A circuit board in the shape of a business card is shown. The circuitry is confined to the left side of the board, and the rest is used for text.
(Neural) Networking With A Business Card
A PCB business card is a great way for electrical engineers to impress employers with their design skills, but the software they run can be just as impressive as the card itself. As a programmer with an interest in embedded machine learning, [Dave McKinnon] wanted a card that showcased his skills, so he designed one that runs voice recognition.
[Dave] specifically wanted to run a neural network on his card, but needed to make it small enough to run on a microcontroller. Voice recognition looked like a good fit for this, since audio can be represented with relatively little data, a microphone is cheap and easy to add to a circuit board, and there was already an example of someone running such a voice recognition network on an Arduino. To fit the neural network into 46 kB, it only distinguishes the words “one” through “nine,” and displays its guess on an LED seven-segment display. [Dave] first prototyped the system with an Arduino, then designed the circuit board around an RP2040.
Continue reading “(Neural) Networking With A Business Card”
Business Card Ouija board
This Ouija Business Card Helps You Speak To Tiny Llamas
Business cards, on the whole, haven’t changed significantly over the past 600-ish years, and arguably are not as important as they used to be, but they are still worth considering as a reminder for someone to contact you. If the format of that card and method of contact stand out as unique and related to your personal or professional interests, you have a winning combination that will cement yourself in the recipient’s memory.
In a case study of “show, don’t tell”, [Binh]’s business card draws on technological and paranormal curiosity, blending affordable, short-run PCB manufacturing and an, LLM or, in this case, a Small Language Model, with a tiny Ouija board. While [Binh] is very much with us in the here and now, and a séance isn’t really an effective way to get a hold of him, the interactive Ouija card gives recipient’s a playful demonstration of his skills.
Continue reading “This Ouija Business Card Helps You Speak To Tiny Llamas”
Two sides of a business-card shaped device are shown. On the left, it’s clear that the device is about half a centimeter thick, with a large scroll wheel visible in the center. The device cover is 3D-printed in black plastic, and has cutouts to mark where three buttons ar. On the right, the underside of the device is visible. It is a black PCB, with white text giving contact information.
Building A Macro Pad Into A Business Card
A business card is a convenient way to share your contact information, but it’s unfortunately prone to being thrown away or forgotten. PCB business cards try to get around this problem, but while impressive, most won’t keep the recipient engaged for a very long time. [Cole Olsen]’s macro pad business card, on the other hand, might actually get regular use.
The card has three buttons and a rotary encoder as controls, with an RGB LED to indicate the card’s current mode. It can perform three sets of functions: general productivity, serving as a presentation remote, and controlling music. The scroll wheel is the main control, and can switch through windows, desktops, and tabs, page through slides, and control music volume.
The card itself is made out of a PCB, the exposed side of which contains [Cole]’s contact information, and the other side of which is covered by a 3D-printed case. As thick as it is, this might be stretching the definition of “card” a bit, but as a mechanical engineer, [Cole] did want to demonstrate some mechanical design. A nice!nano wireless keyboard development board running ZMK firmware reads the sensors and sends commands. Conveniently for a presentation remote, the card is powered by a rechargeable battery and can work wirelessly (as a side benefit, if a recipient were minded to get rid of this card, the lithium-polymer battery would probably substantially delay disposal).
[Cole] writes that he was inspired by many of the other impressive business cards we’ve covered. Some of the macro pads we’ve seen have been marvels of miniaturization in their own right.
Flip card
LEDs That Flow: A Fluid Simulation Business Card
Fluid-Implicit-Particle or FLIP is a method for simulating particle interactions in fluid dynamics, commonly used in visual effects for its speed. [Nick] adapted this technique into an impressive FLIP business card.
The first thing you’ll notice about this card is its 441 LEDs arranged in a 21×21 matrix. These LEDs are controlled by an Raspberry Pi RP2350, which interfaces with a LIS2DH12TR accelerometer to detect card movement and a small 32Mb memory chip. The centerpiece is a fluid simulation where tilting the card makes the LEDs flow like water in a container. Written in Rust, the firmware implements a FLIP simulation, treating the LEDs as particles in a virtual fluid for a natural, flowing effect.
This eye-catching business card uses clever tricks to stay slim. The PCB is just 0.6mm thick—compared to the standard 1.6mm—and the 3.6mm-thick 3.7V battery sits in a cutout to distribute its width across both sides of the board. The USB-C connection for charging and programming uses clever PCB cuts, allowing the plug to slide into place as if in a dedicated connector.
Inspired by a fluid simulation pendant we previously covered, this board is just as eye-catching. Thanks to [Nick] for sharing the design files for this unique business card. Check out other fluid dynamics projects we’ve featured in the past.
business card pcbs
Creative PCB Business Cards Are Sure To Make An Impression
Business cards are a simple way to share contact information, but a memorable design can make them stand out. [Jeremy Cook] has been experimenting with adding artistic finishes to PCBs, and has recently applied what he’s learned to make some unique business cards. His write-up consolidates some great resources to get you started in making your own PCB business cards, as well as PCB art in general
To make his cards stand out, he designed them to serve as functional tools beyond sharing contact information. He created two designs: one incorporates an LED and a coin cell battery holder, while the other includes drafting tools, such as a ruler, circle stencils, and a simplified protractor.
While the classic PCB solder mask is green, many board houses now offer alternative finishes and colors to enhance designs. He tested and compared the offerings from various manufacturers, highlighting the importance of researching fabrication options early, as different providers offer a variety of finishes. His creative approach shines in details like using through-hole pads as eyes in a robot illustration, making them stand out against a halftone dot pattern.
If you’re looking for more inspiration, be sure to check out the winners of our 2024 Business Card Challenge.
The Business Card Of DOOM
This account of running DOOM on a PCB business card isn’t really about serving the “Will it DOOM?” meme of getting the classic game to run on improbable hardware. Rather, this project has more to do with getting it done right and leveraging work that’s already been done.
We’ll explain. You may recall [rsheldiii]’s previous DOOM keycap build, which was quite an accomplishment for someone who doesn’t fancy himself a hardware hacker. But he made a fair number of compromises to pull that build off, and rather than letting those mistakes propagate, he decided to build a more general platform to serve as a jumping-off point for the DOOM building community. The card is centered on the RP2040, which keeps things pretty simple. The card has a tiny LCD screen along with USB jacks for power and a keyboard, so you can actually play the game. It also has GPIO lines brought out to pads on the edge of the board, in case you want to do something other than play the game, which is shown in the brief video below.
Pretty standard stuff, right? Perhaps, but where this project stands out for us is that it stresses the importance of relying on reference circuits. We’ve all seen projects that have been derided for pulling the example circuit from the datasheet, but as [rsheldiii] points out, that seems a little wrongheaded. Component manufacturers put a lot of effort into those circuits, and they don’t do it out of the goodness of their hearts. Yes, they want to make it easier for engineers to choose their parts, but in doing so they’ve done a lot of the work for you. Capitalizing on that work wherever possible only makes sense, and in this case the results were perfect for the task at hand.
Continue reading “The Business Card Of DOOM
Illustrated Kristina with an IBM Model M keyboard floating between her hands.
Keebin’ With Kristina: The One With The Folding Butterfly Keyboard
Want to give prospective employers a business card that doesn’t immediately get tossed? Of course you do. If you’re one of us, the answer is obvious: make it some kind of a PCB.
A PCB business card that doubles as a keyboard.
Image by [Ricardo Daniel de Paula] via Hackaday.IO
But as those become commonplace, it’s imperative that you make it do something. Well, you could do a lot worse than giving someone a fully-functioning capacitive-touch keyboard to carry around.
[Ricardo Daniel de Paula] initially chose the CH32V303 microcontroller because it has native USB 2.0 and 16 capacitive touch channels, which can support up to 48 keys via multiplexing.
But in order to reduce costs, [Ricardo] switched to the CH582M, which does all that plus Bluetooth communication. The goal is to have an affordable design for a unique, functioning business card, and I would say that this project has it in spades.
Continue reading “Keebin’ With Kristina: The One With The Folding Butterfly Keyboard”
