PS3 Wireless Visual Interface
[Technott’s] at it again, this time extending the Playstation 3 with a wireless interface. This handheld isn’t actually a PS3. It provides a wireless connection to your PS3 to receive audio and video, as well as to manage controller data. Think of it as a wirelessly tethered handheld that allows you to play Playstation when your wife is watching the Real Housewives. This is similar in size to his Xbox 360 WVI but the case shape and appearance are a big step up (not that we disliked that one). We’ve embedded a video tour of the device after the break.
Continue reading “PS3 Wireless Visual Interface” →
Panoramic Scanner Camera
[Photodesaster] put together a panoramic digital camera using a scanner and some miscellaneous parts. You may remember seeing something like this about six months ago and originally about five years back. The parts used here work together nicely. The sensor board from the scanner is mounted to a metal plate along with a 50mm lens. The plate is mounted to a hard drive platter that is turned via belts connected to the original scanner motor. This way, when you tell the computer to scan an image, the lens is rotated to capture the panorama. The use of an 18V tool battery is a nice portability hack for the scanner circuitry.
Judging from this 71MP image he has achieved some remarkable results.
[Thanks Stefan]
Ikea Dioder Hack
[Joseph] wrote in to tell us about his Ikea Dioder hack. The Dioder is a lighting system with a silly name from Ikea. It is basically 4 RGB LED bars that are connected to a controller that will cycle their colors in different manners. They aren’t individually addressable, and at $50 aren’t really that great of a deal for people who could build their own. [Joseph] thought that maybe, if the features could be extended, it could be a decent lighting system. He bought it and began searching. Disappointed by the lack of hacks available, he cracked it open and began brainstorming. Ultimately, he decided to interface it with his computer. He can now control it with software, so making an ambilight clone shouldn’t be too difficult.
He does mention that he thought of making 4 independent drivers so that each light bar could be a different color. We agree that this would be the next logical step, possibly even rewiring for individual access to each LED.
Composite Video Output From Chumby
[bunnie] posted this pretty slick way of getting composite video out of a Chumby. The Chumby is an open source connectivity device that has already seen some decent hacking. This modification, done by [xobs] isn’t too difficult. It only requires patching into some pads on the motherboard and loading a custom kernel to support the external output.
CNC Project Roundup
We asked for CNC projects, and wow did you guys deliver!
First up is [J-J Shortcut’s] MDF based CNC. He’s made three thus far, with the most recent costing about 180 euro and taking 2 months to build.
[Qwindelzorf] has also constructed a multitude of CNC machines including this industrial size router and this smaller miller.
Finally, [Mick’s] large steel CNC which just made its first cut only a week ago!
Keep up the great work guys, CNC machines are not easy to build and your accomplishments are ones for the record books.
