AI Might Kill Us All (With Carbon Emissions)
So-called artificial intelligence (AI) is all the rage right now between your grandma asking ChatGPT how to code in Python or influencers making videos without having to hire extras, but one growing concern is where the power is going to come from for the data centers. The MIT Technology Review team did a deep dive on what the current situation is and whether AI is going to kill us all (with carbon emissions).
Probably of most interest to you, dear hacker, is how they came up with their numbers. With no agreed upon methods and different companies doing different types of processing there were a number of assumptions baked into their estimates. Given the lack of information for closed-source models, Open Source models were used as the benchmark for energy usage and extrapolated for the industry as a whole. Unsurprisingly, larger models have a larger energy usage footprint.
While data center power usage remained roughly the same from 2005 to 2017 as increases in efficiency offset the increase in online services, data centers doubled their energy consumption by 2023 from those earlier numbers. The power running into those data centers is 48% more carbon intensive than the US average already, and expected to rise as new data centers push for increased fossil fuel usage, like Meta in Louisiana or the X data center found to be using methane generators in violation of the Clean Air Act.
Technology Review did find “researchers estimate that if data centers cut their electricity use by roughly half for just a few hours during the year, it will allow utilities to handle some additional 76 gigawatts of new demand.” This would mean either reallocating requests to servers in other geographic regions or just slowing down responses for the 80-90 hours a year when the grid is at its highest loads.
If you’re interested in just where a lot of the US-based data centers are, check out this map from NREL. Still not sure how these LLMs even work? Here’s an explainer for you.
The Greenhouse Effect Isn’t For Greenhouses
Think of a greenhouse. It’s a structure with glass walls that lets light in and traps heat, all for the benefit of the plants inside. As for how it works, that’s elementary! It’s all down to the greenhouse effect… right?
Alas, no. So many of us have been mislead. Let’s rexamine how we think greenhouses work, and then explore what’s actually going on.
Continue reading “The Greenhouse Effect Isn’t For Greenhouses”
The Clathrate Gun Hypothesis: Unearthing Puzzles Of Warming Events Past
As the Earth continues to warm at a worrying rate, scientists continue to work to understand the processes and mechanisms at play. Amidst the myriad of climate-related theories and discussions, the clathrate gun hypothesis stands out not only for its intriguing name but for the profound implications it might have on our understanding of global warming events.
Delving into this hypothesis is akin to reading a detective novel written by Mother Earth, with clues hidden deep beneath the ocean and Arctic ice. It’s a great example of how scientists attempt to predict the future by unpicking the mysteries of the past.
Continue reading “The Clathrate Gun Hypothesis: Unearthing Puzzles Of Warming Events Past”
Reduced Sulfur Emissions Could Cause Climate Shock
When we talk about emissions these days, we typically talk about cutting them back for the good of the environment. However, the climate system is a complex beast, and one we’re still learning to understand.
As it turns out, cutting back on emissions may have unexpected or undesirable effects. Some scientists are concerned that cuts to human-induced sulfur emissions may actually be warming the Earth.
Continue reading “Reduced Sulfur Emissions Could Cause Climate Shock”
Sea Level Rise From Melting Ice Sheets Could Soon Be Locked In
Where today we talk broadly of climate change and it’s various effects, the conversation was once simpler. We called it “global warming” and fretted about cooking outside in the summer and the sea level rise that would claim so many of our favorite cities.
Scientists are now concerned that sea level rises could be locked in, as ice sheets and glaciers pass “tipping points” beyond which their loss cannot be stopped. Research is ongoing to determine how best we can avoid these points of no return.
Continue reading “Sea Level Rise From Melting Ice Sheets Could Soon Be Locked In”
Sulfur Hexafluoride: The Nightmare Greenhouse Gas That’s Just Too Useful To Stop Using
Sulfur hexafluoride (SF6) is not nearly as infamous as CO2, with the latter getting most of the blame for anthropogenic climate change. Yet while measures are being implemented to curb the release of CO2, for SF6 the same does not appear to be the case, despite the potentially much greater impact that SF6 has. This is because when released into the atmosphere, CO2 only has a global warming potential (GWP) of 1, whereas that of methane is about 28 over 100 years, and SF6 has a GWP of well over 22,000 over that same time period.
Also of note here is that while methane will last only about 12.4 years in the atmosphere, SF6 is so stable that it lasts thousands of years, currently estimated at roughly 3,200 years. When we touched upon sulfur hexafluoride back in 2019 in the context of greenhouse gases, it was noted that most SF6 is used for — and leaks from — high-voltage switchgear (mechanical switches), transformers and related, where the gas’ inert and stable nature makes it ideal for preventing and quenching electrical arcing.
With the rapid growth of highly distributed energy production in the form of mostly (offshore) wind turbines and PV solar parks, this also means that each of these is equipped with its own (gas-filled) switchgear. With SF6 still highly prevalent in this market, this seems like an excellent opportunity to look into how far SF6 usage has dropped, and whether we may be able to manage to avert a potential disaster.
Continue reading “Sulfur Hexafluoride: The Nightmare Greenhouse Gas That’s Just Too Useful To Stop Using”
Blocking Out The Sun: Viable Climate Countermeasure Or Absolute Madness?
If there’s one thing humans hate, it’s exercising willpower. Whether its abstaining from unhealthy foods, going to bed early, or using less energy and reducing greenhouse gas emissions, we’re famously bad at it. Conversely, if there’s one thing humans love, it’s a workaround. Something that lets us live our lives as the carefree hedonists we are, and deals with the sticky consequences so we don’t have to.
One such workaround for the issue of climate change is a doozy, though — blocking out the sun’s rays in order to cool our warming planet.
Continue reading “Blocking Out The Sun: Viable Climate Countermeasure Or Absolute Madness?”
