out like that of a screw. They are the same size so they can mesh when placed together.
Making Products For Fun And (Probably No) Profit
If you’re like most makers, you have a few product ideas kicking about, but you may not have made it all the way to production of those things. If you’re thinking about making the leap, [Simone Giertz] recently discussed all the perils and pitfalls of the process from idea to reality.
The TLDR is that there’s a big difference between making one item and making hundreds or thousands of them, which you probably already knew, but it is nice to see what sort of issues can crop up in this seemingly simple example of the Yetch Screwdriver Ring. It turns out that the metalworking skills of tool making and jewelry making rarely overlap in the contract manufacturing world.
[Giertz] also shares some of the more mundane, yet terrifying, parts of business like finally committing to bulk orders and whether it’s wise to go with intermediaries when working with suppliers overseas. She also keys us into parts of the process where things can go wrong, like how product samples typically use a different manufacturing process than bulk for practical reasons and how you need to have very specific quality control requirements not just decide if a product is good enough based on vibes.
If you’d like some more advice on making your own products, check out [Carrie Sundra]’s Supercon talk about Manufacturing on a Shoestring Budget.
Continue reading “Making Products For Fun And (Probably No) Profit”
A woman in a dark green shirt and grey jeans holds a set of cinnamon pants. She is standing next to a burnt orange cushioned and backed-chair. The arm rests, legs, and outer circular rack are a blonde wood. It looks somewhat mid-century modern. A number of differently-colored clothes line the wall in the background.
Uncanny Valley Of Clean Conquered By Clever Chair
Do you ever have clothes that you only wore for a few hours, so you don’t want to wash them, but it still seems icky to put them back in the drawer or closet? What if you had a dedicated place to put them instead of on your floor or piled on a chair in the corner? [Simone Giertz] has a tidier solution for you.
On top of the quasi-dirty clothing conundrum, [Giertz]’s small space means she wanted to come up with a functional, yet attractive way to wrangle these clothes. By combining the time-honored tradition of hanging clothes on the back of a chair and the space-saving efficiency of a Lazy Susan, she was able to create a chair with a rotating rack to tuck the clothes out of the way when not wearing them.
The circular rack attached to the chair orbits around a circular seat and arm rests allowing clothes to be deposited on the chair from the front and conveniently pushed to the back so they remain out of sight and out of mind until you need them. The hardware chosen seems to be pretty strong as well given the number of items placed on the rail during the demonstration portion of the video. We also really like how [Giertz] challenged herself to “CAD celibacy” for the duration of the build to try to build it quick.
If you want to see some other clever furniture hacks, how about repurposing the seats from an old subway, or hacking IKEA furniture to be more accessible?
Continue reading “Uncanny Valley Of Clean Conquered By Clever Chair”
A set of brass safety glasses sit on a marred black workbench. The top and earpiece sections of the frames are in squarish brass plate and have ruler marks on them.
Combination Safety Glasses And Measurement Tool
While rulers and tape measures are ubiquitous, they always seem to disappear when you need them. We know you’d never forget your safety glasses (safety first!), so what if they were also a measuring tool?
Starting by snapping pieces from a folding yardstick, [Simone Giertz] and [Laura Kampf] worked out a rough prototype before letting [Giertz] complete the project in brass. Some initial issues with the weight of the frames were alleviated by switching to a lighter weight plate material and using thinner frames and weight-saving holes near the ear pieces.
Beauty is in the eye of the beholder, so we’ll let somebody else decide whether or not these will be the newest fashion craze. But it’s hard to argue with the timelessness of brass unless you have a copper allergy. We could definitely see a less expensive plastic version catching on in makerspaces for the PPE bin.
Want some other cool wearable gear? How about [Giertz]’s grocery bag hat, an evening gown with servo-driven flowers, or a shirt that reflects heat out the atmospheric window?
Continue reading “Combination Safety Glasses And Measurement Tool”
A photo of a white dog with curly fur riding a black skateboard with grey motors under the front deck. There are blue squares on the top of the deck that she is standing on to steer the board.
An Electric Skateboard For The Dogs
What’s a dog to do if they want to do some accessible skateboarding? [Simone Giertz]’s three-legged pup, [Scraps], got the chance to try a LEGO Technic board for her thrills.
This electric LEGO skateboard features six motors and paw pedals to let [Scraps] steer while [Giertz] remotely controls the speed of the board. While it’s not a particularly fast ride, it does let [Scraps] live out her dreams of being a YouTube dog skateboard celebrity.
A video from [Giertz] wouldn’t be complete without a life lesson, and this time it was the importance of rest to the creative process. Sometimes when a solution eludes you, it’s just time to take a break. The steering mechanism, in particular, was giving her trouble but became simple the next morning. We’re also treated to an adorable shot of [Scraps] napping when the initial shoot of her riding the board wasn’t going as planned.
Want to try your hand at making your own skateboard? How about a deck from recycled plastic, tank treads instead of wheels, or is a rocket-powered skateboard more your speed?
Continue reading “An Electric Skateboard For The Dogs”
