GNU Radio Gets A Makeover With PimpMyGRC
[idealdealy] had a problem. GNU Radio Companion was proving to be a powerful tool, but it just didn’t look… cool enough. The solution? A custom bit of software called PimpMyGRC, designed to jazz things up a bit in everyone’s favorite open-source SDR package.
In the creator’s own words, PimpMyGRC solves the problem nobody had with GNU Radio. It stemmed from [idealdealy]’s desire to have a plain black background in the software to ease eye strain during late night debug sessions. From there, it developed into a full theming package coded in Python, complete with all kinds of fun color schemes.
You can go with “arctic” if you’re somewhere cold, “bubblegum” if you’re feeling young and fun, or “neon hacker” if you’re still obsessed with early 90s movies with terrible plot holes around computers.
None of these themes will help you work faster, but they’ll probably make your friends jealous that your setup looks a little bit cooler than theirs. Plus, there are some really fun animated effects to catch your eye if your attention is fading. You might get flames dancing on the bottom of the screen, or binary digits falling through the display in a manner vaguely akin to terminals from The Matrix.
If you’re new to this world, you might like to check out this primer on getting started with GNU Radio. Meanwhile, if you’re cooking up your own SDR hacks of value, don’t hesitate to notify the tipsline!
Software Defined Everything With Mike Ossmann And Kate Temkin
Software defined radio has become a staple of the RF tinkerer, but it’s likely that very few of us have ever taken their software defined toolchain outside the bounds of radio. It’s an area explored by Mike Ossmann and Kate Temkin in their newly published Supercon talk as they use GNU Radio to do some things that you might find unexpected.
For most people, a software defined radio is a device. An RTL-SDR dongle perhaps, or the HackRF that a popular multi-tool for working in the radio frequency realm. But as they explain, the SDR hardware can be considered merely as the analogue front end, being just the minimal analogue circuitry coupled with a digitiser. The real software-defined part comes — as you might expect — in the software
Kate and Mike introduce GNU Radio Companion — the graphical UI for GNU Radio — as their tool of choice and praise it’s use as a general purpose digital signal processing system whether or not that includes radio. Taking their own Great Scott Gadgets GreatFET One USB hackers toolkit peripheral as an input device they demonstrate this by analysing the output from a light sensor. Instantly they can analyse the mains frequency in a frequency-domain plot, and the pulse frequency of the LEDs. But their bag of tricks goes much deeper, exploring multiple “atypical use cases” that unlock a whole new world through creative digital signal processing (DSP).
Continue reading “Software Defined Everything With Mike Ossmann And Kate Temkin”
SDR Is At The Heart Of This Soup-Can Doppler Radar Set
Want to explore the world of radar but feel daunted by the mysteries of radio frequency electronics? Be daunted no more and abstract the RF complexities away with this tutorial on software-defined radar by [Luigi Cruz].
Taking inspiration from our own [Gregory L. Charvat], whose many radar projects have graced our pages before, this plunge into radar is spare on the budgetary side but rich in learning opportunities. The front end of the radar set is almost entirely contained in a LimeSDR Mini, a software-defined radio that can both transmit and receive. The only additional components are a pair of soup can antennas and a cheap LNA for the receive side. The rest of the system runs on GNU Radio Companion running on a Raspberry Pi; the whole thing is powered by a USB battery pack and lives in a plastic tote. [Luigi] has the radar set up for the 2.4-GHz ISM band, and the video below shows it being calibrated with vehicles passing by at known speeds.
True, the LimeSDR isn’t exactly cheap, but it does a lot for the price and lowers a major barrier to getting into the radar field. And [Luigi] did a great job of documenting his work and making his code available, which will help too. Continue reading “SDR Is At The Heart Of This Soup-Can Doppler Radar Set”
Getting Started With GNU Radio
Software Defined Radio (SDR)–the ability to process radio signals using software instead of electronics–is undeniably fascinating. However, there is a big gap from being able to use off-the-shelf SDR software and writing your own. After all, SDRs require lots of digital signal processing (DSP) at high speeds.
Not many people could build a modern PC from scratch, but nearly anyone can get a motherboard, some I/O cards, a power supply, and a case and put together a custom system. That’s the idea behind GNU Radio and SDR. GNU Radio provides a wealth of Python functions that you can use to create sophisticated SDR application (or, indeed, any DSP application).
If Python is still not up your alley (or even if it is), there’s an even easier way to use GNU Radio: The GNU Radio Companion (GRC). This is a mostly graphical approach, allowing you to thread together modules graphically and build simple GUIs to control you new radio.
Even though you usually think of GRC as being about radios, it is actually a good framework for building any kind of DSP application, and that’s what I’ll show you in the video below. GRC has a signal generator block and interfaces to your sound card. It even has the ability to read and write data to the file system, so you can use it to do many DSP applications or simulations with no additional hardware.
UPDATE: Don’t miss the follow-up post that uses SDRPlay to build a GNU Radio based receiver.
Continue reading “Getting Started With GNU Radio”
