For whatever reason the city [Jenslabs] lives in decided it was a good use of taxpayer money to make some giant twig chickens and put them on the boulevard in front of his house. So he decided to spruce them up a bit with some electronics.
We’re still unsure why they did this, but [Jens] recognized them for what they truly are. T-1000C — the chicken edition. Giant robot chickens sent from the future to keep an eye on [Jens] to make sure he doesn’t stop ChickenNet. Naturally they needed glowing red eyes.
Fully expecting all his hard work to be thrown out eventually, [Jens] built the upgrades out of cheap components. A few LEDs, some transistors, resistors and a LDR (light dependent resistor). That way the eyes only glow at night. And to waterproof it all, he wrapped it in good ‘ol duct tape.
[Dino] found something pretty cool at Walmart. It’s a USB Lighter; basically a car cigarette lighter that’s powered by a battery and charged via USB. A few bucks will buy you a battery, charge controller, and USB plug that will deliver over 2 amps at 3.7 Volts.
Speaking of battery chargers, here’s something from [Thomas]. He works in a hospital, and the IV pumps have a terrible charging circuit. After a few dozen chargers, they’ll give a battery error on the screen. They’re not bad, only unbalanced. [Thomas] made a simple rig with a Tenergy battery charger to rebalance the packs. No link, but here’s a pic. It beats paying $34 for a new battery pack.
Those Silhouette Cameo blade cutters don’t get enough respect. You can make vinyl stickers or an Arduino-themed pop up card.
Retroreflective spraypaint. Volvo has developed something called Lifepaint. It’s for bicycles and bicycle riders. Apparently, it’s clear when you spray it on, but if you shine a light on it – from a car’s headlight – it will reflect back. Any cool ideas here?
The market wasn’t always flooded with ARM dev boards. For a while the LeafLabs Maple was the big kid on the block. Now it’s reached end of life. If only there were a tree whose name ended in ~ino…
It’s no secret the Hackaday tip line gets a lot of email from Kickstarter campaigns and PR firms managing Kickstarter campaigns. Most of these are terrible products. Want a five-pound battery that can’t be recharged? Yeah, stuff like that.
Every once in a while, we come across a tip that’s a completely original idea. There’s a balance between ingenuity and practicality with these ideas, and I can’t figure out where this one sits. It’s a Kickstarter for perfboard, yes, but not like any perfboard you’ve ever seen.
Busboard, or solderable breadboard
Before we dig into this, let’s get some definitions straight. Perfboard is a sheet with holes drilled on a 0.1″ grid. The holes are plated on both sides, and each hole is an individual electrical node. Veroboard, or stripboard is a bunch of holes on a 0.1″ grid. These holes are also plated, but all the holes in a column are a single electrical node. You can cut the tracks between holes, but the basic idea here is to reduce the number of wires needed to connect components. Busboard, seen left, is a continuation of Veroboard, and is laid out like a solderless breadboard.
And so we come to the new invention, Perf+, the perfboard reinvented. This perfboard again is a series of plated holes on a 0.1″ grid. Alongside these holes is a plated bus. This bus does not connect to any hole; instead, a little bit of solder is used to connect it to holes on the same row or column. “Selective Veroboard,” you could call it.
Now for the real trick: on one side of the board, the plated busses run vertically. On the other side of the board, the plated busses run horizontally. This means any two holes on the protoboard can be connected as one electrical node simply with a bit of solder.
If ever there was an idea you could point to and simultaneously say, “that’s clever” and “I have no idea how to use this,” there you go. I’m pretty sure this idea isn’t better than a piece of stripboard, but it is different. If you have any idea of how to used this new, strange, and otherworldly protoboard for something useful, put a note in the comments.
Before [Mike] digs into the hardware, a quick refresher of how the castAR works: inside the glasses are two 720p projectors that shine an image on a piece of retroreflective fabric. This image reflects directly back to the glasses, where a pair of polarized glasses (like the kind you’ll find from a 3D TV), separate the image into left and right for each eye. Add some head tracking capabilities to the glasses, and you have a castAR.
The glasses come with a small bodypack that powers the glasses, adds two jacks for the accessory sockets, and switches the HDMI signal coming from the computer. The glasses are where the real fun starts with two cameras, two projectors, and a few very big chips. The projector itself is a huge innovation; [Jeri] is on record as saying the lens manufacturers told her the optical setup shouldn’t work.
As far as chips go, there’s an HDMI receiver and an Altera Cyclone FPGA. There’s also a neat little graphic from Asteroids on the board. Video below.
It doesn’t work and we’re not surprised considering the can of worms that comes with RAM addressing. Right off the bat we assume timing problems due to variance in the trace lengths and EM issues. But you have to hand it to [cyandyedeyecandy] for even trying. The self-proclaimed upgrade seeks to readjust how the DIMM works without changing the edge pinout.
The stick shown here is a 512 MB module that, because of the computer using it (unspecified in the post), is only allowing access to 256 MB. The added chips and free-form circuit make up an AND for the chip-select line, and flip-flop for the bank address.
The post is a gorgeous cry for help. We already weighed in from the peanut gallery at the top (seriously, that’s somewhat baseless guessing) so step up to the computer-engineering plate and let us know what needs to be done to make this most-awesome-of-non-working hacks actually work.
Once you’ve figured this out, here’s another one to scratch at your brain with.
After years of futzing around with 433 MHz radios and WiFi, we’re finally seeing a few dev boards that are focused on cellular radio modules. The Konekt Dash is the latest offering that puts a small u-blox SARA cellular module on a board with a small ARM Cortex M4 microcontroller for a complete cellular solution for any project you have in mind. Yes, until we get radios that make sense for an Internet of Things, this is the best you’re going to get.
If the Konekt sounds familiar, you’re right. A few months ago, Spark introduced the Electron, a cellular dev board based on the u-blox SARA-U260 module that includes a SIM with a 1MB of data a month. Practically, it’s not much different from the Konekt, but the Dash and Dash pro offer battery management and a battery connector, two power supplies, and encryption from the board to a server. There are slight differences for about the same price, but that’s what’s great about competition.
The Konekt Dash is now a few days in to a Kickstarter campaign that includes as rewards a board and a SIM with a six months to a year’s worth of data. There are a lot of things that can’t be done with WiFi, Bluetooth, or other radio modules, and if you have something like that in mind, you won’t do better than a Konekt or Spark Electron.
[Dano] builds a lot of guitar pedals and amps. He needed a speaker cabinet dedicated to this task in order to be a consistent reference when checking out his electronic creations. He ordered a couple of 10″ guitar speakers…. and they sat around for a while.
Then one day at the craft store, he stumbled on an inexpensive wooden trash can. It had a tapered design and came with a lid. As would any normal person, [Dano] immediately thought these would make a perfect speaker cabinet so he bought two of them.
The trash cans would be used in an upside-down orientation. The intended lid makes for a well fitting bottom of the cabinet. Holes were cut for the speaker and two terminal blocks. Since these cabinets would be used for testing a bunch of different amps, two different terminal blocks were used to permanently have multiple connector types available.
A pair of modern kitchen cabinet handles were used as carrying handles for each of the two cabinets. If a speaker cabinet one speaker tall is cool, a cabinet two speakers tall must be twice as cool. To get there, the two cabinets were bolted together using electrical conduit as an industrial looking spacer. Those brackets bolted to the sides of the bottom cabinet are actually Ikea shelf brackets that [Dano] had bought and never used. The Ikea brackets support casters making for easy moving around the studio.
Overall, [Dano] is happy with how his cabinets sound. They are very unique and interesting at the least. We’d be happy to play some riffs through them!
