Building A Recumbent Trike From Old Parts
This recumbent trike was built using parts from three salvaged bikes and without welding. These bikes are a bit easier on the back and neck than the traditional riding position. This one also allows for a shorter pedal crank which was a concern for the creator, [Barry Millman]. Not only did he do a fantastic job of making the thing, but he shared the project in verbose detail.
It’s a good build. It won’t win a prize for light-weight design as it includes a big chunk of plywood. But it is worth the weight hit if welding is not an option. For your viewing pleasure you’ll find a short parking lot test-drive of the finished recumbent after the break.
Oh, and if you want a more dangerous cycling build, try this over-under tandem.
Continue reading “Building A Recumbent Trike From Old Parts” →
ARM Prototyping On-the-cheap With STM32 Discovery
STMicroelectronics has another inexpensive development board out; the STM32 Discovery is an ARM Cortex-M3 prototyping platform. Coming in under $10 puts it right along the lines of their 8-bit offering, but this one is 32-bits with 5 KB of RAM and 128 KB of programming memory. It runs a bootloader and has on-board USB for easy programming. They’ve even got a trio of crippled IDE’s to get you started.
Unfortunately this is following a growing trend with the exclusion of Linux support. [Gordon] wrote in to let us know that there is hope in a couple of forms (but not using the USB functionality). The first is a serial programmer using the RS232 that [Paul] came up with (there’s a lot more on his blog so spend some time there). But you can also use the serial debug protocol to program the board.
Either way you’ll still need a method of compiling the code. We’ve had great success rolling our own GNU ARM cross compiler using this guide. Or you can grab a pre-built package by downloading Sourcery G++ lite.
Use A 3D Mouse With Eagle CAD
[Sebastian] made a 3D mouse work with Eagle CAD. He was inspired after using a 3DConnexion device to manipulate the views in a copy of Solid Edge 3D CAD modeling software. The system uses the 3D mouse in one hand with the regular mouse in the other.
It turns out that 3DConnecxion offers a lot of tools to get their devices working with your software. [Sebastian] downloaded the .NET example and modified it to read in data from the device. With the use of hot-keys he manages to get zoom, pan, and centering to work (see for yourself after the break). The only drawback to his implementation is that he can’t pan while dragging parts. But that’s just a small issue waiting for you to find a solution.
Continue reading “Use A 3D Mouse With Eagle CAD” →
Halloween Props: Puking Pirate
With everyone’s favorite free-candy holiday approaching, [Slouriesr] set to work building a vomiting ghoul for his Halloween display. He’s calling it a puking pirate and it centers around a pump and some simple plumbing fixtures.
First, the vomit receptacle was made by adding a sink drain with a pop-up stopper to the bottom of a kitty litter bucket. The drain slows the evacuation of liquid into a five gallon bucket below. In that bucket you’ll find a float switch pump used to keep water off of a pool cover. As the bucket fills up the pump turns on and empties the water through a hose ending at the ghoul’s mouth. The result is a 20-second puke cycle sure to delight the trick-or-treaters. Sure, there’s a lot of work to be done to get this guy looking the part, but what a great idea!
Help keep us in the holiday spirit by sending the details on your latest prop build.
Take Me Back To A Simpler Time, Radio Flyer
[Fred Keller] and [Judy Foster], both retired, are proving that age is just a number. What you see above is a nostalgia inducing full size driveable Radio Flyer red wagon. The base of which is a 1976 Mazda pickup truck, while the wagon portion is a mishmash of wood, fiberglass and bondo, detergent bottles, and more. Even the steering wheel has been retrofitted from an actual wheel from a wagon. We were surprised to find out the entire conversion only took the two 11 months to complete (finishing this past august), and even more confounded to learn the vehicle is completely street legal.
[Thanks Rob]
