Quick Robotic Base For Netbook
robot_base
This is a great example of how marketing should be done. TeleToyland and RoboRealm(currently down) have teamed up together to show you how to build a quick and easy robot base for your netbook. The build process is fairly in depth, including part numbers and links to various places to buy them. They are using RoboRealm software to control the robot, utilizing two web cams for sensory input.  This should get you well on your way to having an autonomous netbook wandering around your house.
Jacob’s Ladder
jacobs_ladder
[jandgse812] shows us how to build a Jacob’s Ladder from mostly household parts.   The bulk of the instructions for this project are included in the downloadable document, there is a downloadable video as well. Be sure to follow to the end where he shows us a much safer and possibly better looking revision. The Jacob’s Ladder has become standard fair for any mad scientists laboratory. If you plan on having a workshop suited for world domination, it absolutely must have one of these in it. Be careful though, the high voltage can be deadly.
25C3: Nokia Exploit Stops All Inbound SMS
[Tobias Engel] released a serious Nokia vulnerability today. By using a specially crafted SMS message, you can block the recipient from getting any future SMS messages. The attacker changes their Protocol Identifier to “Internet Electronic Mail” and then uses any email address 32 characters or more in their message. The recipient will receive no indication that they got the message and no other messages will be allowed until the phone is factory reset. You can see a demo video here. This affects many different varieties of S60 phones and no fix is known.
[Thanks fh]
25C3: Cheap Swarm Robotics
swarm-2
The Formica project was our favorite presentation at 25C3. The goal is to build open source swarm robots as cheaply as possible. The team ended up building 25 robots in an assembly line fashion. With enough lead time, the price could get as low as £15 each. Each bot has two direct drive cellphone vibration motors with tiny neoprene wheels. They’re controlled by an MSP430 microcontroller. The only really specialized chip is a charge controller so the bots can charge without any intervention. They have copper skis on the front that touch the ground plane plus antennas to contact Vcc. On top of the bot are three IR detectors for both navigation and for transferring firmware updates between bots. A reflective sensor is on the underside for detecting “food”. It looks like a great design and any easy way for anyone to start researching swarm robotics.
25C3: Hackers Completely Break SSL Using 200 PS3s
A team of security researchers and academics has broken a core piece of internet technology. They made their work public at the 25th Chaos Communication Congress in Berlin today. The team was able to create a rogue certificate authority and use it to issue valid SSL certificates for any site they want. The user would have no indication that their HTTPS connection was being monitored/modified.
Continue reading “25C3: Hackers Completely Break SSL Using 200 PS3s” →
Card Shuffling Machine Failure
cardshuffle
Breaking from his usually routine of winning at everything, [Glacial Wanderer] has posted one of his projects that didn’t actually work. It’s a Rube Goldberg style card shuffling machine. He wanted something that was visually interesting while still randomizing the cards. A blower would be mounted to the top to mix the cards similar to a lottery ball machine. The cards would then drop into a chute that would make sure all of the cards were oriented correctly before being presented to the user. After building the first prototype, several problems were apparent. The first of which was the fan not being strong enough. His interest was waning and it looked like the time he’d have to invest in fixes was growing quickly, so he decided to cut his loses. He still posted about the prototype in hopes that it could help someone else exploring this sort of machine. A video of the mechanism can be found below.
Continue reading “Card Shuffling Machine Failure” →
25C3: CTF Dominated By Iphone-dev Team, HackMii
25c3ctf
While we had been excited about 25C3’s CTF competition, we couldn’t even venture a guess as to who would win. It seems the iphone-dev team weren’t satisfied to just give an amazing talk. They teamed up with the Wii hackers from HackMii to win the competition. You can see their progress during the eight hour competition above in red. It’s impressive to see hardware hackers jumping over to network security AND completely killing at it.
