These speakers are hand made and almost one of a kind. [Lluís Pujolàs] didn’t come up with the original design, but he sure did an amazing job of crafting them, including an eleven page build log (translated). They’re called the Odyssey 2, after the original design. The shell-shaped cavity on the bottom was built as a wooden skeleton first, then covered over for the finished shape. But the mid and high range enclosures were turned on a lathe from wood glued-ups. A serious machine shop is necessary to do this kind of woodworking. The bases are poured concrete, impregnated with lead beads to help with vibration isolation. At 330 pounds each it’s understandable that he tested them on wheels before parking them in their final position as seen above.
[Thanks Neorazz]
