Diskette Game Floppy Flopper Is Certainly No Flop
There’s a tactile joy to the humble 3.5″ floppy that no USB stick will ever match. It’s not just the way they thunk into place in a well-made drive, the eject button, too, is a tactile experience not to be missed. If you were a child in disk-drive days, you may have popped a disk in-and-out repeatedly just for the fun of it — and if you weren’t a child, and did it anyway, we’re not going to judge. [igor] has come up with a physical game called “Floppy Flopper” that provides an excuse to do just that en masse, and it looks like lots of fun.
It consists of nine working floppy drives in a 3×3 grid, all mounted on a hefty welded-steel frame. Each drive has an RGB LED above it. The name of the game is to swap floppies as quickly as possible so that the color of the floppy in the drive matches the color flashing above it. Each successful insertion is worth thirteen points, tracked on a lovely matrix display. Each round is faster than the last, until you miss the window or mix up colors in haste. That might make more sense if you watch the demo video below.
Continue reading “Diskette Game Floppy Flopper Is Certainly No Flop”
Don’t Say This DIY Diskette Was A Flop
Sometimes, you build a thing because you need a thing. Sometimes, you do it just to see if you can. This project is in category two: [polymatt] didn’t need to create a floppy disk from scratch-– plenty of old disks still exist– but we’re glad he made the attempt because it makes for a fascinating video that’s embedded below.
Some of you are going to quibble with the terminology [polymatt] uses in this video: first of all, he didn’t begin by creating the universe, so is he really starting “from scratch”? Secondly, the “floppy” format he’s attempting to copy is a 3½” diskette, which does not flop at all.
Choosing newer stiff-walled medium does allow him to practice his CNC skills and make the coolest-looking floppy enclosure we’ve ever seen. (It turns out brushed aluminum is even cooler-looking than the translucent neon ones.) On the other hand, we can’t help but wonder if a lower-density format 5¼” disk might have been an easier hurdle to jump. The diskette that was built does magnetize, but it can’t read or write actual files. We wonder if the older format might have been more forgiving of grain size and composition of his ferrite coating. Even more forgiving still would be to use these techniques to make magnetic tape  which is a perfectly viable way to store data.
Instead of storing data, you could make your own cleaning floppy. It’s not like data storage was really the point here, anyway– its not the destination, but the journey. So whatever you call this DIY diskette, please don’t call it a flop.
Thanks to [Anonymous] for the great tip!
Continue reading “Don’t Say This DIY Diskette Was A Flop”
Illustrated Kristina with an IBM Model M keyboard floating between her hands.
Keebin’ With Kristina: The One With The Funny Keyboard
What’s the most important keyboard macro you know? Honestly, it’s probably Ctrl-S. But do you use that one often enough? Chances are, you do not. What you need is a giant, dedicated Save keyboard that looks like a floppy disk.
A physical Save button that looks like a floppy disk and sends Ctrl-S over USB-C.
Image by [Makestreme] via Hackaday.IO
[Makestreme] recently started creating YouTube videos, but wasn’t pressing Save often enough. Couple that with editing software that crashes, and the result is hours of lost work.
Just like you’d expect, pressing the floppy icon triggers Ctrl-S when connected over USB-C. Internally, it’s a Seeeduino Xiao, a push button, and some wires.
The floppy disk itself is made of foam board, and everything is encased in a picture frame. If you want to make one for yourself, [Makestreme] has some great instructions over on IO.
Continue reading “Keebin’ With Kristina: The One With The Funny Keyboard”
Keebin’ With Kristina: The One With The TRON Keyboard
[Folaefolc] was craving a new keyboard build a few weeks ago and got inspired by the humble 3.5″ floppy disk. So much so that he decided to make a split keyboard with each half having the exact footprint of a floppy — 90 mm x 94 mm. And you know the PCBs have floppy details silkscreened on the back. Just check out the gallery.
A split keyboard with a 3.5" floppy disk footprint for each half. An actual floppy sits between the two halves.
Image via [Folaefolc] via reddit
This bad boy uses a pair of Liatris microcontrollers, which are made by splitkb and are designed to be drop-in replacements for Pro Micros and an alternative to the RP2040.
The other fun part of this build is that [Folaefolc] used RJ9 connectors to join the halves instead of something like TRRS.
Beneath those candy keycaps are 34 Kailh choc v1 switches shoved into hot swap sockets in case [Folaefolc] changes his mind. Gerbers are available if you want to build one of these cuties!
Via reddit
Continue reading “Keebin’ With Kristina: The One With The TRON Keyboard”
An odd looking apparatus for cleaning floppy disks. A neon green disk tray is suspended on metal linear rails in a vertical orientation. It can move back and forth through a set of cleaning heads and a set of drying fans. There are some control buttons on the font as well as a string of addressable LEDs and two speakers.
Rube Goldberg Floppy Disk Cleaner
Floppies were once the standard method of information exchange, but decades of storage can render them unreadable, especially if mold sets in. [Rob Smith] wanted to clean some floppies in style and made a Disco Rube Goldberg-Style device for the job.
Starting with a disk caddy on linear rails, [Smith] has a track for the floppy to follow. First it goes through a set of pads with cleaning solution on them, and is then dried off with heating elements. To make it more fun, the device has LEDs and a set of speakers at the bottom to treat the disk to a more complete car wash-esque experience.
Cotton swabs and a cleaning solution are all you really need to do the job by hand, but if you have a lot of floppies, that can get tedious quickly. [Smith] compares his machine’s performance to doing it by hand with both IPA and a dish soap solution showing that his machine does indeed clean the disks and usually makes them more readable than they were before. He cautions that it might be best to make multiple copies of the disk during the cleaning process as it isn’t always constructive though.
Thinking about archiving that stack of floppies under your workbench? While Linux doesn’t support the drives anymore, we’ve covered a couple different methods in the past and the importance of reading the flux.
Continue reading “Rube Goldberg Floppy Disk Cleaner”
Checking Out And Reviving A Batch Of Used Floppy Disks
With the last manufacturer of 3.5″ floppy disks (FDs) having shut down in 2010, those who are still using this type of storage medium for production and/or retrocomputing purposes have to increasingly rely on a dwindling stack of new old stock, or the used market. With the purported unreliability of this type of magnetic media in mind, what are the chances of a box of used FDs — whether DD or HD format — still working in 2023? That’s the question which [VWestLife] set out to answer in a recent video when he bought a stash of these real-life save icons in 720 kB format from eBay.
To his delight, he found that he could read most of the disks without issues, revealing contents that had been on there since the 1990s. All but four also could be formatted without issues, the problematic disks reported bad sectors, which was a bit of a bummer. As a practical demonstration of how fun magnetic media is, he then proceeded to try and fix these four disks with a bulk eraser tool. This is a rather brute-force tool that uses a rapidly fluctuating electromagnetic field to scramble the bits on magnetic media.
As the cause of reported bad sectors and other issues can be due to sector alignment issues from years of constant writing by different drives, this may sometimes fix a disk. In this case one of the bad disks was fixed, while a second still showed bad sectors while the remaining two refused to format at all. Assuming one can get a box of old FDs for cheap and has a few hours to kill, it’s not a bad way to refill that stack of empty FDs.
Of course if you can’t fix that old floppy, you can always make an IR filter out of it.
Continue reading “Checking Out And Reviving A Batch Of Used Floppy Disks”
Floppy Disk Sales Are Higher-Density Than You Might Think
Floppies may be big in Japan, but nostalgic and/or needful Stateside floppy enthusiasts needn’t fret — just use AOL keyword point that browser toward floppydisk.com. There, you can buy new floppies of all sizes, both new and old, recycle your disks, or send them in to get all that precious vintage stuff transferred off of them.
That delightfully Web 1.0 site is owned by Tom Persky, who fancies himself the ‘last man standing in the floppy disk business’. Who are we to argue? By the way, Tom has owned that address since approximately 1990 — evidently that’s when a cyber-squatter offered up the domain for $1,000, and although Tom scoffed at paying so much as $1 for any URL, his wife got the checkbook out, and he has had her to thank for it ever since.
My business, which used to be 90% CD and DVD duplication, is now 90% selling blank floppy disks. It’s shocking to me. — Tom Persky
In the course of writing a book all about yours-truly’s favorite less-than-rigid medium, authors Niek Hilkmann and Thomas Walskaar sat down to talk with Tom about what it’s like to basically sell buggy whips in the age of the electric car.
Tom also owns diskduper.com, which is where he got his start with floppies — by duplicating them. In the 80s and 90s, being in this business was a bit like cranking out legal tender in the basement. As time wore on and more companies stopped selling floppies or simply went under, the focus of Tom’s company shifted away from duplication and toward sales. Whereas the business was once 90% duplication and 10% floppy sales, in 2022, those percentages have flopped places, if you will.
Continue reading “Floppy Disk Sales Are Higher-Density Than You Might Think”
