Tailgating This Car Carries A Heavy Penalty
This hack seems simple enough:
  1. 1. Open hatchback
  2. 2. Insert jet engine
  3. 3. Profit
Actually, the guy who added a jet engine to a VW Beetle has a PhD in Mechanical Engineering from Stanford. He claims this is street legal, and even has a snapshot of the police trying to figure out what to charge him with after stopping him on the road. There’s plenty of details and we’re not questioning [Ron Patrick’s] competence, but having the intake for the turbine inside the cab of the vehicle seems a bit insane. He remarks that “it’s a little windy but not unbearable”… yeah.
One the same page you’ll find his dual-jet modified scooter. The starting cost there is considerably less, especially if you build your own ram jets.
[Thanks Goldscott]
CNC Hardware: Stream G-code To An Arduino
[Reza Naima] has been using an Arduino as the center of his CNC setup for quite some time now. It handles three stepper motors, limiting switches, e-stop, and spindle control. The sketch he’s using allows him to stream g-code to the popular prototyping platform, freeing him from needing a dedicated PC. It’s worked so well that he’s decided to clean up the code and develop a shield to help others get up and running. If you want to see his progress or lend a hand, check out the google group he started for the schematics, code, and forum discussions. There is already a CNC project for Arduino called Grbl but [Reza’s] approach uses the Arduino libraries in an effort to make the sketch more customizable for the average user.
Android Development 101 – Part 3:Introduction To Databases
In this tutorial we will be pivoting from our last tutorial on Graphical Elements to start focusing on databases in Android development. The android platform uses SQLite databases in its applications and is one of five data storage options in android development. We will only be focusing on SQLite development in android because it is key to the construction of a workable/functional program. After this tutorial you should be able to implement a SQLite database that you are then able to insert and select items from tables in the database.
For this project we will be creating a Random Quote generator that has you enter quotes or sayings in a textbox and press a button to insert them into the database. We will issue a confirmation toast that allows us to see if the data was entered into the database successfully and the textbox will be blank. If a second button is pressed, the database will be accessed and told to select a random quote from the database to show in a toast on the screen.
Continue reading “Android Development 101 – Part 3:Introduction To Databases” →
Break Out The Two-ply, Ecobot III Poops
[youtube http://www.youtube.com/watch?v=qU6zi1_aZiw&feature=player_embedded%5D
Imagine our surprise when this article on Ecobot III and the disgusting video above showed up in our feed. The robot can theoretically be self-sustaining forever, so long as it has a food source. Yes, you read correctly, food.
Typical robots relying on grub burn the biomass to produce heat/steam/energy, but Ecobot III actually digests using Microbial Fuel Cells and extracts energy in the form of hydrogen.
The process isn’t very efficient (yet), and of course waste must be excreted, but we’re inching closer and closer to the day our robot overlords are invincible. The project has come to a halt (we can’t imagine why), but you can still read up on the process, and meet Ecobot’s brothers: II and I.
Related: We’re all going to die, Carnivorous robots.
LED Matrix With A Gross Of Pixels
This LED matrix is arranged in a 24×6 pattern for message scrolling. There’s no etched boards here, making us wonder where [Syst3mX] found protoboard this long. He’s using an Arduino to drive the demonstration (clip after the break) but you can use any microcontroller with this setup. That’s because he’s using three shift registers for column data and a decade counter for row scanning, requiring just five control pins.
While you’re going to the trouble of ordering components, maybe you should try your hand at building a touch sensitive LED matrix too.
Continue reading “LED Matrix With A Gross Of Pixels” →
Complete The Hack A Day Survey, Win A Shirt
Take our reader survey. Do it. Do it right now.  Do you think we should run more articles on the dietary needs of Llamas? Here is your chance to let us know.  We got a lot of great feedback from [Jason]’s post, and now we’re ready for more. We’ve put together 10 quick questions that will help us get a feeling for what you want. We will be choosing 5 participants at random to give free t-shirts (the basic logo one).
Update: While we wait for our survey slave to get the changes made, please just put something in the fields that are mandatory(questions 7-9). Even if you put “no opinion”, we’ll get good info from the rest of the survey.
